Question about Lexmark All-in-One Printer with PictBridge
Phone dialup-local phone service
I'm thinking about buying a lexmark can I fax with a dialup connect and just local calling?
    Problem Solver:
  • 15 Answers
You do not need a dial-up internet connection to use fax. All you need is a working phone line. Beyond that it works like a phone call (think of it as one fax machine calling another fax machine), so if your plan allows you to call locally only, then you can only fax locally as well. If you try to fax long distance, it may or may not work based on whether you can make a long distance phone call. Also, you will be charged for long distance calls if you fax long distance. These fees have nothing to do with Lexmark or whatever brand your fax machine is, it is the phone company that will charge you.
Posted on May 20, 2009
My fax machine is not sending faxes but will recieve faxes it copies the pages to send then dials but once it connects it drops the call and gives a error message on the screen then tries to redial a...
Reset all settings of fax to factory defaults.
For that press menu button of printer and enter in fax settings reset all settings to defaults.
Then restart printer.
Also change phone line cable Then check.
My chat session is disconnected because of power failure .
Let me know if you need further assistance.Thanks.
Nov 20, 2009 | Lexmark X8350 All-In-One InkJet Printer
Unable to receive fax data, i have it on auto anwser and fax mode. sender only gets ringtone. land line is connected to fax mach. please advise.
Test by sending fax to 1300 688 999. Results will be faxed back. Automated service. Cost of local call.
Ring your fax from your mobile when you are next to it and hear it ring and answer.
ADSL filters in place???
Nov 17, 2009 | Lexmark X5070 ALL-IN-ONE InkJet Printer
Can send but not receive faxes
Is that a USB connected Lexmark unit?
Apr 24, 2017 | Lexmark X6570 InkJet Printer
Can't Send Faxes
Can't really help you is you dont advise the printer model. Only thing I can ask is if the phone lines are connected or not as well as the power supply cable?
Nov 11, 2008 | Lexmark X4270 All-in-One Multifunction...
I have a Lexmark all in one printer, X5270, I cannot send or recieve fax's, so would you tell me what I need to do to fix this, as it is suppsed to do fax's. I have Qwest dsl hooked up and have an...
I have an "all in one" model X2580. I haven't attempted faxing, but I just looked up faxing in my user's manual and it appears we need a modem with fax capability to do this. Before reading the manual, I assumed it was done over the Internet.
Text from manual:
"Make Sure:
The printer is connected to a computer that is equipped with a fax modem.
The computer is connected to a working phone line.
Both the printer and the computer are turned on."
Having Quest DSL should not be a problem. but it won't help you.
If you don't have a fax capable modem in or attached to your computer, is one included in your answering machine that could be attached to your computer? If so, this could help. If not, you probably need to install either an internal or external 56K modem with fax. They are not expensive and if you're lucky, someone might give you one id they're changing their ISP from Dialup to DSL or Cable Modem.
I will ask a Lexmark person I have been in contact with recently, but I don't think this can be done over the Internet.
Aug 05, 2008 | Lexmark Office Equipment & Supplies
Uanble to call from Lexmark X4270
Have you tried to call out using the phone as a phone and not just faxing? Because the "unable to connect" voice is made by an operator or phone system, not your printer. Make sure that you are not running DSL over analog lines, on a digital phone system, or using IP phones. Fax machines will pick these high-frequency sounds up and it interferes with connectivity.
In the case of DSL at least I know there are line scrubbers you can buy. But in most cases the best bet is to run the FAX on a dedicated analog line.
Jul 06, 2008 | Lexmark X4270 All-In-One InkJet Printer
Sending Fax
set baud rate to 9600 or slow
set resolution to standard
set error correction mode (ECM) off
if fax has overseas mode turn it on
vonage can make changes to the line that could help, if your using a voice line with call waiting use *70 prior to the number to disable call waiting for that call
Dec 31, 2007 | Lexmark X125 All-In-One InkJet Printer
Need to know how to send fax's.
Your particular Lexmark X3350 does not have a fax modem. You have a couple different options though, however I am not sure if the option in the software you are using will be ungreyed, but you will be able to send faxes.
One option is to purchase a modem at a computer store (usually they are around $15) and install it. If you want to take this route then I would first check to see if your computer has room for one or sometimes I have found people already have one, and its just not installed. If you would like to take this route, respond and I will make detailed instructions on how to install for you.
Another option is to pay for a service to send & receive faxes for you. This is common, because as technology continiously increases everything is becoming more and more digital and people are shifting away from using real paper all of the time. For instance I built a service for a company a few years ago where they could fax whatever papers they wanted by sending an email to my program with the telephone number as the subject of the email and whatever they wanted to fax as an attachment. If you are interested in this alternative let me know, and I will suggest some third party services for you.
Regards,
-Chester
Dec 27, 2007 | Lexmark OfficeCenter X3350 All-in-One...
Lexmark All-in-One Printer with PictBridge Logo
175 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
