Question about Lexmark X4550 Multifunction Wireless Color Inkjet Printer
I changed both cartides but color will not work ore register
I changed both cartridges but color cartridge will not work and is not registrated in the printer
  • stig33 May 15, 2009
    Yes but I solved it another way. I just bought an new cartridge and that one work perfectly.
    Problem Solver:
  • 5 Answers
Make sure that the cartridge name or number is exactly the same cartridge that you you have removed from the printer because if its not the exact type it will realy not recognise the cartridge
or you might as well did not install properly the cartridge or you installed it wrongly for example you put the other color to another one it might be some cause but if its correct and still might not work there is a problem with the sensors or the software itself you might need to replace the component that was placed in the homing section of your printer and the circuit board that covers the cartridge in the homing section or you just have to clean the sensors
Posted on May 15, 2009
  • greylance May 15, 2009
    make sure that the cartridge name or number is exactly the same cartridge that you you have removed from the printer because if its not the exact type it will realy not recognise the cartridge
HAVE COLOR PLANE REGISTRATION ISSUES WITH THE HP CP1215. HAVE CALIBERATED BUT NO CHANGE
Sounds like you have a defective cartridge. Replace that cartridge and retry.
Mar 12, 2014 | HP LaserJet CP1215 Color Printer
Canon lbp5050 printer out-of-Register Colors Correction Error
So your mean is changing of all 4 cartridges istead of charging them Krishnan ? Do you have an experience with compatible cartridges or you say they must be replaced with 4 new original cartridges ?
Oct 22, 2012 | Canon I-Sensys Lbp5050 Laser Printer
My porinter can not recognised color cartide
have you recently changed the cartridges?
have you bought the original cartridges for the printer? compatiable cartridges have tendency not to work very well with printer so its always best to buy the original cartridges to avoid any headache.
once installed you might want to run the head cleaning program for the printer just to make sure that the heads are working fine and then a test sheet so the are not smudges or lines.
hope this helps
Jun 11, 2011 | Canon Office Equipment & Supplies
Yellow and Magenta do not register when I print colour jobs. Other colours register perfectly. What shall I do?
It seems your color cartridge have issue try changing the color cartridge or clean the head cartridge head and try.
Regards,
JJ
May 13, 2011 | Sharp AR-C260M All-In-One Printer
My printer ricoh 3260c is not registering and when I do the auto registration the yellow is still not registering
Sounds like you have a registration problem.!
Please try the fallowing.
First, please remove all print cartridges and power of unit. (Completly disconnecting the power source).
Next, please clean with worm water and a tissue ( Q-Tips ) the cartridge area ( Print heads ).
Next, please wipe the cartridge base unit you see alittle ink on the tissue. ( again with worm water and tissue or Q-Tips. )
Now, with cartridges removed, please power on unit and wait for error messages.
Next, please install print cartridges, one at a time and see if the unit comes back.
When both are installed, the unit should see that they have been removed and will ask you to aline cartridges.
Hope this works out for you.
Please rate kindly
Happy Holiday's
John
Dec 07, 2009 | Office Equipment & Supplies
I have a HP LaserJet 1320tn, after I changed the cartridge I keep getting paper jams just about where the paper meets the cartridge
Hi if you says that the paper gets jam at the fuser meeting point than i m sure that registration assembly which register the paper with toner cartridge is not working properly this is internal hardware fault.
It may caused due to faulty pickup assembly too.
There is a small **** manual feed tray try to print using manual feed and check if the problem persists then registration assembly is faulty if the it print fine from manual feed than Tray 2 pickup assembly or pickup roller is faulty.
Jun 29, 2009 | HP LaserJet 1320 Printer
Changing cartridges
A few things...
make sure all of the tape and adhesive from the packaging has been removed. Newer printers use a small chip or other such thing to sense things like ink levels and whether you bought their OEM cartridge.
After you've done that, make sure the cartridge is seated properly in the printer when you put it back in.
If it's a third party cartridge, it may not have been manufactured right and the printer won't register that it's there.
Lastly, did you try running through the cartridge replacement procedure WITH the printer? sometimes they won't register a new cartridge until they register that you took the old one out they way it likes.
Let me know if this works, otherwise we can continue to troubleshoot.
Jan 05, 2009 | Lexmark X5150 All-In-One InkJet Printer
Color Registration Error - BCU Received no Feedback from LD
I have had a problem like this before and had to replace the black pcu.
Dec 15, 2008 | Ricoh Aficio CL2000N Laser Printer
HP2600n color printing not registering
Looks like theres a problem with the color ragistration.
I would calibrate the printer. Heres how;
  1. Go to "System Setup" on the display. Press Select.
  2. Go to "Print Quality". Press Select.
  3. Go to "Calibrate Color". Press Select.
  4. Go to "Calibrate Now''. Press Select.
  5. Press Select again to confirm Calibrate Now.
This will calibrate the printer and should eliminate the color registration problem you are having.
Nov 11, 2008 | HP Color LaserJet 2600n Printer
Black Ink Cartridge error
i ended up putting a color and black cartridge in and everything is fine.
Mar 27, 2008 | Lexmark X2500 All-In-One Printer
Lexmark X4550 Multifunction Wireless Color Inkjet Printer Logo
85 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
