Question about Ovens
Installation clearance/ventillation. i am reinstalling a my creda ESO-210 (specification 48261) in a below range cabinet. there is no ventilation hookup on the unit...just a few slits on the back of the unit. how much clearance/ventilation do i need for safety.
2 Suggested Answers
SOURCE: Creda Oven Model ESO 210 broken multifunction selector knob
Same thing happened with my Creda ESO 210. The function selector works find. It just doesn't rotate the piece of plastic that has the funtion symbols on it. I contacted the authorised parts supplier in Canada and was told it would cost $90 for the part. After a long wait, the part arrived and it wasn't the correct piece (they'd ordered the little plastic circle with the function symbols on it instead of the knob thingee that moves it). So, if that cost $90, I dread to think what the broken mechanism would cost. So, I gave up and I simply count the clicks from the off position to use my oven. However, if you really want to follow up on this, you can contact www.creda.co.uk.
Posted on Mar 07, 2010
Testimonial: "I appreciate the response to my problem. Although it is not the fix that is needed I know someone else is dealing with the same problem."
Jrp24bod1bb GE Double Oven
you would need a minimum of 48&1/8" high,23&1/2" Deep, and 22&1/2" wide and 14" off the floor for ventilation per G.E quick specs
Feb 18, 2013 | GE JRP24 Electric Double Oven
How can i remove ranghood kleenmaid rh1 from the wall
I removed my dead-motor Kleenmaid RH-1 rangehood from my top cabinet yesterday. (It had been in this position for about 15 years.) Using the original installation leaflet as a guide, I loosened the ventilation ducting from the top, removed the four Philips screws fixing the ranhehood top to the shelf above, and the two screws fixing it to the "L" long shaped rear bracket underneath. (It turned out that undoing these two screws was unneccesary in my case as they merely fixed the bracket to the body.)
To my consternation, it just wouldn't budge, like it was glued in place. I thought there must be some extra screws somewhere fitted by the electrician. Wrong! With a bit of serious pulling and muscle power, it came cleanly away from its fitted cabinet. However, my strong advice is to protect the cooktop heavily when you're doing this, say with boxes and other padding because when it does comes lose under heavy pulling and jiggling, it will almost certainly come loose very quickly and fall.
Good luck! I hope yours comes cleanly away once you remove those scews. If not, get someone with muscle to give you a hand to get it out with some brute force.
Larry
(Sydney)
Apr 29, 2012 | Ovens
Oven light bulb
Go to a name brand hardware store, like ACE Hardware.
Dec 17, 2011 | Ovens
Oven keeps turning off
It could be the overheat thermostats. These age and become unstable, especially if the oven cooling fan is not running or running slowly. It could also be that the ventilation holes allowing air into the cabinet/oven have become blocked, reducing the airflow for the cooling fan.
Nov 23, 2011 | Stoves Ovens
Do i need to ventilate my wall oven
No, all wall ovens have a built in cavity extractor fan. When the oven is turned on this fan operates and blows air from the oven cavity through a vent at the front of the oven, normally just above the door. This keeps the outer oven and cabinet cooled sufficiently.
Feb 27, 2011 | KitchenAid KEBS177 Electric Single Oven
How much clearance is required between the bottom of the built-in oven and the plywood floor of the cabinet
The installation manual does not specify.
(If you need a manual you can get one here: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man)
As an installer, without a manufacturer's specification, I would assume no specific clearance is required. Further, if you check the exploded parts diagram in the manual you will note that there is an insulating panel in the base of the oven. Evidently the oven has been designed to insulate the exterior panel from excess heating and does not require any minimum clearance at the base.
Mar 19, 2010 | Frigidaire (FEB30S7D) Oven
Jan 20, 2010 | Creda Europa E010E Electric Single Oven
Manual for Smeg SE398X
SMEG have all their manuals online. The SE398X series is at http://www.smegtech.com/site/smeg/myapp/libretti/index.php?model=SC110&lang=EN
Nov 07, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Mounting a microwave above stove
A copy of the installation instructions for your units should contain how far it should be.Try to study it. You'll likely find that the over the range units will fit the standard 30" cabinet and also provide the required clearance to the range top. Consider the following:- power source (dedicated circuit, with an outlet box in the cabinet above). Venting (outside ot inside), and attaching method. Though they're simple in concept to install, it's a bit awkward in reality. The main thing you need to determine is sufficient space between the MW and the stove. You will have to check, but I believe you need 18" beneath the microwave. Many companies have brackets for that purpose.
Jul 15, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
51 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
