Question about HP Compaq ProLiant ML530 Server
ML530 Startup My Compaq ML530 server gives me two options when booting as 1- Press "F1" key to continue 2- "F10" key for System Partition Utilities The problem is that the server stop the booting process at this menu and I have to manually press F1 to complete the starting phase. Please could you help me to avoid this options Thanks, Bernardo
  • 3 Answers
Evidently your bios is not configured correctly. Get a copy of the user's mannual, from the mfgr., for proper set-up.
Posted on Sep 19, 2012
Yep the solution to this for me was to make sure the secondary power supply was plugged in. Look at the screen before you hit F1 and see what errors are on the screen the computer thinks is important enough that it thinks you need to see prior to booting.
Posted on Dec 09, 2007
Check your Hardware configuration.  This usually happens when you tell the system BIOS that you have for example, a second floppy or Hard Drive, when you do not.  So it stops and asks you what to do next.
Hope that helps.
Posted on Oct 16, 2007
Diskette 0 seek startup failure
restart your system and press delete to enter the bios mode and change the boot options set 1st boot device as cd/DVD rom and 2nd boot device as HDD if you are not using floppy drive just disable it. After finishing the changes press f10 to save the changes and exit
Feb 24, 2012 | Microsoft Windows Vista Home Premium with...
How to enter in bios to boot change sequence in ProLiant ML 530
Press F10 during post boot if you have smartstart installed in the partition. If not, you need to boot from SmartStart CD.
May 08, 2010 | HP Compaq ProLiant ML530 Server
I turn on my compaq and the first thing come on screen is CPU=AMD-K6(tm)/300 00000640K SYSTEM RAM PASSED 00064512K EXTENDED RAM PASSED 0512K CACHE SRAM MOUSE INITIALIZED FIXED DISK 0:FUJITSU...
above 06 lines are related with system information, Go to the BIOS check the startup sequence, if everything is ok save and exit from BIOS.
Apr 01, 2010 | Computers & Internet
Selecting booting device
Normally with the new laptops you have to press F2 to access your bios settings, you will definitely be able to select the boot device from there.
If F2 does not work startup your laptop and watch the screen, there must be an option that will tell you which key to press to enter bios.
If the screen comes and goes to fast for you, press the pause button on your keyboard so you can read it at your own time and do your actual selection.
Hope it helps.
Aug 29, 2009 | Microsoft EF1330255 Keyboard/Mouse
I cant install a new operating system into my HDD. My setup does not suportt boot from CD.
The Bios Settings need to be changed to boot from The ATAPI drive. When you turn on computer press the F2 or F1 or Delete button, sometimes its F10. Once you are in the bios setting look for boot devices. Follow the on screen instructions to change the boot order. I hope this helps.
Mar 30, 2009 | IBM NetVista PC Desktop
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
SCSI Devices not detected when posting ML530 Server.....
To get to the BIOS for your server, press F10 at start-up. This should get you there to verify if settings are detecting SCSI devices. If they are there, you may have to reinstall the SCSI controller drivers. Good Luck.
Jan 30, 2009 | HP Compaq ProLiant ML530 Server
Toshiba Satellite 1400
To Access the Bios Setup Utility Here Is A List Of Key Commands And The Make/Model They Are For..
Acer - Aspire, Power, Veriton, Extensa, Ferrari, TravelMate, Altos
  • Press Del or F2 immediately after powering on.
  • The BIOS on the Acer Altos 600 server uses the Ctrl+Alt+Esc key and the F1 key for advanced options.
  • Older Acer computers may use also use the F1 or Ctrl+Alt+Esc keys to access BIOS.
Compaq - Presario, Prolinea, Deskpro, Systempro, Portable
  • Press F10 while the cursor in the top right corner of the screen is blinking.
  • Older Compaq computers may use the F1, F2, F10, or Del key to give access to BIOS.
Dell - XPS, Dimension, Inspiron, Latitude. OptiPlex, Precision, Vostro
  • Press F2 when the Dell logo appears. Press every few seconds until the message Entering Setup appears.
  • Older Dell desktops and laptops may instead use Ctrl+Alt+Enter or Del to enter BIOS.
  • Older Dell laptops may use Fn+Esc or Fn+F1.
eMachines - eMonster, eTower, eOne, S-Series, T-Series
  • Press Tab or Del while the eMachine logo displays on screen.
  • Other eMachine computers may use F2 to enter BIOS.
Fujitsu - LifeBook, Esprimo, Amilo, Tablet, DeskPower
  • Press F2 once the Fujitsu logo appears.
Gateway - DX, FX, One, GM, GT, GX, Profile, Astro
  • Press the F1 key repeatedly after restarting the computer.
  • Some older Gateway computers use F2 to access the BIOS Setup utility.
Hewlett-Packard (HP) - Pavilion, TouchSmart, Vectra, OmniBook, Tablet
  • Press the F1 key after restarting the computer.
  • HP Tablet PCs may use F10 or F12.
  • Other HP computers may allow access to BIOS using the F2 or Esc keys.
  • Press F1 immediately after powering on the computer.
  • Older IBM computers (including some laptops) may utilize the F2 key for BIOS entry.
Lenovo (formerly IBM) - ThinkPad, IdeaPad, 3000 Series, ThinkCentre, ThinkStation
  • Press F1 or F2 after powering on the computer.
  • Older Lenovo products allow access to BIOS using Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1.
Micron (MPC Computers) - ClientPro, TransPort
  • Press F1, F2 or Del immediately after powering on the PC.
NEC - PowerMate, Versa, W-Series
  • Press F2 to enter the BIOS Setup.
Packard Bell - 8900 Series, 9000 Series, Pulsar, Platinum, EasyNote, imedia, iextreme
  • Press F1, F2, or Del to enter BIOS.
Sharp - Notebook Laptops, Actius UltraLite
  • Press F2 after the computer starts.
  • Some very old Sharp PCs require a Setup Diagnostics Disk to access BIOS.
Shuttle - Glamor G-Series, D'vo, Prima P2-Series, Workstation, X Mini XPC, Surveillance
  • Press F2 or Del on startup.
Sony - VAIO, PCG-Series, VGN-Series
  • Press F1, F2 or F3 after turning on the computer.
Toshiba - Portégé, Satellite, Tecra
  • Press F1 or Esc after powering on to access BIOS.
The following companies are either closed for business or no longer manufacture or support mainstream computers systems so verifying the following BIOS access information is nearly impossible. I have included what I could dig up for anyone who might be interested:
ARI / ALR / AST (Advantage) - Press the Ctrl+Alt+Esc or Ctrl+Alt+Del keys.
Cybermax - Press the Esc key.
Tandon - Press the Ctrl+Shift+Esc keys.
Good Luck and Hope it helps...
Jun 12, 2008 | Toshiba Satellite A35-S159 Notebook
Compaq Server ML530
I have a basic knoldge.....
Tell me ur problem..
Nov 18, 2007 | HP Compaq ProLiant ML530 Server
HP Compaq ProLiant ML530 Server Logo
667 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
