S-ATA Hard Disk not detect
I have a Hard Disk : Barracuda 7200.10 - 250 GB S-ATA. How to install it to my computer? Because the bios NOT detect it. My Computer Spec.is: BIOS : AMIBIOS 080009 Ver: 1011.003 BIOS Date : 11/17/05 14:36:24 Ver: 08.00.09 P-ATA Hard Disk : 1. Master Drive - Maxtor 6E040L0 - 40 GB : 2. Slave Drive - Barracuda ST380011A - 80 GB Memory Module : DIMM-1 (256 MB) DIMM-2 (512 MB) Total: 768 MB Motherboard : P4P800S-X Chipset Model : 82865G/PE/P, 82848P DRAM Controller / Host-Hub Interface Processor : Intel(R) Pentium(R) 4 CPU 2.40GHz Bus Speed : 533 MHz L2 Cache Size : 1 MB L2 Cache Speed : 2.4 GHz Thank you, Joajo-Bandung
  • morinet May 15, 2009
    If I have any spare time, I will try. Thank you very much on your suggestion.
    -morinet -
    Sergeant:
  • 186 Answers
Hi Dear,
You have to update your BIOS. If you have intel mother board just go thought their website and download BIOS Flash utility of your particular Board and Update BIOS.
The above fix will surely solved your problem.I had same problem as you and it's now fixed.
Posted on May 11, 2009
My hardisck no deteck in my PC
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 09, 2013 | Seagate Barracuda 7200.12 500 GB 7200RPM...
I want to detect driver Thanks
There is _NO_ need for any additional device-driver -- Windows "natively" supports all disk-drives.
Dec 17, 2010 | Seagate Barracuda 7200.10 ST3160815A -...
Have a barracuda ATA 120 gb that came out of a computer with a fried motherboard. how to externally get info off the hard drive ?
You need an expert to do that. The expert must have the exact same board to swap with the burnt board. If the power did not affect the disk, you may recover the data on the disk.
Aug 12, 2010 | Seagate Barracuda ATA V (ST320013A) 20 GB...
Hard disk ST9120822AS ATA Device
If the computer cannot Bootup with an error message that hard drive nor detected or no boot device then you could have a faulty hard disk.
Go into the BIOS configuration and see if the BIOS detects the hard disk. If it is not detected then it is probably faulty.
Next reset the ATA data cable on the hard drive and at the motherboard. Bootup the computer again, also check the BIOS configuration again to see if it detects the hard drive.
If it still does not find the hard drive then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port. If this computer does not detect it as an external hard drive then this proves the hard drive is faulty.
To get your computer working again, replace the hard drive and install Windows together with the device drivers and your programs.
Nov 06, 2009 | Dell InspironTM 1501 Notebook
Firmware update for Seagate Barracuda 7200 10 80 gb ultra ATA. I got problem due to firmware detection. the firmware on the Hard disk said it going with type 3.AAC, but when I try to open with Sea tool, it...
Dear FixYa team,
Thx for your kind offering to me. I already call my friend to help me here. And he seems already found the solution. The problem was comes from USB cable malfuction, and I think it somehow affect the firmware detection. Gladly he can back up it again with another harddisk, just try to baiting it to make the firmware read. Now I'm still waiting for data recovery only. I'm so sorry that I can't use ur helps now, coz I needed it in hurry. Thx
Regards,
Angeliczone
Jun 26, 2009 | Seagate Barracuda 7200.10 - 80GB - 7200rpm...
My bios doesn't recognize my hard drive
Do the neccesary jumper cable settings. then manually detect it through your bios. If not detected, try to replace the ide cable. if still not detected, try to feel the hard drive if it spins, if not, the had drive is damage.
Mar 03, 2009 | Seagate Barracuda 7200.7 200 GB Hard Drive
Barracuda 7200.7 be used with NTFS drive?
Yes, it can be used that way. Do you already have an operating system installed on your first drive?
Disk can be formatted after installing operating system on the first disk or prior to installation if you intend to install the operating system on this disk.
Jan 16, 2009 | Seagate Barracuda 7200.7 ST380011A 80 GB...
What to do with unreadable but recognised hard disk segate 400GB
After data is recovered, it should be moved to another drive to keep safe. The drive that was recovered has to be reformatted and checked for errors before storing more data.
Nov 28, 2008 | Seagate Barracuda 7200.7 160GB 7200rpm...
Seagate Barracuda 7200.7 ST380011A "a disk read error occured"
Might be a damaged sector. Otherwise i would think you (by accident) created a seperate partition on your C:\ (? main) HD. The cause of damage can be many things, certain types of certain brands or more sensitive in how fast these sectors get damaged. But you can at least try to repair them with the disk repair utility in Win XP, called ChkDsk ("check disk"). However, what may end up happening is that ChkDsk will mark the sector as bad (instead of attempting to recover any information) and your hard drive will no longer 'hover' over top of that area of the drive, making it impossible to recover any data on the sector. Maybe try to google for (free) BETTER third party software for this first. So what caused it is hard to discover after it happened, but you can try to repair it.
Nov 05, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
New hard drive 160 GB ATA can't be partitioned
why dont you try 40000 in the first partitioned..if doesn't work.. try fix your hard drive using a seatools, a bootable disk, that can detect and repair a bad sector for a hard drive..
Feb 26, 2008 | Computers & Internet
Computers & Internet Logo
563 people viewed this question
David Payne
David Payne
