Question about Whirlpool GHW9400SU Front Load Stacked Washer / Dryer
Water Not Comming To Dishwasher Stater Light Flashing
  • 234 Answers
The problem is most likely the water inlet valve. This is a solenoid that opens when there is power to it. It is a common problem on dishwashers and washing machines.
They are not very expensive and are usually fairly easy to replace.
If you need more help, post a comment.
Thanks,
Tim
Posted on May 29, 2009
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Indesit dishwasher IDL505 green light flashing water not entering the machine
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Aug 27, 2010 | Indesit 24 in. IDL500 Built-In Dishwasher
Some lights are flushing and the dishwasher does
If the clean light is flashing it is an indication of the water not heating up. I have attached a link to a sheet explaining what might be causing it and how to reset the control so you can use the dishwasher again.
Clean light flashing
If other lights than the clean light are flashing that is an indication there is a short circuit in the keypad control and that part would need replaced. Let me know if you need details on replacing that. If so I would need the complete model number from the tag on the dishwasher just inside the door.
May 02, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
When I start the dishwasher it seems like the motor hums,water comes on but then it stops. When I open the door the control panel is flashing pots and pans and heavy when I had selected normal for the...
Pl refer user manual. In general flashing light may mean : no water flow, salt chamber empty, door not closed etc. It all depends on the error code message designed.assigned by the manufacturer.
Apr 30, 2010 | Viking DFUD142D Built-in Dishwasher
I have a 2005 cr250 and its got no spark
the cdi is the best bet but get a test light and have someone kick the bike over while you see if the stater has power comming out of it the stater is on the left crank case cover you will see the wires comming out of the cover but the cdis go out a lot more often than the stater with the bike being a 05 its a 90% shot
Jun 28, 2009 | 2005 Honda CR 250 R
Flashing green light on my indesit dishwasher
Put some towels dowm and tip the dishwasher over to one side about 45 degrees, if water pours out of the base it means that the dishwasher is in "flood mode" and you have a leak into the base that will need resolving.
Thanks
Dec 05, 2008 | Indesit 24 in. D61 Free-standing...
Dishlex 450
I had this problem and reset the dishwasher to solve. Turn off dishwasher for at least 20 seconds, turn on while pressing eco button and wait for about 30 seconds. Should hear beeps.
May 05, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Mieli water-intake light comming on?
I think it's regular salt, yes, but I've never bothered to fill mine.
Have you had a dishwasher previously? If not, check the tap where your washer gets its water to make sure it has proper water preasure. If the washer doesn't get enough water it will stop.
In my kitchen there is a separate little knob on the tap to control the water to the dishwasher. this has to be open. Mine has hot and cold selection, but only cold is connected so if I turn it on hot the washer gets no water
Nov 07, 2007 | Dishwashers
Whirlpool GHW9400SU Front Load Stacked Washer / Dryer Logo
55 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
