Question about Lexmark X5495 Printer
Lexmark x5495 won't power on, i have checked cord and outlet.
My Lexmark x5495 will not power on. we had an electrical storm and the next morring the printer wouldn't come on. It looks like there are three red lights on in the bottom of it.
  • 30 Answers
Replace the mother board of the printer and that is the only way your printer can work very well again
Posted on May 21, 2009
My Lexmark X5630 does not switch on, what can I do?
1 Press to turn the printer off. 2 Disconnect the power cord from the wall outlet. 3 Gently remove the power supply from the printer. 4 Reconnect the power supply to the printer. 5 Plug the power cord into the wall outlet. 6 Press to turn the printer on.
Make sure the cord on the back of the printer is pushed all the way into the socket, it should only fit one way. If that fails, check that there is power at the outlet you are using.
Sep 08, 2017 | Miscellaneous
Cartridge error 1203
Remove the print cartridges, and close the cartridge carrier lids.
Disconnect the power cord from the electrical outlet.
Reconnect the power cord to the electrical outlet.
If the power button button is not lit, press power button.
Reinsert the print cartridges.
If the error does not reappear, the problem has been corrected.
If the problem reappears, one of the cartridges is not working properly. Continue with the following procedure to determine which cartridge is not working properly.
Reinsert the black (or photo) print cartridge.
Oct 14, 2013 | Lexmark International Lexmark 7100 Series
My printer wont turn on
If you are encountering power problems with your printer, please go through the following checklist:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Jan 22, 2012 | Lexmark X5495 Printer
I cannot get my Lexmark 5600-6500 to turn on
Try to unplug the power adapter from the printer.
Then unplug the power cord from the power outlet. Wait at least 10 seconds before re-plugging the power cord into the power outlet in the wall (bypass any power strip) and the power adapter into the printer. This will give enough time for the printer to reset itself. If printer won't automatically turn on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Jun 28, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have the telephone/computer line but can't find electrical ?
If you're missing the power cord for the Lexmark printer, I suggest you contact Lexmark Technical Support for assistance. You can request for that and they can send you one for free. Hope this helps.
Jun 02, 2010 | Lexmark X5495 All-in-One &USB...
My lexmark prints things out PINK - it says there is an alignment problem, but I cant fix it
Hi, try removing the cartridges from the printer. Clean the nozzles of the carts using a damp paper towel first, then finish it using dry paper towel to wipe it off clean. Unplug the power cord from the power outlet. Plug power after 10-15 seconds. Reinsert the cartridges. Make sure the cartridges are secured in the carrier. Hope this helps.
Mar 07, 2010 | Lexmark X5495 Printer
INSTALLING LEXMARK X5495 SOFTWARE. WHEN I GET TO
Make sur ethe usb is pluged in adn the printer is on. If your computer is not detectingthe printer restart the computer, if all else fails try another usb port.
please rate.
Aug 22, 2009 | Lexmark X5495 All-in-One &USB...
Lexmark X5495 Will Not Power On.
Connect the printer directly to the wall outlet without using the surge protector if it still does not work then either your power cable is spoilt or your printer has died.
May 30, 2009 | Lexmark X5495 Printer
Power cord
you can get one at radio shack or ebay, model # on ebay 12V
Jan 05, 2009 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 6350
SolutionStep one: Perform a power reset and connect the printer directly into the electrical outlet Remove all the paper loaded in the main input tray.
Make sure that the product is turned off.
Disconnect the USB cable from the back of the product.
Disconnect the power cord from the product.
Disconnect the power cord from the electrical outlet and wait 10 seconds.
Reconnect the power cord directly into the electrical outlet and check for the following.
Make sure that the power cord used is the one provided with the product.
If a computer is connected to the product, make sure that the computer is connected to a grounded (three-prong) wall outlet.
Make sure that the power cord is firmly connected to both the product and the power supply.
Reconnect the power cord to the back of the product.
Press the power button ( ) to turn on the product.
Reconnect the USB cable to the back of the product.
If the issue is resolved, proceed to Step six: Print a self-test page.
If the issue continues, proceed to the next step.
for more information please go to below link>>
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458822&cc=us&lc=en&dlc=en
Thanks for using FixYa.
Jun 01, 2008 | Lexmark P6350 All-In-One InkJet Printer
Lexmark X5495 Printer Logo
205 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
