Question about Aeris Scuba Diving & Snorkeling
Aeris transmitter problem
Cant get connection with transmitter from my gt 750, i changed both bateris, put them in short distance, still the same
2 Suggested Answers
  • 3197 Answers
SOURCE: Remote transmitter stopped working, changed
There is no way to tell if you only have the one transmitter. If you have another remote or a wireless keypad that is working normally then it is that remote.
Posted on Jul 07, 2011
How do i ? ive a 2012 chery j11 and iam unable to find any info on how to program the keyless remote for it please help regards Dan
The Service Manual says this...
Remote Keyless Entry (RKE) Inoperative
No Response From Remote Keyless Entry (RKE) Transmitter
1. CHECK BATTERY
• Check battery of the RKE transmitter.
Is the battery voltage of the RKE transmitter normal?
Yes >> Go to the next step.
No >> This concern has been caused by the transmitter battery.
Go to step 4.
2. CHECK THE IGNITION LOCK CYLINDER CONDITION
• Check the ignition lock cylinder for proper operation.
Is the check result normal?
No >> Repair or replace the ignition lock cylinder key switch.
3. PERFORM THE RKE TRANSMITTER MATCH PROCEDURE
• Close all the doors.
• Insert the ignition key into the ignition switch which has lost synchronization in LOCK position.
• Press any button on the RKE transmitter within 5 seconds.
• Pull the ignition key out of the ignition switch.
• Try to operate the RKE transmitter.
Does the RKE transmitter operate properly?
Yes >> Erase all codes before returning the vehicle to the customer.
No >> Go to the next step.
4. PERFORM THE RKE TRANSMITTER MATCH WITH THE X-431
• Replace the RKE transmitter.
• Connect the X-431 scan tool to the Data Link Connector (DLC), press the POWER key to start the X-431 (use the most current software available).
• Turn ignition switch on.
? Enter the Diagnostic Program.
? Select Chery main program.
? Select diagnostic version.
? Enter download program.
? Select T11 series, and then select ISU.
? Select Remoter Match.
• Press the lock button on the RKE transmitter for less than 2 seconds.
• Pull out the ignition switch.
The concern was caused by the RKE transmitter.
No >> Replace the FBCM (See FBCM Removal & Installation in Section 15 Body & Accessories).
Refer to the RKE transmitter match procedure with X-431 as the description.
Perform match between the RKE transmitter and FBCM with X-431.
Best wishes from another Chery J11 owner.
You can download the entire service manual from the link below.
Kevin Mullen
Perth WA
Chery Tiggo 2009 Service Manual Page 1699
Nov 18, 2014 | Refrigerators
How do wireless headphones work
Wireless head phones works on principle of wireless technology.
The phone has a reciver and tv or Audio system has a transmitter ,.
WiFi/blue tooth are examples.
Feb 15, 2014 | Sony Audio Players & Recorders
Intermittent LOUD shorting sound
I would prefer to hear it to be sure which one it is, but the four biggest causes of noise in a wireless system are: 1) Something hitting the mic (check to make sure the mic is free of clothing, other people, faces, etc.) 2) If the mic is a lavalier or in some way has a cable that plugs into the transmitter, something pulling on it could create a loud noise. Check to make sure it's in snug. 3) RF Interference with another mic or some other interference source. Try changing the frequency. 4) Something blocking the signal between the transmitter antenna and the receiver antenna. This is most likely to happen with a lavalier in someone's pocket or under clothing, and/or if the transmitter is far away from the receiver. The SLX series is okay for what it is, but part of why it's on the cheaper side is because of its limited distance. Unfortunately the only ways to alleviate this are to a) Reduce the distance, b) get a stronger wireless system, c) move the transmitter somewhere that the antenna is free, and d) invest in True Diversity antennae for the receiver.
Sep 23, 2013 | Shure SLX4 Wireless Receiver with Antennas...
Fused Terminal Block on Refrigerator
  1. Signal Integrity
    • One benefit of using a terminal strip to connect the thermocouple wires is signal integrity. Since the thermocouple has a temperature probe located on the end of the wires, a signal must be sent from the probe to the thermocouple. The equipment and machinery will work intermittently, if the signal strength is not maintained. For example, if the probe senses the flame on the furnace, it sends a signal to the thermocouple. Once the flame goes out, a signal is sent to the thermocouple, which shuts off the gas.
    Shield
    • The terminal strips have a covering, or shield, to protect the thermocouple wires. You can open the strip and gain access to two metals for testing. You must cut off the insulation surrounding each metal wire and insert them into a terminal strip to make the proper connection. The cover protects those bare wires from dirt and debris. The cover can be removed when troubleshooting the thermocouple and wiring. Without the terminal strip, you would have to cut off each wire's insulation to test the signal strength and voltage between the probe and the thermocouple.
  2. Transmitter
    • A thermocouple sensor that has to carry signals over a long distance requires a thermocouple transmitter to strengthen the signal. Using terminal strips makes it easier to connect a transmitter to the thermocouple device. The terminal strips also lengthen the thermocouple wires. If you need to extend the distance from the probe to the thermocouple, you can add additional wires and splice them with terminal strips to increase the distance. It is like adding an extension cord to an outlet, so you can extend the distance between the outlet and the television.
    Connection
    • Another benefit of using a terminal strip is that the strip enables a better electrical connection between the two thermocouple wires. Without a terminal strip, you would have to introduce signal compensation metals for the thermocouple sensor to get an accurate temperature reading between the two metals. Since the terminal strip uses the same metals found in the thermocouple wires, your electrical connection will not lose voltage. A decrease in voltage can trip the thermocouple.
Jan 09, 2013 | Dryers
Remote transmitter stopped working, changed battery, reprogrammed opener and it works but now only at a very short distance - about 1 -2 feet. Is this a transmitter issue or the opener?
Jul 07, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have an acurite atomic wall / weather clock but the outside temperature is reading blank. I changed the batteries in the transmitter but still no reading. Where can I purchase a new transmitter. The...
I had one of these a while back and it had a required sequence for putting in the batteries. When the signal dies and you have to replace the transmitter batteries and the clock batteries in a certain sequence. The transmitter batteries cannot just be replaced. You also had to remove the clock batteries, then put in the transmitter batteries, then replace the clock batteries.
Dec 03, 2010 | SkyScan 86742 Digital Atomic Wall Clock
My Nuvi 750 has stopped talking, still shows the map but no voice
That has happened to me several times. When it happens I go to Tools > Settings > Language. In my case, the Voice field is empty, so I click on the Voice field and then select American English-Jill (TTS) and it's okay afterwards.
May 05, 2009 | Garmin (010-00583-00) for nuvi 750/760/770
Scuba Diving & Snorkeling Logo
105 people viewed this question
Top Aeris Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Aeris Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
