I need to find out if my bins can continue to cope with my ageing eyes, how can I tell how much dioptre correction the bins are capable of? (i.e. is the poorer view my eyes needing more powerful bins or bins out of adjustment)
SOURCE: How to focus my Zeiss 10x40B TP binoculars
Your binoculars are known as the Zeiss Classic or what was once known as the Dialyt. They focus differently from the usual binoculars like those mentioned. The rear wheel is to focus both binocular barrels while using them. The front focus wheel is adjust the right eyepiece to suit your right eye. Binocular manufacturers take into account each eye is slightly different. To focus the Dialyt...First close your right eye and turn the rear wheel until the image is sharp in the left barrel. Leave the focus wheel alone. Now close left eye and adjust the front wheel until the image is sharp for your right eye. The image should now be clear and in focus for both eyes. It should not be needed to use the front wheel from now on. The rear wheel is what you will use to change the focus from near to far objects.
SOURCE: one eye or the other seems slightly out of focus.
Hi, one of your eyepieces has an twisty eye piece, its printed on the outside + & -, probably the right side? If its the right side you close your left eye and focus with your right, then open both & HEY Presto, you've got vision in both! Thanks Mark
SOURCE: My Zeiss bioculars will NOT
The focusing gear that revolves is either broken or off-track, most likely. The unit will have to be serviced and will probably require a part or two to get it working correctly. Go to the following webpage to get some advice and help from Zeiss:
http://www.zeiss.com/ebird
Good luck, and hope this helps.
