Try to check your network signal if it's stable or dropping,also try to transfer your simcard to other phone and see if the problem is still the same.try check the settings of your network if you are using 3g or dual mode or only gsm mode,sometimes dual mode signal is not consistent by going to settings > phone > network and set it to gsm mode.
another way is formatting or resetting your phone,back up all necessary data first before proceeding,on your home screen type *#7370#, a lock code will be ask.enter the desire code or 12345 as the default code,then it will reboot automatically.Now try the signal if its ok.
If the above method doesn't work,might be a hardware problem and let a mobile service technician fix this problem,so you can find out what particular problem takes place.
Friend you can unlock your phone online. just go to
www.nokia-calculator.com. on the site select your phone model then
enter your imei. then press calculate. Once given the code enter it on
your phone and it will unlock.automaticaly. good luck friend.
hi im josh in cebu phils.friend may i help you? your problem is weak signal. friend when the phone is weak signal there maybe a problem in hardware of the phone. the frequency reciever is weak im sure.but you can boost its functions throught entering the setting and go to network settings and select manual search.your phone frequency will search the network connections around so the hardware will be force to boost.once it will show the network providers around you select the network you are using and it will be setted to the network in more/ higher frquencyh signal. thats all friend hope i helped you.good luck/
first of all insert the memory card in your phone then open the memory card through the file manager.Then remove it and connect it to the pc through the card reader.Copy all the software to the Others folder. Insert the memory card once again and switsh on the phone .Go through the file manager and open the others folder of your card. There you will find the copied softwares .Just click on it and it will guide you through the installation
In this situation it really is a matter of how much damage was done, most cell phone warranties do not cover water damage unless you pay an additional monthly fee. In this case there is probably no saving the phone. I would refer back to your provider and see if a replacement phone can be rendered to you.
