Question about GE Refrigerators
Refridgerator making consistent clicking noise in the back. unable to locate why.
GE Refridgerator is making a clicking noise from the back and I can not locate what it is or why it is doing it. Refridgerator and Freezer are still working at this time.
  • 1,543 Answers
Get yourself a new motherboard. You will need it soon.
Posted on May 10, 2009
Refridgerator has started making a noise. It stops when I open the refridgerator door and then starts again when I close the door.
It's your evaporator fan that is either hitting frost build up or bearing in motor is bad. If blade is hitting frost, you may have a defrost circuitry problem or door gasket problem
Jul 31, 2015 | GE GBS22HCP Bottom Freezer Refrigerator
GE Side by Side is not cooling refridgerator or
if turbo fans not running then the evaporators probably froze up and wont cool at all unplug and replace turbo fan and make sure u let the unit thaw completely i recommend atleast24 hours and turn back on and make sure turbo fan is running and u should be fine
Feb 24, 2010 | GE Profile¿ Arctica® Energy...
The compressor is not running and there is a clicking noise coming from the circuit board panel on the back of the refridgerator
You have to replace the main control board . The clicking is the compressor board relay , which the only repair , is to replace the main board .
Sep 11, 2009 | GE Refrigerators
Very loud clicking noise from my LG LSC26905TT refridgerator
first you have to remove all shelves in the freezer,then remove all screws in the interior rear panel. In some cases you'll have to remove a couple of shelf tabe located on the side wall. Once tha panel is removed,the fan will be in plain sight. The blade is usually aboue 4-5 inches in diameter and is attached to a small motor with 2 wires and a green grounding wire. Note: you might want to check why it's making noise. Is there ice built up around the blades?Are you getting too much moisture entering the box thru faulty door gaskets?
Aug 26, 2009 | LG LSC26905TT Side by Side Refrigerator
Not cooling at all
refridgerator not cooling making clicking noise from back
May 03, 2009 | GE Profile Stainless Bottom-Freezer...
GE Refridgerator leaking
it is possibe the inlet to the drain line may be plugged.The defrost water cannot run down the drain line to the pan on on the bottom.Also make sure it is level
Apr 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Sep 08, 2008 | GE GSH22SGRSS Side by Side Refrigerator
Refridgerator
IF THE BUZZING SOUND IS ONLY THERE WHEN THE MOTOR IS RUNNING THAT COULD MEAN ONLY ONE THING.YOUR PISTON IN SIDE THE COMPRESSOR IS NOISEY THE ONLY WAY TO SOLVE THAT IS TO REPLACE THE COMPRESSOR.BEST YOU HAVE A TECH TO ADVICE YOU FUTHER.GOODLUCK.MOHAMED
Jul 21, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
203 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
