Question about Brother MFC 210C All-In-One InkJet Printer
Scanner Cover The scanner has a hibit of telling me to "Close the scanner cover'. The scanner cover is closed. Is theere a solution for this?
  • dkendrick2 Oct 12, 2007
    Thank you very much. I now know where the switch is and I will try the tape. The printer is a great printer for the price, however, it does not do a good quality job on photos. I really do appreciate your taking time to answer and assist me.
  • 832 Answers
Yes. Simply stick some tape onto the cover!
On the opposite side of the menu button (to the inside of the printer) is a double plastic contact. This contact signals the open cover message. Stick some thick tape onto the cover where the contact touches down.
Posted on Oct 12, 2007
Epson printer error codes
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Sep 01, 2014 | Epson Stylus DX6050 All-In-One InkJet...
Epson Perfection V500 Photo scanner cover will not close
Check to see if the cover open switch is stuck or the is anything blocking the closing motion, rectify.
Aug 24, 2014 | Epson Perfection V500 Photo Scanner...
Unable to print 70
  1. Open the Outer Back(Rear) Cover (1) at the back of the machine. Pull the jammed paper out of the machine.
  2. Close the Inner Back(Rear) Cover (1) if it is open as shown in the illustration.
  3. Close the Outer Back(Rear) Cover. Make sure the cover is closed properly.
  4. Pull the paper trays (1) out of the machine.
  5. Push the two green levers up on both sides.
  6. Pull out the jammed paper (1) and press Stop/Exit.
  7. Push the green duplex unit up.
  8. Reset the machine by lifting the scanner cover from the front of the machine and then closing it.
    If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
  9. Using both hands, use the plastic tabs on both sides of the machine to lift the Scanner Cover (1) into the open position. Make sure that there is no jammed paper left in the corners of the machine under the plastic covers.
    Note
    • If ink gets on your skin or clothing immediately wash it off with soap or detergent.
    • If the paper is jammed under the print head, unplug the machine from the power source, and then move the print head to take out the paper.
    • If the print head has stopped in the right corner as shown in the illustration, you cannot move the print head. Press Stop/Exit until the print head moves to the middle. Then unplug the machine from the power source, and take out the paper.
    1. Gently close the scanner cover using the finger holds on both sides of it as you push down on the Scanner Cover Support (1).
    Caution Be careful not to trap your fingers under the scanner cover. Always use the finger holds provided on both sides of the scanner cover when opening and closing it.
    1. Push paper tray #1 and paper tray #2 firmly back into the machine.
    Note Make sure you pull out the paper support until it clicks.
Nov 11, 2011 | Brother MFC-6890CDW Printer
Changing ink instructions canon MP240
With the printer on, open the paper output tray. Then lift up the scanner unit (with the document cover closed). Make sure the support is holding the scanner unit. Then wait until the cartridges move to the replacement area. Pinch the tabs together to open the cartridge locking cover (it just rotates up). Then remove the cartridge by pulling it towards you. Prepare the new cartridge - remove it from the box and remove the orange tape. Do not touch the electrical contacts or the print nozzles.
Slide the new cartridge into the cartridge slot (color on the left). Then close the locking cover - it should click into place. Make sure the cover is correctly closed. Lift the scanner unit to disengage the support and lower the scanner to close it. Wait for the printer to clean the new print heads before sending a new job to the printer. (It will finish printing a job that was in progress when the ink ran out.)
Note: if the scanner unit is open for too long, the cartridges will move to their home position. Close the scanner unit and reopen it.
You can find pictures of the procedure at Canon's support site: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp240#ServiceAndSupport . Searach for replace ink cartridge. Altternatively, go to the Brochures and Manuals page and see the manual.
I hope this helps.
Mar 08, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Printer will not print showing error 2200. How do l fix it?
This is a scanner error. You could try the following...
Power off and remove the power supply(Power Cord) from the back of the unit.
Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover
Using the carrier belt, move the cartridge carrier to the middle of the unit.
Remove both cartridges, close the top cover, reinsert the power supply, and power on.
IF THE ERROR MESSAGE DID NOT COME BACK....
Power off and remove the power supply from the back of the unit.
Open the top cover
INSERT THE COLOR CARTRIDGE ONLY,
Close the top cover, reinsert the power supply, and power on
IF THE ERROR MESSAGE RETURNS.. GET A DIFFERENT COLOR CARTRIDGE AND REPEAT THIS PROCESS....
IF THE ERROR MESSAGE IS GONE,
Power down as before, do all the same to get the carrier to the middle of the unit and RE-INSTALL THE BLACK CARTRIDGE.
Power back up as in previous steps...
NO ERROR? SHOULD BE GOOD TO GO..
ERROR?? TRY DIFFERENT BLACK
If after trying all of the above and the error message does not go away, you unit would need serviced (if it's under warranty, it's worth it; if not, you might want to replace it.)
Nov 15, 2010 | Lexmark P6250 All-In-One InkJet Photo...
My mfc 240c says to close scanner cover and ink cartidge cover but both covers are closed
make sure that the USB cable unde rthe scanner fits correctly in the groove. this happened to me as well and it was because the cord was not placed properly and the scanner did not rest perfectly on the rest of the printer
May 06, 2009 | Brother MFC 240C All-In-One InkJet Printer
Black ink cartridge doesn't work.
Have you tried
  1. Taking out all the cartridges
  2. Power down the power
  3. Power up the printer
  4. Open the scanner Cover
  5. Close the scanner cover
  6. Message will ask you to put the ink.
  7. Put in Black
  8. Close scanner cover
  9. It may ask you whether the Black is being changed.
  10. Open the cover.
  11. Install Cyan.
  12. Repeat step 8-10 for the rest of the 2 colours.
  13. It should resolve the Black ink empty message.
Let us know if this works.
Thank you.
Dec 11, 2008 | Brother DCP-110C All-In-One InkJet Printer
Reinstalling ink
I put a new magenta cartridge in the printer. It says to open the scanner cover, then reinstall ink cartridge. when i open the scanner cover nothing happens and i dont know how to install the ink.
Oct 03, 2008 | Brother DCP 115C All-In-One InkJet Printer
Error code E6
An E6 is an error with the scanner cover or its switch.
6 The scanner’s cover
is open.
Close the scanner cover and
make sure it attaches
completely.
Dec 05, 2007 | Xerox DocuMate 272 Path-Through Scanner
Brother MFC 210C All-In-One InkJet Printer Logo
89 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
