Question about Garden
TRANSMISSION LOOSES PULLING POWER AFTER WARNING UP
AFTER MOWING FOR ABOUT 30-45 MIN MOWER LOOSES PULLING POWER NEED TO KNOW WHERE FILL PLUG IS AND TYPE FLUID TO USE OLDER MODEL AROUND 1999-2002 Same here on Hayter Heritage ST42... I've seen elsewhere posts about purging the air out of the system ???
Didn't understand it though and I am hoping for a idiots guide to how to do this.......
    Sergeant:
    Champion:
  • 226 Answers
The first step is to replace the air filter you'd be suprisied.then the fuel filter .take a test run after that.hope this helps
Posted on Jun 09, 2009
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Clutch adjustment for engaging dec
You clutch is probably OK. This sounds like some binding in the mowing deck.
  1. Take off the deck.
  2. Clean the underside of the mowing deck.
  3. Remove the belt and be sure all the moving parts move freely. If something is bound, try to free it up with oil.
  4. Replace any bound up bearings. Bearing are a very high maintenance item on a mowing deck.
Good luck.
Apr 05, 2015 | Garden
I have a Husqvarna YTH24K48 mower, it barely moves forward, but does good in reverse, any suggestions?
Might be that you need to bleed the tranny. Or perhaps the tranny has an internal problem. Following are some general notes. Go to the websites and review the tranny instructions.
The Huskvarna YTH150 uses Hydrogear transmission 319-0650, drive model 150071. One place to find parts and diagrams is here:http://www.m-and-d.com/Hydro-Gear_parts....
Hydrostatic Transmission Fluid is actually 10W-50 synthetic motor oil (like mobil). Do not use hydraulic fluid or transmission fluid.
Hydro static transmissions on most lawn tractors are very similar. Most of them are made by one or two manufacturers. Tuff Torq makes a lot of them. They definitely make all the John Deere lawn tractor hydro drives. The lawn tractor manufacturers (like JD) often say they are sealed and not serviceable. That is flat out, a lie. All of the JD hydros, and most all others, are serviceable. A complete line of rebuild/replacement parts can be found at Tuff Torq. Info and instructions can be found there. It's quite likely they made your tranny too.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like mobil). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black plug on the top. You have to remove the tranny from the mower (not a difficult things to do, takes about 30 min). Pull that black plug and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out, clean it and replace it. It may fall out while the tranny is upside down. When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
Sep 15, 2014 | Husqvarna Garden
Snapper mower
valves overheating needs valve job as mover over heats its looses power until it shuts down
Aug 24, 2014 | Snapper Garden
Why is my John Deere LA 150 not pulling hills after 40 minutes of mowing
I have an LA145. I do a bit of commercial mowing with this mower. Sounds like tranny problems developing, if the growling noise is coming from the back under your seat. Tranny problems need immediate attention if you want to save the tranny.
Additionally, I have found that the mower manufacturers fill them (or spec them) with motor oil, 10W-30W. In the service manual, and at the hydro manufacturer, you are told if your tractor is used in extreme or heavy duty situations it's best to drain the oil and replace it with 10W-50 synthetic motor oil (like mobil). Truth is the tranny should have this oil from the get go. It will give you more power and extend the life of the tranny. The mower manufacturers are all just being cheap. John Deere fills them with 10W-30. They figure why not, you're the one who has to pay for the early failure. Oh yeah, one other minor detail, the tranny manufacturer also recommends regular oil changes, like every 100 hours.
Virtually all of these trannys have a black plug on the top. You have to remove the tranny from the mower (not a difficult things to do, takes about 30 min). Pull that black plug (I use a flat blade screw driver to pry them up) and turn the tranny upside down for about 30 min to completely drain. Most hold about 2 quarts. Flip it back, right side up, and refill. Install plug and reinstall tranny. Note: under the plug there is often a magnet which collects metal shavings. Lift this magnet out while you have the plug out, clean it and replace it. It may fall out while the tranny is upside down. When you refill the fluid just keep filling till it comes up within a quarter inch of the plug. You may have to go through a bleed process after reinstalling the tranny. The tuff torq site explains the bleed process.
May 10, 2014 | John Deere Garden
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Pto shuts off durning mowing
hook up a test light so you can see if it looses power when it shuts off
May 14, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
I replaced the blades on my Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 by tipping it on it's side and now the mower looses power when going up the smallest incline? I bled the air out...
Not the float.
Where you mowing when you had the problem or were you just driving the mower? If you were mowing, then disengage blades and see if it returns to full driving power. If you were just driving, then with it sitting, engage the blades and see if problem recurs. The blades are the bigger load on the engine, your mower will drive around with a little 4HP engine, all the extra power is for the blades and if pulling anything.
Let me know what the test results were, so we can figure out if it is in the carburetor or not.
Aug 12, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
My mower has an automatic transmission. after 20 min of mowing it slows to a stop. i dont know how long until itll work again. i just try the next day
Mine loses the ability to climb the slightest grade, and it is a failing hydrostatic transmission. Yours most likely the same problem. Find out the model and part number of the transmission, you may find it cheap on ebay. They are very expensive to buy thru a dealer, more than the value of the entire mower.
Jun 20, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Unfortunately, but I'm not 100% sure on your model, it is a sealed transmission. I have had the same problem on an lgt2654 husqvarna and the service center just ordered a new transmission to replace the faulty one. Fortunately it is warranted for two years and I'm covered. Curiously though the service center suggested that this unit, even though advertised as a garden tractor with all kinds of pictures of attachements, is not meant for moderate to heavy usage. i.e. pulling a lawn sweeper or yard cart full of dirt. I most definetely will re think my next purchase! Good Luck
May 05, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
214 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
