Question about KDS Radius RAD-5 15 in. Flat Panel LCD Monitor
Moniter when my screen is on standby and the screen is blue i have white squiggles and lines and square shadows what look like scrathes please help
  • 3 Answers
I resolve a similar problem by unplugging the power cord for three seconds.
Posted on Feb 16, 2009
Sanyo dp50747 plasma tv is only showing in the middle of screen no video blue square showing horizontal 20 inches wide.The outside of square is blue solid both sides inside the square fuzzy lines red,...
It is line fault. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 17, 2014 | Sanyo Televison & Video
I have green vertical squiggles lines over whole screen
possibly the DMD chip goes bad, you can try to disassemble your tv, and take out the DMD chip, when carefully inspect its mirror, whether you found any lines or white pots in it.
if it had lines or white pots, you have to replace it.
Oct 26, 2014 | Samsung HL-S5087W DLP TV
Phone has a black dot with a purple squiggle thru it, and there are vertical rainbow lines on the left side of the screen. the majority of the screen is white/blank
I hate to tell you but your screen is busted, there is no way to fix it.
If I answered your question correctly please dont forget to rate my performance.
Mar 25, 2011 | Cell Phones
The moniter blacked out, blue light is saying the moniter is still on, but screen looks like there is no power. When you turn on the moniter, the screen shows up for a few seconds, then blacks out again!...
Unplug power. Unplug VGA cable. Remove back of monitor. (four small Philips headed screws along the bottom rear. Remove screws attaching Monitor to it's base. Carefully, lean the screen away from back of case. Gently unplug 25 pin cable from the screen.
Connect AC power.
Screen should power on Gray to White. Ble light comes on Blue.Flickers then changes to Amber.
Reconnect VGA cable. Monitor should work.
Close up the monitor in reverse order to opening it.
If these steps don't solve your monitor, consider replacing as cost of repairs may shock you.
Sep 09, 2010 | Proview PL926WBi 19" LCD Monitor
Screen prob with Hitachi 51UWX20B red square
Maybe the best way to adjust the screen is with the manual magic focus..instead of letting the tv do the auto change it to manual and see if you can adjust the convergence yourself. I have this same model and once in the manual adjustment you want to make sure you see all white lines....if you seen any blue or red that is the color that needs to be moved towards the white line closest.
Once you think you have it lined up nicely hit "exit" on your remote and option 1....
Hope this helps you.
May 05, 2009 | Hitachi 51UWX20B 51" Rear Projection...
50V500 ONLY
GHOST: May be described as "Out of Convergence" but ghost is still attached to main image.
A "ghost image" appearing to the left or right of images in the picture. Can be varying shades of a primary color (red, green, or blue) as well as gray. Can easily be seen in the 4 x 3 mode, at the edges of the picture.
To correct the problem, please do as follows:
  1. Access I2C Menu. (See page 57 of the Service Manual).
  1. To enter the I2C Service Menu, with power off, (on the front control panel) press and hold the INPUT button. Then press the POWER button for two seconds. The following Service Menu will appear.
03b_ghost_image01.gif Figure 1
  • Be sure to press SELECT after each change to SAVE the new Data.
  1. Using the Remote Control joy stick, scroll down to next page (see Figure 2) until LCD ADJUST is highlighted.
03b_ghost_image02.gif Figure 2
  1. Move the joy stick to the right to cursor right once. The next page will appear with the word GHOST highlighted.
  2. Cursor right again, and a white screen will appear with a BLACK SQUARE in the center, as in Figure 3. You will see LCD ADJUST, followed by “SHP” and a number (value).
Figure 3
  1. If the unit is out of adjustment, you will see a gray ghost on either side of the black square. Move the joystick to the right or to the left until the ghost disappears. The number values will change up or down.
    • If the ghost adjustment is off with a lower value, there will be a ghost to the left of the square.
    • If the ghost adjustment is off with a higher value, there will be a ghost to the right of the square.
  2. Once you get the square to look good without ghosts, press "SELECT" to save any data values that have been changed.
  3. Press the "EXIT" button three times to return to normal picture.
  4. Adjustment is completed
Jul 26, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Vertical line on LCD screen
hi unfortunately you'll have to replace the lcd display
Aug 09, 2007 | HP Compaq nc6000 Notebook
KDS Radius RAD-5 15 in. Flat Panel LCD Monitor Logo
76 people viewed this question
Top KDS Computers & Internet Experts
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
