When search for device then its showinhg there is no available device
SOURCE: Nokia 6102i will not detect my BH-600
Hey I found the solution :
1. When the headset is off, press and hold the multifunction key until the indicator light is continuously displayed.
2. Switch on your compatible phone.
3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
4. Select the headset from the list of
found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone.
In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
If the pairing is successful, the indicator light starts to flash slowly, and the headset appears in the phone menu where you can view the currently paired Bluetooth devices.
The headset is now ready for use.
Enjoy..
Pavan
SOURCE: Bluetooth headset Nokia BH-600
You just have to press your blutooth on/off button a bit longer for 15 to 20 sec, when the LED blinking stops (noted that the LED should be turn ON but not blinking), try to search the device again with your phone. By that time your blutooth headset should be recognized by your phone, then select and enter the code 0000.
SOURCE: i have nokia bh-100 bluetooth headset, i tried
Start with the headset turned off, and the bluetooth radio of the device you want to pair the headset to, turned on. Then, press and hold the headset's power button until the led flashes rapidly. It is indicating is in pairing mode. Now, make your device search for new devices, and select the BH-100 from the list. If a passkey (or PIN, or pairing code) is requested, enter '0000' (four zeros).
If your headset's user guide happens to be missing, download it from this location, if you want.
Hope it works for you.
Cheers!
Carlos
SOURCE: Nokia BH-213 unable to Pired with Nokia E-63,it stopped suddenly
I also experienced the same problem. After trial and error I realized that the bluetooth device needs to be reset to fix this issue.You may reset the bluetooth device by deleting the pairings from the headset or reseting the headset. Switch off the headset, and press and hold the multifunction key for over 8 seconds. Start pairing the device again. It should work fine now with default passkey 0000
SOURCE: Got a New Nokia BH-106 bluetooth Headset, i'm
i purchase new Nokia bluetooth headset BH-106 and i want to connect my laptop ( Dell INsprion N5010) plzz give some advise who to connect it.
