Question about Dell OPTIPLEX GX1 PIII-667MHz 128MB 10GB (DELLP3667) PC Desktop
Need help with startin pc.
I opened up my computer to see wat was inside, i touched the memor and evcerthing when the computer was off, adn now it does'nt start. If i get a a peice of metal and touch the start button from the inside the light comes on and the fan starts to work but then goes off again. Pls Help
    Habit-Forming:
  • 188 Answers
Ur start button is not working man....
change it emidiatly...may be it is damage.... ok
im sure ur prob is solved...
best regards & best of luck..
Posted on Oct 12, 2007
Hello, I have a PDA Datalogic Memor. It was working flawlessly, but now it asks to enter the name of the driver for this PC card and I think because of this, the WiFi is not working anymore. i tried hard...
I trust you have seen this FIXYA Link:
Datalogic KYMAN reset Questions
It deals with a 'hard reset' (that you have already tried) but there is other info in that Link that may be of help to you?
IF all else fails here is a Link for repair service (I KNOW ~ I KNOW)...
http://www.datalogic.com/eng/products/healthcare-retail-other-solutions/mobile-computers/memor-x3-pd-636.html#service
Dec 14, 2017 | Datalogic Memor Pocket PC
I have a black screen on my pioneer avh-p400dvd, all of the touch functions work, i have two of these decks and just memorized where the touch function were, need help if possible
mcdevito75 here, Monitor could be burned out, check all functions specially bright / dark, bring monitor to Staples, Best buy for testing.
Jun 25, 2010 | Pioneer AVH-P4000DVD Monitor
Moved my computer to another room and when starting up the monitor has no power. I tried changing cords and outlets and still no power. Is this the end of the line?
It may have been coincident. For a 4 years old monitor, the power supply may have failed.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Gateway monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 20, 2010 | Gateway FPD1950
How do you replace the harddrive
replacing a hard drive is very easy all you need to do is open your computer case and swap out the old one for a new one you just unplug the 2 wires from the old one and plug them into the new one. Attached I have added a link to a how to guide.
http://www.ehow.com/how_4424308_replace-hard-drive-computer.html
I hope this helped
Thank you,
Norse
May 18, 2010 | Gateway 300 C PC Desktop
PSC 1210 ALL IN ONE WILL NOT CONNECT TO MY NEW DELL INSPIRON WITH WINDOWS 7 . IT SAYS THEREIS A COMPATABILITY ISSUE?
drivers are no available on website for win 7. wat you can do you can directly connect ur pritner to computer with usb cable you will se message found new hardware. installing device drivers. after some time it will show you message device is ready to use. then click on start. go to start search adn type pritners. then hit enter. it will open pritners windows.
in that window click on add a pritner on top. then select add a local pritner. then it will says select existing port select usb vertual pritner port and hit next. then under manufacturer select hewlett adn packard and under prtiner select psc 1200 series prtiner and hit next. do not share this pritner follow onscreen instruction to finish add a pritner wizard.
Dec 16, 2009 | HP PSC 1210 All-In-One InkJet Printer
DISBLED I POD TOUCH
Hi, I have understood this question to mean that you wish to sync it with your computer. If this is correct then please follow the procedure below:
1. Connect iPod to computer and open iTunes 2. It will ask you whether it should sync it with the new computer removing all old data. Click Yes if you want to replace the content on the iPod from your iTunes library otherwise click No and proceed to next step. 3. If you want to keep the data then enable the check box Manually Manage Music and Movies 4. Click Apply
If the device has a passcode lock then you will need to restore ipod to its factory settings. This option too is on the main page of your device settings showing within itunes.
Jul 15, 2009 | Apple iPod touch
My touch pad wont work
Are you running linux?? do you know how to use linux?
Open a terminal and as root type: nano /etc/X11/xorg.conf or type: sudo nano /etc/X11/xorg.conf if your not root user.
You should be able to find the line that says shmconfig and change it to true.
save the file and restart the computer.
Jun 16, 2009 | Acer Aspire 4530-5889 Notebook PC
Acer E360 doesn't turn on, only a long beep, nothing on screen.
ok ill tell u wats wrong, one of the hardware needed to start up the computer is damaged... wat you do find out what motherboard is inside and look up the beep sequences and see whats wrong with it.... REMEMBER: the beep means error XD jst look the motherboard up
Jun 14, 2009 | Acer Aspire E360 PC Desktop
Can i copy my mp3's to my ipod touch or do i need to chack it?
Open itunes and go to file-> add folder to library or add file to library adn add your music then sync your ipod with itunes.
Feb 19, 2009 | Apple iPod touch
Computer does not turn on, since i opened it
Not to worry...As you can see this is just a loose contact....Since you seem like a novice user attempting to fix it yourself is not advisable.Just get someone who knows electronics to fix it for you...
And one more thing dont touch any part inside the computer with bare hands.Walking on a dry floor will charge your body to a static voltage of upto 5000v and is more than enough to damage the motherboard...
For now just get someone to fix that power cable for you!
Oct 12, 2007 | Dell OPTIPLEX GX1 PIII-667MHz 128MB 10GB...
Dell OPTIPLEX GX1 PIII-667MHz 128MB 10GB (DELLP3667) PC Desktop Logo
26 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
