Question about Epson Stylus Photo R300 InkJet Printer
Epson Stylus R300 Photo
Trying to print on cds but it keeps telling me the cd tray is not alligned properly - reinsert it and press the maintenance button
This is not resolving the problem
I am doing it right i have already printed about 1000 cds with no problems
Make sure that there is at least 3 inches of clearance behind the printer. sometimes the tray is ejected because it is bumping into an object which is obstructing it behind the printer. this solved the problem for me, i found the answer on Epsoms FAQ's
Posted on Dec 03, 2007
  • Epson Master
  • 691 Answers
Clean the white parts on the caddy and also clean the entry/exit rollers (use windowlene and a sponge). If you still have problems see my previous posts about under head cleaning and just complete a quick clean.
This should get you going again.
Posted on Nov 21, 2007
The cd/dvd tray is not set correctly.
reload the cd/dvd tray then press the maintenance button
Feb 16, 2010 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R300 Inkjet Printer When I try to print on a cd/dvd I line up the arrows hit print but it keeps telling me to close the cd/dvd tray, there is no way it will print with this tray.
The cd/dvd tray door has a small opening on right edge. Inside there is a slide switch. Use a toothpick to see if it is stuck. Check where it closes to the main body. A thin strip protrudes out to mate and close the plastic actuator of the switch. The door may not be closing well enough the actuate the switch. Make sure it is fully closed and retry to print. Also, there will be a small click as you raist the door before it snaps into place. If not, check to see if there may be some debris causing it to not actuate properly.
Good luck,
Feb 21, 2009 | Epson Stylus Photo R300 InkJet Printer
Need CD/DVD designer/ printing R300 stlyus photo software
I may be able to help. I have the disc with the 2.5Mb CD Printer folder on it. I can email you the folder which contains the install. Let me know. RMS
Nov 28, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
Nov 16, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus R320 - cant align the CD tray to print....keeps showing error.
This printer has a bad system tray. If doesn't work in regular way, try inserting the cd tray from the back using the back slot and see what happen (usually works)
Oct 03, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson stylus r300
Hi Chillyslade,
Try this..
Close the CD/DVD guide, then press the font28.gif maintenance button.
If the CD/DVD tray is inserted, remove the CD/DVD tray, then close the CD/DVD guide
Hope this works, kindly let me know by providing your valuable rating.
Jan 04, 2008 | Epson Stylus Photo R300 InkJet Printer
Epsom Stylus Photo R300
Yes I had a similar problem and in fact returned my printer for a replacement. You need clearance as the CD tray emerges some 2.5 to 3 inches behind the printer. If the tray hits an obstacle it is unable to correctly line up for printing and the trat is rejected
Dec 24, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
135 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
