Question about Tricity Bendix 24 in. DH104 Free-Standing Dishwasher
After washing the dishes in dishwasher everything comes out with a white film on it even the machine the machine has rinse aid and salt in it ive had the machine about 8 years with no problems untill now triciy bendix dh103
SOURCE: Dishwasher tabs not disolving dishes and glasses
let the hot water run in sink first before you start the dish washer this should fix the problem
Posted on Dec 11, 2009
  • 677 Answers
SOURCE: Dishwasher rinse-aid dispenser not working
the film is caused by hard water. go to www.dishwasherfilter.com. they have a product out for this exact problem. works amazing every time and is very affordable.
Posted on Jan 01, 2010
  • 901 Answers
SOURCE: Filters clean, arms unblocked, salt and rinse-aid ...
Yes! you are already having the answer. check your water inlet flow. Clean the strainer at the machine water hose connecting end.
Check the drain filter also. Refer user guide for instructions on cleaning.
Posted on May 21, 2010
SOURCE: Dishwasher leaves white film on
If your dishes or plastic dishes appear with a white filmy or spotted following a complete wash cycle, adjusting the amount or type of detergent you?re using and adjusting your hot water heater?s water temperature may solve the problem. But before you do either of these, put a rinse additive (such as Jet-Dry) in the rinse dispenser to improve the sheeting action of the water.
Next, you?ll have to determine whether the film is removable or permanently etched. To do this, soak a glass in undiluted white vinegar for about 15 minutes. Or, wash the glass with warm water and concentrated dishwasher detergent or a high-phosphate detergent (such as Glass Magic).
If the film comes off, it is probably caused by hard water minerals, improper amounts of detergent, or unsuitable water temperature.
Permanent etching is often caused by a combination of soft water and excessive heat or detergent. If glassware is permanently etched, there isn?t anything you can do to make it clear again. But you can avoid future etching by taking these steps:
1) Be sure hot water entering the dishwasher is no hotter than 140 degrees F. Don?t use extra-hot settings such as ?Power Scrub,? and use the ?Energy Saver? dry cycle.
2) Adjust the detergent amount.
3) Don?t pre-rinse your dishes before loading them in the dishwasher. Food particles on the dishes actually help the detergent and drying agents clean better.
A common cause of poor washing results is improper loading?dishes that block or impede the spray arm(s) or prevent the soap dispenser from opening. On the other hand, if your dishwasher has chronic problems with good washing, the problem may not be your dishwasher. A good first step is vary the amount of dishwasher detergent you're using and try switching brands.
Other possibilities: Your home?s water pressure may be too low, your water may be too hard, or the water temperature may not be hot enough.
In order for your dishwasher to fill to the appropriate level, water pressure should be from 20?120 pounds per square inch. If you suspect that your water pressure may be low, turn off all faucets or other users of water (such as washing machines and sprinklers) and then put a half-gallon jug under the kitchen faucet. Turn on the hot water full-blast. If the jug doesn?t fill within 14 seconds, your water pressure may be too low for proper dishwasher operation. Call your city water utility to discuss your options, or avoid drawing water elsewhere in the house or yard during dishwasher cycles.
The right amount of detergent to use depends on how large your load of dishes is and how hard your water is. Hardness is measured in grains of minerals?the more grains per gallon you have, the more detergent you?ll need. If your water has 12 grains or more of hardness, fill both dishwasher soap cups completely with detergent. If that doesn?t work, consider installing a water softener. (For more information, see the article Water Softener Systems.
To check water temperature, hold a meat thermometer under the hot water faucet for two minutes; if it doesn?t register a minimum of 140 degrees F., turn up the temperature dial on your hot water heater. (However, if you have a newer dishwasher that heats the water internally, it isn?t necessary to turn up your hot water heater.)
If your dishwasher has worked fine in the past but suddenly your dishes aren?t clean after the dishwasher completes all cycles, listen to the spray arm(s) spinning inside during the wash cycle. If spinning poorly, wait for the machine to cool down, remove the spray arm(s) by unscrewing the hubcap(s), lifting the arm(s) off, and then cleaning out the spray holes in the spray arm(s) with a stiff piece of wire.
