Question about Toshiba 27A32 27" TV
Tv would not turn on and it makes a clicking sound constinuously.
Tv model 27a32. when open up tv it makes clicking sound like when just turn on or off the tv,but does not turn on.
  • Toshiba Master
  • 19,396 Answers
The TV is on protect mode. The clicking sound is the protection switch that keep turning the TV off to prevent further damage, this happens when a fault had been detected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 15, 2009
WHAT IT THE PROBLEM FOOR FAILING TO SWITH ON FROM STANDBY MODE
Have you tried to switch it on with the channel +/- buttons on the TV itself ? If this works, the batteries in your remote are dead. If it does not, then you have an electronic problem in the TV. Need a service-technician.
Jun 15, 2014 | Toshiba 27A32 27" TV
How to switch from TV to DVD on a Toshiba Model 27A32 when you do not have the remote control for the TV
Without its remote control, you can't select its inputs. Even some universal remote controls won't allow you to select this option. If you wish to buy a genuine remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have set-up codes to your TV brand, adn buy that one according to availability. If you wish to get more details about this, try the sites linked here. It has set-up code list, and set-up procedure to many popular brand universal remote controls. http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Dec 26, 2013 | Toshiba 27A32 27" TV
When I plug in my tv it makes a clicking sound like it wants to turn on but it can't. After i plug it in it won't turn on after I press the power button
Sounds like a deffinate power supply issue, if you open the TV, there is likely a bulging capacitor on the power supply. Even if not a obvious capacitor problem, the Power board is likely the culprit.
Can buy new one on many websites, or used on ebay.
make sure you buy based on the part # listed on the board, and not by the model number of your TV, as there are usually many sub-models that all have different interior parts, and most are not capatable with eachother.
Jun 07, 2011 | Proscan Televison & Video
How to program a replacement remote
toshiba tv that" s kind tv easily to get & install remote control in rca brand. just follow inside instruction step by step to try each code# in front of your tv. good luck!
Jun 05, 2011 | Toshiba 27A32 27" TV
Lost the remote for my toshiba tv model 27a32, need the model number to replace the remote (prefer to get a toshiba remote rather than a universal)
The model number will be on the back of the tv. You'll have a model number serial number and a few other numbers. But for the price of a factory remote you can get a really nice universal....
Dec 07, 2010 | Toshiba 27A32 27" TV
Will not come on it only a clicking sound from part no. 0mron 0584H3
I had the same problem with my tv, same make and model. I first continuously turn on and off my tv manually until I could get some kind of picture. This procedure took maybe five minutes. I was able to get a fine picture and sound, as if it was brand new! Other things to keep in mind, try to eliminate dust build up as much as possible.. Hope this helps out...
May 21, 2009 | Philips Magnavox 27MS343S 27" TV
Zenith TV won't turn on
Not really a solution but i have the problem with mine< opened it up and it's part number 38-102 or ex3401 which appears to be a open fuse by the AC in on the board. When I bridged the open, melted gap it turned on, smoked, and melted again with a spark so be that as it may there's got to be something going on here that can't be too hard to fix but the repair man will make more on the sale of a new tv than fixing the old.
Jul 12, 2008 | Zenith Z36H96R 36" TV
Toshiba 27A32 27" TV Logo
256 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
