Question about GE Profile PSI23SGR Arctica¿ CustomStyle 22.6 cu ft Side-by-Side Refrigerator
WR30X10093 Icemaker problems
I just replaced my WR30X10093 Icemaker because it overfills the tray and the ice sticks together in the pan. The new icemaker does the same thing. Can someone please advise? I cannot find a manual for this icemaker.
  • Larry Colson May 10, 2009
    I have made an adjustment 1 full turn - and did not see any difference. Should i keep turning 1 full turn at a time or do you suggest less?
    Guru:
  • 1,524 Answers
Remove the white plastic cover. Upper right screw sideways with + and - on the head. This is the fill adjustment.
Posted on May 10, 2009
  • Robert Moller
    Robert Moller May 10, 2009
    No give it a chance.
Ice maker overfills the ice tray, ejecting large block of ice instead of individual cubes.
What is your model number? Sounds like you may need a new icemaker. Sometimes when the icemaker motor goes bad it causes the icemaker to keep filling even though it hasn't kicked out the ice in there. Also, are you sure there isn't 2 valves on the refrigerator?
Nov 15, 2015 | Refrigerators
I have a GE Profile fridge PSS25MGNAWW with an ice maker that is not working properly. The ice maker doesnt fill with water. If I turn the ice maker off then back on it will squirt water in for about...
HI this is just a test the icemaker runs when you first turn it on, its not suppose to fill up the tray, it will fill it when the icemaker reaches the correct temperature, if its not cold enough in the freezer it wont kick on, if its been sitting for several hours and still wont fill or make ice, you need a new icemaker. The new icemaker part # is WR30X10093
Sean
Mar 30, 2011 | GE Freezers
I just replaced the icemaker in my Kenmore Refrigerator with the WR30X10093 Kit that fits many other models of refrigerators also. The water slightly overfills the ice tray and freezes the cubes together...
Congratulations, you have very good water pressure. I am not aware of any adjustment for the time the fill solenoid opens. The easiest thing I can suggest is to adjust the water flow with the supply valve. If you have the typical saddle valve, it has quite a taper to the piercing needle, and you could possibly use that to reduce the water flow, thus the volume of the fill. A little trial and error will be needed to find the right number of turns for the valve to be opened. I also recommend a water filter in the line to reduce contaminants, which makes the ice taste better. The filter should be replaced every 6-months or so depending on the amount of impurities.
Feb 13, 2010 | Kenmore Refrigerators
Icemaker water overflows into freezer
the condensate tube is run incorrectly on this model and goes uphill into the area above the refrigerator where there is a condensate pan. This will plug and back up and cause this problem. I have fixed ours several times but it always came back. The last time I bought a new clear plastic tube and reran the condensate out the back of the refrigerator and down through my floor. It's all downhill now and seems to have fixed the problem.
Nov 28, 2009 | GE Monogram ZISx420DR 42-inch Side by Side...
Ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Jul 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Have Amana side-by-side about 14 yrs old. The icemaker overfills ice tray by about 8oz of water? Please help!
Unless someone has made a water level adjustment there is,
Only one repair. Replace the ice maker.
If someone has made a water level adjustment you can try this.
Remove the ice maker plastic cover. Locate the water level screw adjust it to a minimum setting and try it there.
If that does not correct the problem, replace the ice maker.
May 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
Mar 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice box
In the LG side by sides they have developed a new ice cup tray. The tray has a little wall so that the water stays in the tray and doesn't go onto all of the ice causes it to stick together.
part number is 3390JA1150A
Sgt 48
Feb 08, 2008 | LG LRSC26920TT Side by Side Refrigerator
Ice Maker overflow
my icemaker overfill can you help
Oct 31, 2007 | Refrigerators
Refrigerators Logo
1,341 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
