Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
Weed eater featherlite primer bulb won't fill with gas. it does not appear to be broken and fuel line is clear and filter is new. any ideas?
  • nicklauer May 11, 2009
    i think it was the small teeny weeny screen (fuel filter) that is part of the carburetor body. i did not even know it was there. i thought the only fuel filter was in the gas tank. i studied a parts breakdown and discovered it. i think we are going again.
    thanks.
  • 246 Answers
Hello
From your Description and Depending on the OEM (Zama or Walbro) of the Carburetor it Sounds like a Bad Fuel Filter or the Primer Check Valve has Stuck and the Carburetor Requires Soaking and Cleaning.
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://www.poulanpro.com/poulanpro/indexAction.do?id=default and Select Order Parts and Accessories. On this Page Select Illustrated Parts List from the Menu on the Left. Now Select the Manufacturer (Poulan/Weed Eater) and Enter the Model Numbers in the Boxes at the Lower Left of the Page.
I Require the OEM (Walbro, Zama, ect) and the Model Numbers Off the Carburetor. With these I can Locate a Breakdown of the Carburetor and Better Assist you.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
  • John C Bridgers Sr May 11, 2009
    Hello nicklauer:
    I am Glad you Located the Internal Filter. Many People do Not Know that it is in the Carburetor. Im Glad I was Able to Assit you. Have a Nice and Wonderful Life. As Always, May the All Mighty Bless you and Yours. Till Next Time. May all you Mechanical Problems be SMALL Ones.
    Best Wishes and Good Luck
    Respectfully
    jbridger (John)
Weed Eater GTI 19T
If it's the one that comes 'out' of the primer bulb it is the return line that goes in the fuel tank.
Aug 07, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Primer bulb not filling
Bulb or fuel line could have a crack or a clog in fuel line/filter or carburetor. Here's a video on how to change the bulb and fuel lines and another video on how to clean/rebuild the carburetor.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
May 02, 2014 | Homelite Mighty Lite Lawn Trimmer
Hi curtis, i have a craftsman 32cc bushwacker weed eater. i had to replace fuel line in tank with filter. i also replaced the second line in the tank which is alittle larger in diamiter. i have a primer...
change the fuel lines over on the carby
you are trying to feed fuel through the primer line when the engine is running and that is why it is cutting out
Mar 12, 2017 | Garden
Repair weed eater
If you see gas in the primer bulb it is pulling in gas to the bulb. If not check for cracks in the bulb assembly and check to see if the fuel lines are not off their fittings and not cracked.
Jul 17, 2013 | Garden
A relative has a weed eater featherlite 20c and thr primer bulb doesnt keep gas in it,is it supposed to?and if so what is the cause?And it want stay running unless u keep it running wide open.Why is that?
The machine is having a fuel delivery issue The purge/primer bulb PULLS fuel from the fuel tank, thru the carb and then to itself it pull any air/old fuel in the carb...and the PUSHES this mixture back to the fuel tank. There are check valves in carbs that have the bulb on them..Deteriorated fuel lines clog a screen in the carb and the ethanol in the gas works to deteriorate the fuel pump and metering diaghram in these carbs...You have to start at the tank with the fuel filter and go from there.
I'd say from the running symptons that a diaghram kit is needed for the carb...they are cheap and easily installed.
Aug 12, 2010 | Garden
Weed eater wont start
If you haven't changed fuel filter in awhile, do that as well.
look here...
Aug 01, 2010 | Craftsman 25cc Gas Line Trimmer
Replaced gas tank and primer bulb on my Poulan Leafblower FL1500 and it appears I'm not getting gas into the carb. Any ideas as to what my be the cause?
I assume the new tank came with new fuel lines and filter in it.
First be sure you have all the lines hooked up correctly. There should be a main line from the tank ( has the fuel line on the end of it in the tank) to the fuel pump side of the carb. Then there should be a line leaving the metering side of the carb to the primer bulb then from the primer bulb returning to the tank. When you press the primer bulb you should see it **** the fuel into the carb then from the carb into the primer bulb then back into the tank.
If the fuel lines are all hooked up correctly then you should rebuild the carb.
Jan 02, 2010 | Poulan Featherlite Gas Blower, with Low...
Weed Eater Lightweight 1500 Leaf Blower Fuel Line Repair. There is something in my gas tank, which I assume is a filter of some sort and I need help getting one replaced and onto which fuel line it should...
there are two lines going into the tank one is short which just goes in the for pressure from the primer bulb the other line goes to the filter which goes to the carburator
Itsman
Nov 03, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Where do you put the line from the gas tank I have A mcCulloch weedeater the tank have two lines it all so have A primer
One line is a return line short, the other is connected to the filter and to the carb fuel intake. The primer bulb will not fill if they are reversed.
Oct 11, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
I am trying to repair the fuel intake on a featherlite weed eater
replaced fuel lines on sear weedeater and primer button still acts like it is suching against a vacume. push it in and it won`t release. this unit in same as my featherlite carb and tank. What do I look for line are not restricted, but car not drawing fuel?????
Jul 08, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
4,117 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
