Question about Refrigerators
The freezer is working fine but the refridgerator is not cool enough
The freezer on my kenmore side by side is working fine bu t the refidgerator is not cool enough.
Sounds like your frig is not defrosting. Locate defrost timer and start manually. If that solves the problem, replace defrost timer. Another possibility is that the evaporater fan in the freezer compartment is not working. Both items easy to replace.
Posted on May 10, 2009
Refidgerator side is warm freezer still working but not defrosting
Your model refrigerator has a 241508001 Defrost Control Board
found as part listed as location 23 HERE
and is the most likely cause for your refrigerator not defrosting. The other causes can be the 5303918255 Defrost Heater
instructions on testing can also be found on the same page as the defrost heater. The last part to cause defrost failure is the=> 5303918214 Defrost Thermostat
Item 14 is the defrost heater and item 21 is the defrost the
rmostat and can be found in the photo found on this page HERE
Let me know what you find so I can answer your questions, Thanks Sea Breeze
Oct 04, 2012 | Kenmore Side by Side Refrigerator
I have a kenmore elite coldspot side by side refridgerator and it is not cold enough on the fridge side. How can i fix this?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 08, 2011 | Kenmore 56983 Side by Side Refrigerator
My freezer works fine but refridgerator is wont get very cold
If freezer is frosting up, check fan. if fan is not working in fridge the freezer will ice up and the fridge will not get cool air.
Feb 09, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My kenmore elite freezer works but the refrigerator is not cooling
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Kenmore 53642 / 53644 Side by Side...
Freezer seems to be working fine, but the refridgerator is cool at best with the thermostat all the way down. I tried to defrost, but with no help. I think the fan in the freezer might be bad.
The only place that cools in a refrigerator is the freezer. The refridgerator side stills cold from the freezer via an air duct that runs from the freezer to the refridgerator. If your fan in the freezer compartment is not working your refridgerator side will not work. To replace the fan you will need to clean out the freezer including the shelving. Then remove the back panel all you need is a phillips screw driver. When the back is replaced the fan is at the top. It is held in by two screws that go threw rubber mounts on the fan braces. You will need to remove one ground wire and two electric wires on the motor its self. Make sure to unplug the refrigerator before starting the repair. good luck
Aug 28, 2010 | Kenmore Refrigerators
Kenmore Refridgerator Freezer Condensation
When I observed this issue, I found the freezer not running the defrost cycle enough times, (maybe this was in the spirit of conserving energy Energy Star compliant???))
If the Defrost is working, use the diagnostic test, that may be all you need to do until the next build up of frost on the coils.
Aug 17, 2009 | Kenmore Refrigerators
Kenmore model 50503990 not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fsfj
Jun 09, 2009 | Kenmore 57029 Side by Side Refrigerator
Refridgerator problem
Not sure about your model, but most of these style side by side refridgerators use the cold air from the freezer to cool the refridgerator. Sounds like your "flapper" valve is broken. At the top left in the refridgerator there should be plastic shroud. Remove it and your flapper valve should be under it. You will most likely find the flap broken off of it. You may have success using epoxy to glue it or you may have to replace the valve assembly.
Good luck.
Apr 20, 2009 | Frigidaire FRS26H5AS Side by Side...
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
