Question about Whirlpool Kitchen Ranges
Accusimmer burner takes off and glows red when using large pots
11 yr old Whirlpool electric range has problem with the left front burner
when it is used as a normal burned. When a large pot or pan is used
on this burner and is set to a lower temperature range (3-6) the burner
starts to glow red hot and requires turning off for a few minutes before
it can be turned back on. This may happen several times while trying
to cook something for a longer period of time. This problem has been
happening for several years and is getting worse. This problem does not occur when burner is used in the accusimmer mode.
  • 521 Answers
SOURCE: burner on range will not turn off
  1. all these problems are given in the link below and the solutions with diagram is given in it
  3. A common flow chart for microwave repairs
  4. A breakdown of a newer counter style microwave
  5. Door switch caution and repair help
  6. How can I get at the handle screws on my microwave to replace the handle? This has a common GE style microwave picture to help you.
  7. How to install a common over the range microwave
  8. Important Disclaimer
  9. I set something on fire in my microwave and now it is!
  10. My GE OTR ( Over The Range ) microwave is running but will not cook
  11. My Frigidaire microwave is flashing a fault code in the display...what's up?
  12. My GE microwave is flashing a fault code in the display...whats up?
  13. My Panasonic microwave is flashing a fault code in the display...what's up?
  14. My Sharp microwave is flashing a fault code in the display...what's up?
  15. My Whirlpool microwave is flashing a fault code in the display...what's up?
  16. My microwave light bulbs burnt out...caution!!
  17. Ohm testing an capacitor
  18. Some common Microwave FAQ
  19. Some common components and how to check them with a ohm meter - like magnetron, high voltage transformer, high voltage capacitor, door switches and high voltage diode.
  20. Stainless Steel Cleaning
  21. Sparks from inside the oven area....why?
Posted on Aug 27, 2008
  • 1462 Answers
SOURCE: Miele Oven H316 When using
element should glow dull red when on fan oven but not bright red. are you sure fan is operating? remember there are two fans - oven fan and casing fan and you may be listening to casing fan
Posted on Nov 17, 2008
SOURCE: Burn marks on pot and pans
Just got a Garland 6 burner stove w/single oven. It was Natural gas need to convert to propane. Need supplier for conversion kit
Posted on Nov 21, 2008
  • 3361 Answers
SOURCE: yellow flame blackening pots and oven
Are you on LP/Propane gas or Natural gas?
Was the range set up by a technician?
Posted on Mar 13, 2009
  • 82 Answers
SOURCE: Back burner caught fire
If the water has been dried up, it was most likely the drip pans. Water is non flammable, sorry i couldn't help myself. If water was the problem there would be sparks and buzzing noises first.
Posted on Jun 18, 2009
Left front range top burner temerture control issues
Good Morning Friend,
I understand that you are having trouble with the left front burner on your Frigidaire range, model# FEF355. I see that the burner heats up to a glowing red hot temperature, no matter what you set the dial to. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes.
When power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button, then within 5 seconds press and hold the up or down arrows until the correct time of day appears.
Once you have set the time, turn on the left front burner, on the lowest setting. If the burner is still glowing red hot, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your range and determine what is causing the burner to glow red hot on all settings. Hope this is helpful.
-Best Regards-
May 15, 2014 | Frigidaire FEF355 Electric Kitchen Range
I have a Whirlpool electric range RF263LXTQ2- 2 yrs old-it gets so hot that the large burner pans are both charred black. Had it looked at about a year ago and couldn't find any problem-top and front of...
Since you are having problems with multiple elements the problem is probably the circuit board that controls them. This can be ordered and replaced. Be sure to unplug the stove before getting into the circuit board though.
Mar 13, 2017 | Whirlpool RF263LXTQ Range
The burner light does not go off. Why?
if you see a large red glow, but the gas does not turn on, you have a bad sensor or defective gas control valve...
If you dont see a glow, your glow rod is defective, this is the most common problem
Dec 19, 2010 | Whirlpool RF368LXKS Electric Kitchen Range
Large burner on front left only heats up a little...just enough to turn on the red light. I am handy, so how do you open the top to replace the burner?
if top does'nt lift.try removing from rear.may need to pull out from wall to remove rear panal.make sure power is disconnected.before removing panels
Oct 09, 2009 | Whirlpool RF378LXKS Electric Kitchen Range
Large range burner switch possibly defective
no warranty only 12 mo. The switch is bad call dealer - servicer and order part. should be less than $50
Apr 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Our Whirlpool speedheat 2600 burners shut down whenever we try to boil water when canning or even making pasta, what do we do?
If the pot is too large or to small for the burner or is concave or convex, the burner will short cycle. Try to match the burner to the pot and be sure the pot is nice and flat on the bottom.
Apr 08, 2009 | Whirlpool RF368LXKS Electric Kitchen Range
Burner dosent get as hot as the others
If you saw a spark from the burner chances are that the burner has shorted out and is in need of replacement.
Apr 06, 2009 | GE Spectra JBP78 Electric Kitchen Range
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Kitchen Ranges Logo
285 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
