FixYa.com
Tags:
Unwired UFR650  2-Way Radio
What's the channel frequencies for a common 22...
posted by oliviayee on Oct 12, 2007
i would like to connect the motorola with icom. can you give me any site that displays the vhf frequencies table?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Oct 12, 2007
Thanks for Trying (70)
Bushwacker
Rank:Master Master
Rating: 81%, 11 votes
Not sure what you want.....VHF band ius approximatly 130mhz to 175 mhz..... in that VHF band there is a commercial VHF band aprox. 155 mhz to 175...... the amateur radio vhf band is aprox. 135 to 150mhz.
With amateur radio, any freq in that range can be used...... with commercial radio the FCC cangive a company any freq. in that range also.
If you are looking for FRS/GMRS frequencies they are UHF freqs not VHF.
So I'm not sure exactly what you want......sounds like you might want to program in FRS freqs into an Icom amateur radio. If thats  the case you will need an Icom that will do UHF freqs.
Rating Locked! (?) oliviayee has rated this solution as Thanks for Trying
Can you Help with these 2 Way Radios problems?
2 Way Radios
Columbia Walkie Talkies -...
I have been unable to locate... Answer This...
2 Way Radios
NO TX No RX
radio Powers up fine hit the... Answer This...
2 Way Radios
how to program
how to program Answer This...
2 Way Radios
about job
i want work as a o&m... Answer This...
2 Way Radios
midland GXT565 series gmrs/frs...
cant transmit or recive Answer This...
Repair Service
Find 2 Way Radio Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