Posted on Sep 03, 2010
heatman101
  • 43501 Answers
SOURCE: not cleaning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
dghjruy
Posted on Sep 29, 2010
Milky water when rinsing in dishwasher & gritty covering on dishes
I have spent many years (47) in the catering industry using catering dishwashers, under counter models, corner- wash stations and also conveyer machines..
The milky water is a by-product of the wash water and rinse water mixing.
The spray are has to rotate freely or the dishes won't wash or rinse properly. They spins a lot faster than you realise and this adds pressure to the water, but also a pulsating effect to remove dirt.
Over doing the salt can cause more problems that it solves. The gritty film may indeed BE salt. I actually prefer Calgon as a softener.
My advice is to remove both top and bottom spray arms. Check the slots/holes for obstruction, and run water through them under a tap, outside to inside (the opposite to how it is in the machine) rocking the arms up and down to allow any obstructions to flush out. Lemon pips and toothpicks are out biggest problem! Put the arms back and make sure they spin freely. Sometimes they just lock up for no apparent reason!
Use CLR descaler in the machine to clean it using the instructions on the bottle. Then run the dishwasher using the recommended doses of detergent and rinse aid.
Jan 19, 2016 | Siemens Dishwashers
Machine working fine last week then began to not clean efficiently then water did not all drain away so plunged, soaked up excess, cleaned filter, replenished dishwasher salt and rinse aid and put new...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Apr 17, 2011 | Haier Dishwashers
My dishwasher has left a white residue on items on the top shelf I have put the dishwasher on the hottest wash, I have checked the rinse aid and the salt
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Feb 05, 2011 | Neff 24 in. S5543X2 Built-in Dishwasher
My Dishwasher leaves a white film on dishes.
check inlet water quality. If more calcium deposits in the water this could happen. Try using water water softeners.
If provision for dish washer salt check and add salt. ( not kitchen salt )
Finally check whether rinse aid compartment is filled with the liquid. If you are tablet, extra rinse aid not needed. Try all the above.
Aug 17, 2010 | Whirlpool Dishwashers
White film on dishes and still dirty.
Check rinse aid is actually dispensing - turn it up to max for a while to clear it, and check level is going down after a week.
If you suffer with hard water - your heating element may need replacing as it is probably furred up.
Jun 06, 2010 | Miele G892SC SS Dishwasher
My dishwasher is leaving a white thick film on my dishes.
Check your inlet water quality. If hardness is noticed add salt as per the directions of the manufacturer. Refer user manual.
Check the rinse aid compartment and fill it with rinse aid as recommended by the manufacturer.
Apr 13, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
White film and food particles on dishes
Did you check the incoming water quality, regarding hardness!
If your washing machine supports salt addition technique, fill the appropriate box and fill the salt that is meant for washing machines. Salt works as a softener.
Finally check your rinse aid also for it's fill in the dispenser meant for it
Apr 11, 2010 | Whirlpool 24 in. DU1100XTP Built-in...
Film on dishes and inside stainless steel panel
You live in a hard water area. Even though dishwasher tablets have salt included you may have to fill the machine with extra salt. (its the large srew top cap in the bottom of your machine, open it and fill it with dishwaher salt your machine came with a large funnel to help you do this) you will have to remove the bottom drawer to do this. next make sure you have rinse aid installed in the door of your machine, next to where you put the tablets in (don't buy cheap rinse aid it's not worth it) when its full of rinse aid the indicator will turn dark, will need both salt and rince aid about every 30 cycles.
Nov 05, 2009 | Miele Optima G2470SCVi Built-in Dishwasher
Dishes aren't clean. i have run vingegar and CR through the cycle but dishes and glasses still have a film.
The most common cause of film left behind is a broken heating element.
The heating element is not only used during the dry cycle, but also to raise the water temp. during the main wash cycle to activate the dishwasher detergent. Fixing the heating element should "clear" this problem right up!
Aug 04, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
Dirty dishes
Try putting a cup of white vinegar in the empty dishwasher & running it on fast wash. Should eliminate film; do you have hard water where you live? If so lime build up could be the problem.
Hope this helps.Cheers.
May 16, 2008 | Dishwashers
Tricity Bendix 24 in. DH104 Free-Standing Dishwasher Logo
44 people viewed this question
Top Tricity Bendix Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Tricity Bendix Dishwasher Expert? Answer questions, earn points and help others
