Question about Linksys WRT160N Wireless Router
Brand new linksys wireless, Host (Hard wired)has intermittent connectivity. Indicates it is conneted and is working properly.Cannot browse Web. The wireless part works great!
  • ridepie May 16, 2009
    My router gives good signal and is being picked up by my laptop as usual, but all of the sudden it will not let me run explorer/access the internet. No message comes up or anything. If I plug straight into my modem...no problem.
  • 41 Answers
Try to plug the Ethernet cord for the Host computer on another Ethernet port on the Linksys router.
have you tried replacing the Ethernet cable that's connecting the Host computer to the linksys router?
check if Host computer can get a response from a website by going to Start>Run, then type CMD on the Run box and click OK. On the black screen, type PING www.yahoo.com then press Enter.. if you get the word reply 4 times, it means the computer is connected to the Internet.
If there's no response from the PING test, it means there's totally no connection.
It's also possible the problem is with the Local Area Network adapter or Ethernet adapter. Try disabling the Ethernet adapter and re-enable it by going to Start>Control Panel>Network Connections, you should see the Local Area Connection, right click on it then select Disable then Enable it again. then observe if you're still experiencing intermittent connection on the Host computer.
and if you have security software, try disabling it temporarily and check the connection again.
and let's make sure the cable or dsl modem is connected to the Internet port on the back of the Linksys router.
Posted on May 10, 2009
Usb light link
HP LaserJet 1022 is a "host-based" printer so it must be connected to a PC. Load the driver on PC first and connect the USB cable when software tells you to do so.
Will not work on a Linksys print server.
LaserJet 1022N & LaserJet 1022NW have "special" HP print servers that can support HP host based printers.
Nov 27, 2013 | Linksys Wireless-G WPS54GU2 Print Server
Linsky router has been connected for a year and working fine but within the past 24 hours even though the signal is strong for connection it will not permit us to go wireless on the laptop or son's XBOX...
can you access the Linksys page while on wireless even if it gives you page cannot be displayed error when you browse?
try to do a hard reset on the router and reconfigure your wireless connection. just press the reset button for 10 seconds to reset it properly.
Jan 27, 2011 | Linksys Wireless-G Broadband Router
I have to reset (unplug power, wait 10 secs, then plug back in) a lot to have internet access. The router is recognized and it says that I am connected, however it also says that I have no internet...
There are lots of factor why you have that kind of problem when it comes to your router. Before following the steps in this, check if your computer has a stable Internet connection when connected directly to your broadband modem. If you do not have a stable Internet connection with your modem, kindly contact your Internet Service Provider (ISP).
May I know what is the model and version of your Linksys router?
If you run into Intermittent Wired Connections Using a Router:
Step1: Enabling MTU on the Router
- Access the router's web-based setup page.
- Open a web browser such as Internet Explorer.
- Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
- A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
- NOTE: If the password of the router has been changed, type the router's new password in the Password field instead.
Step2: When the router's web-based setup page appears, look for MTU and set it to Manual. Enter the MTU value of your Internet connection in the Size field.
1468. The size DHCP or cable providers prefer.
1400. Maximum size for DSL.
Step3: Save settings.
If you run into Intermittent Wireless Connections Using a Router:
Check if your wireless computers have stable connection when connected to other wireless networks.
Regular wireless disconnection can be caused by different factors such as:
> Wireless interference within the network.
> Wireless settings of the Linksys router are still set to default.
> Firmware is corrupted.
NOTE: If the procedure does not work, needs to update the router
Nov 05, 2010 | Linksys Wireless-G WRT54G Router
It shows a excelent connectionm wireless and shows a conection wired but dosen't let me load web pages
Either disconnect your wired connection or disable your wireless connection. Your computer doesn't know what device to use for your web browsing.
Oct 05, 2009 | Linksys WRT54GP2A-AT Router (WRT54GP2AAT)
Acer 6935 laptop - cant browse web
Do u have a firewall installed? Norton gets thru being a recognized anti-virus, however check your firewall comands & exception and what is allowed.Change this rule or disable Norton/Firewall & try browsing. Also check your DNS & gateway of your ISP.....sodeep
Sep 28, 2009 | Linksys StackPro II 100BaseFX Distance...
Internet Connection Problem on One Computer
By any chance, are you trying to use something other than Windows to manage the wireless adapter? If you are, remove it.
Now, Click on Start, right click on Network highlight properties, and click on manage network connections on the Tasks menu.
Your two options will be the icons for your LAN and Wireless Network. Is it enabled and without red or yellow marks? It could be disable, it could be not connected and you can't view wireless networks because the switch is off, or it may just nut see your unsecure network (unlikely).
If the above is clear, right click on the wireless and highlight Properties and left click so it brings up the Networking tab. Highlight IPv4 and click on Properties. Make sure the Obtain dots are ticked. That should work, since you are running unsecured.
If it already is, check the red X or if it isn't click OK and close down the box.
Now, back to where your Wireless card is showing, right click it and you have Disable, Connect/Disconnect, Status, Diagnose etc.
If you're still Disconnected but not Disabled, click on Connect/Disconnect. Does it show your wireless network?
By this time, it should. If it doesn't post back. The other possibility is that you take your computer to a wireless internet cafe, McDonalds, Panera Bread, or motel with WiFi and test it there.
Carl
Jun 21, 2009 | Linksys Wireless-G Broadband Router
NETGEAR USB WPN 111 and linksys router problem reconfigure proble
check if the usb light on the modem is lid or not.
try to reinstall the usb drivers.
and visit http://www.aakashjain.com/General+Troubleshooting+Steps+If+Your+Internet+Is+Not+Connecting.aspx
here are the simple steps u can follow.
Feb 17, 2009 | NetGear Wireless-G USB Adapter...
Wireless connection is not secure when I'm logged in from PC,anyone can use
Click on this link
http://www.portforward.com/english/routers/wireless/routerindex.htm
Then choose the brand and model of the router and follow the steps how to secure your wireless connection.
Sep 24, 2008 | Linksys Wireless-G WRT54G Router
Wireless network and computer freeze
Routers in general divide you internet connection across the amount of devices you have plugged into it, but not evenly. For example, computer A can be browsing a web page, and someone else can be playing games on Xbox live. Due to amount of traffic internet gaming creates, it can slow your internet connection tremendously depending on the speed of your connection (especially if you have the slowest broadband connections out there, 1.5mb and under).
However, the fact that you mentioned that it only happens with wireless devices, leads me to believe that it is a router issue. I would first begin by resetting your router to its factory defaults and retesting your internet after its been set up properly (linksys can walk you through this).
If that doesn't work, the next step would be to buy a new router.
Third, would be to upgrade your connection to a higher speed, if your provider allows for it, but this is unlikely that you will have to go to this resort.
Apr 11, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRT160N Wireless Router  Logo
367 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
