Question about Sport & Outdoor - Others
I need O-ring and seal for a homemade log splitter using an MTD cylinder. model:240-640A serial:J039A
Where they can.
Posted on Jun 16, 2009
  • salducci Jun 16, 2009
    good auto parts stores can match and confirm replacement seals for you
  • 122 Answers
Local tractor supply store might be able too help ya on that,cross reference the number and find ya a match
Posted on May 11, 2009
Early '90s mtd 20 ton log splitter developed a hydraulic fluid leak where the valve assembly connects to the piston housing. Leak is between hex nut and piston body. Suggestions...
2 possible answers
hydraulic washers in use have a steel surround with a rubber insert which acts a a seal
the rubber seals off and the steel stops hydraulic pressure from pushing it out of place
or the there is a crack in the thread where the hex nut is
get a new washer from a hydraulic shop and if that doesn't fix it, you may have to get a new valve body
discuss the problem when you are at the hydraulic shop for more ideas
Dec 30, 2016 | Cars & Trucks
I have a 45 ton Grudge Log splitter. the ram works but has no power to split logs.
indicates insufficient pressure from the pump
bypass at the ram/piston seals---seals or scored cylinder
have it checked by a hydraulic specialist
Nov 12, 2016 | Tools & Hardware - Others
Log splitter won't return to start position
well it's a complete guess due to fact you didn't mention model or mfg or even a photo , but most log splitters have a auto return tripper device this should activate ,either a switch or hydraulic lever to reverse the flow of oil from the cylinder after a log is split , some models even use large springs to force the cylinder back into its sleeve after it extends out , I guess springs could break ? this would be easy to clearly see with a close visual inspection
May 07, 2015 | Garden
How do I change the seal in a 22 ton Huskee log splitter?
Picture of the cylinder my help, I have had different hydraulic cylinders apart. I don't know which one they put on a Huskee.
Feb 27, 2015 | Cars & Trucks
I have a Delta Log Splitter model 38610C which needs an O-Ring oil seal for the Dip Stick. Delta no longer has the part. Is there any other supplier I could check out?
Take the dip stick to your local hardware store and find an O-ring that fits the diameter of the stick. They are cheep enough to get a few with cross sections of different sizes and use the one that fits snug when you put the dipstick back in.
Sep 01, 2013 | Garden
Trying to find a Throttle replacement part for Log splitter MTD Tucumseh HS50
Hi Karen,
You might try www.jackssmallengine.com and search by MTD-you'll need some serial/model numbers but they tell you where to find them.  It did list one MTD logsplitter.  Good luck! Nancy
Nov 17, 2010 | Sport & Outdoor - Others
I need a manual for an mtd log splitter. model #24BF552B729. please help. thanks
First things first. Your splitter has been recalled because of a limb amputation problem. If your splitter has not been repaired, you need to call this number. Firm's Recall Hotline: (888) 848-6038
If your splitter has been repaired, this web site should have everything you need.
http://www.mowerpartsweb.com
Here is the parts manual
http://www.mowerpartsweb.com/MANUALS/MTD/769-04973.PDF
Aug 10, 2010 | Computers & Internet
How to take off front hydraulic cylinder cap to
TURN THE NUT WITH A PIPE WRENCH AND USE A PICK TO PRY THE REST OF THE RETAINER RING OUT OF THE SLOT. (YOU CAN LOOK INTO THIS SLOT A YOU TURN THE NUT, MAKING SURE THAT YOU HAVE ALL OF IT OUT. AFTER THIS IS DONE THE NUT CAN BE TAPPED OR PRIED OUT. I PREFER USING A BRASS PUNCH TO KNOCK IT OUT.
Nov 16, 2009 | Heavy Machinery
Sport & Outdoor - Others Logo
153 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
