Question about Epson Stylus Color 880i InkJet Printer
Epson Stylus Ink Jet Printer
All led lights are flashing when I turn printer on. These lights will not go out. The ink cartridges are new and the printer was printing prior to this problem.I'm assuming there may be an eternal problem. Has any one experience this problem before?
1. Turn printer off
2. Press the left 2 buttons down and continue holding them down while turning the power button on. (all 3 are now pressed down)
3. In 3 or 4 seconds, the paper feed (jam) LED light begins to flash. (middle button)
4. Within 3 seconds as the paper feed button LED still flashes, release all 3 buttons together and immediately press down the ink cleaning button (left) and continue to hold down for about 10 - 20 seconds. As soon as the cleaning docking button LED flash, release it. That's it! You are now reset and ready to go.
NOTE: This is a strict timimg procedure and must be done fairly precisely in order for it to work. It may require several attempts for it to work for you. But...it does work! Happy printing!
Posted on Mar 21, 2008
Printer reports out of Light Magenta ink even after new cartridge installed.
discovered recently that printer cartridges have a use by date on them, and that if you use it the printer will not recognise it, only answer is to insert a new one, or ignore the printer ( l have a by-pass function on mine so still use it until l am ready to replace the offending cartridge
Jan 30, 2013 | Epson Stylus Pro 9900 - 44" large-format -...
Hello. My Epson Stylus CX 4200 now flashes the letter E and all the lights flash, including "error." How do I get it working again?
here's what you can do:-disconnect the printer from the computer-turn off the printer-inspect for anything foreign inside like jammed paper-turn the power back on-remove the ink cartridge-check the chip connnector at ink tank and at head carriage. If its dirty clean it with soft moist cloth. -check the status monitor. which ink tank not recognized. -press ink light (1-4 times) depends on number ink tank not recognized, press 1 time again, carriage will move co replacement position, unplug and plug again all ink tank, press ink light 1 more.
if that doesn't work, replace ink cartridge ONLY if you have a spare. DO NOT BUY new ink as the printer is bound for repair.
Nov 13, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
It won't print after installation of new ink jet
Here's a link to the Epson printer troubleshooting guide...if this helps; please indicate so.
http://er.epson.com:8001/start
Nov 10, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
How do i install my new ink cartridges in my printer epsom
Be sure you have a new ink cartridge before you begin. Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
  1. Make sure the EPSON Stylus CX5400 is turned on and not printing. The LCD screen tells you which ink cartridge is low or empty.
  2. If your EPSON Stylus CX5400 is low on ink, press the left Menu button until you see Change Cartridge, then press the Color Copy button.
    If your EPSON Stylus CX5400 is out of ink, press the Color Copy button.
    The ink cartridges move to the replacement position.
  4. Lift up the scanner.
  6. Pinch the tabs on the front and back of the cartridge, lift it out of the printer, and dispose of it carefully.
  8. Before you remove the new cartridge from its package, shake it four or five times.
  10. Unwrap the new ink cartridge and lower it into its holder, then press down on the top of the cartridge until it clicks in place.
  11. Caution: Don't touch the green circuit board on the back of the cartridge; you may inhibit normal operation and printing.
    If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7.
  12. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
  13. The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on.
    Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX hasn't moved or made noise for more than 5 minutes.
Oct 27, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus photo R230 Desktop : Printer icon flashing with exclaimation mark `No Ink` changed Black Ink cartridge in printer , Red & Green lights on not flashing Please help.. how do you know which...
go to the printer setting under control panel, right click on the icon then properties..you can check the ink level there...normally if your printer blinks and ask for a new cartridge..better follow what the printer says... : >
Aug 31, 2009 | Epson Stylus Photo R300 InkJet Printer
The red light on my epson printer wont turn off and it wont print,ive changed both ink cartridges and still no change.
Hi
Which button has the red light or which LED light? Is it flashing or steady red light? turn it off and check for any obstruction and double check if you installed ink cartridges properly.
Hope this helps
May 13, 2009 | Epson Stylus C40UX InkJet Printer
I am trying to put new ink cartridges ito the epson stylus ns400 series epson ink jet printer. how do I do that?
Hold the ink button down for 3 seconds, the carriage unit will move out to allow you to change the cartridge
Gremlin11
Dec 13, 2008 | Epson Stylus NX400 InkJet Printer
Epson stylus cx5400 reset???
try doing this :
Reclamping the Ink Cartridges
Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
if the issue still persists - you need to call the vendor - it´s a hardware issue
Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus Color 880i InkJet Printer Logo
96 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
