Central air seems to be working fine except for the outside unit fan stays on all the time. The line to the outside compressor also drips condensation from the furnace all along the basement to the outside wall.
  • 10 more comments
  • r54ick May 10, 2009
    Yes the line has insulation, and yes the outside coil is clean
    The inside coil seems fine.
    Thanks.
    Yes , the outside unit never shuts off.
    Yes the inside unit shuts off when the proper temperature is reached.
    When I turn off the air at the thermostat,the outside fan stays on. To get it to shut off I have to shut off the main a/c power at the box.
  • r54ick May 11, 2009
    Where exactly would the contactor be located??
  • Robert Moller
    Robert Moller May 11, 2010
    The contactor is in the electrical control box located inside the outdoor unit. Becareful as this has 220V. a safer test would be to remove the thermostat and expose the wiring, then remove the wire going to the (Y) terminal and see if the unit stops.
  • Robert Moller
    You may have a thermostat problem. Does the inside unit shut off when temperature is reached ?
  • Robert Moller
    You say the outdoor unit never shuts ?
  • Robert Moller
    How is the inside coil ?
  • Robert Moller
    That line should have a rubber tex insulation around it. Also is the coil clean ?
  • 148 Answers
Alot of humidity in the basement will cause the dripping need dehumidifier
Posted on May 10, 2009
  • Jason vangel May 11, 2009
    contactor in the condensor outside is stuck
Problem with GE PTAC-Model# AZ28E09DABM2 - Why won't condenser kick on when switching to AC from Fan. AC was working fine until today...Fan is still working...Pulled the unit out and could feel the h
Hummm. A bit difficult to solve this problem. Seems like the condenser outside is not working, I mean the fan of the condenser. Looks like you have a wall A/C and a wall A/C always have condensers outside the house and near the A/C. Have you checked if the fan is spinning? I don't think the compressor is at fault but check it anyway. You should be able to hear the compressor running either in the wall unit or in the outside condenser housing. The only heat you should feel is from the condenser itself. If you blows warm air, that means the fan is working, if not that means the fan is not working. But don't be confused with the fan not working because in winter time sometimes the fan is not working and some times it does. As I said, it's a difficult problem to solve but at least start with checking the situation with the fan in the condenser.
Jun 16, 2014 | GE Zoneline Deluxe Series Cooling &...
Water dripping from unit need to access drip tray and drain pipe on indoor unit
It sounds like you have a central a/c that has part of the system, the compressor, condenser coil and fan outside on the ground, and the rest inside. The inside part, the evap coil, normally uses the same circulating fan as the heater. If this is the case, then locate your heater access and you should find the evap coil and its drip pan in the duct work.
Jul 13, 2011 | Heating & Cooling
Outside temp was 113, the compressor stoped fan stayed on.Only hot air. Latter in the day compressor and fan worked fine. Should I be concerned ? Thank Mike duo therm 13500 .no heater
It just got so hot that the unit kicked out on high head pressure...
Check the outside condenser coil for dirt... wash it out with soap and water so that you can get maximum air flow through it...
Air Conditioning - Cleaning the Condenser Coil
heatman101
Sep 28, 2010 | Dometic Rooftop RV Air Conditioner
Goodman central air conditioner not blowing normally
It sounds like the compressor is not coming on in the outside unit. If it worked fine and was cooling before, then your compressor probably over-heated and tripped the internal overload switch which causes it to stay off while everything else is working. The most common cause of your compressor over heating is an incorrect refrigerant charge, though it could be a few other things like a restriction in the copper line set. You will be able to hear the fan motor and the compressor kick on if you listen close while the system first turns on. If the compressor is over-heated, then after it cools to a save temperature, it will come on again, but only till it over-heats again. I would have the charge checked on the system, but remember that if the compressor is over-heated when the technician gets there, there is nothing he can do until it cools down and time is money! It's best to not run it until the problem gets figured out. Hope this helps and points you in the right direction. Good luck!
Jul 17, 2010 | Heating & Cooling
My conditioner wont work. When i turn in on heat comes out.. What should i do>?
Do you have central air? If so put the fan on auto turn AC to lowest setting fan should come on in a minute if not go outside to your condenser unit check for ice building up on the compressor or any of the copper lines if it is you need refrigerant. If not you may need to blow out the condenser with an air compressor or shut off power hose it out. Also, look for broken wires. If all else fails call your local service Provider.
Jul 28, 2009 | Honeywell Heating & Cooling
My colmen central air unit is not working properly. The Outside unit is not working. The problem initally arouse in June, but it "self corrected" after having the A/C unit turned off. Since that...
If nothing is running outside at times you probably have a weak contactor coil that is not pulling the contactor in all the time. If the outside fan comes on but not the compressor, the compressor is over heating and shutting off on overload protection. This could be a dirty condenser coil, low on refrigerant, the compressor it's self. The compressor comes with a 5 yr. warranty.
Sep 27, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
