Question about Hitachi 43FWX20B 43" Rear Projection Television
After installing the two converegence chips,(stk-392-110)the tv powers on for maybe two seconds then shuts off. I took the board back out and checked all solder joints,they were all ok.when powered on I did not see any smoke or sparks, it just goes off after two seconds.All of the resisters appered to look ok,so I did not replace any of them. Any sugestions on what might be wrong or is it time to get a new tv. Thank You very much for any sugestions.
  • Hitachi Master
  • 3,459 Answers
Yes - You most likely created a short by soldering the convergence chip pins together. Go back over your soldering and fix any bad spots. No two pins should be touching.
Ed
Posted on Jun 20, 2009
I have a KDP51ws550 tv that has convergence problems. Flash focus would not work and neither would manual convergence. I replaced the both convergence ICs and checked the pico fuses, turned the unit back...
Check your soldering. Check the vertical power board on the far left when looking from the back. It has fuses on it as well.
Depending on quality of STK chips, they could have been bad or failed right away. Best things is to look at the schematic, verify what colors you can move and see which STK chip is not functioning.
If both chips are not function after replacement, likely a fuse. Be sure to verify the resistors next to the STK chips.
Mar 06, 2011 | Sony Grand WEGA KDP-51WS550 51" Rear...
Powers on for about 5 seconds and shuts off with 3 flashes of the power light. Continues to flash 3 times.
Hi: Three flashes for the power indicator indicates convergence failure, Most failures are the large black convergence IC's on the convergence board, have these replace to restore operation, The Part number should be on the chips themselves. But just in case the part number of the are STK-392-110, Replace them with 120 for extra life expectancy. (STK-392-120)
Dec 08, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Turns on and within a second goes out
Bad capacitors. They're cheap. Look for the ones closest to where the power cord comes in to the main pcb board. This will be your power supply circuit. Change them! They're probably dried out. If they're bubbled up, they're also bad. They're so cheap though, just replace them all.
May 21, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergence Board (I hope)
check this out I have the same problem check your solder spot make sure the solder points are not touching one another, that could be one of the reason is doing this or just to make sure you can desolder the stk chips clean the holes where the pins go trough the board and power the tv with board and if the tv start fine if could be bad stk chips be very careful when desoldering or soldering good luck about another is not worth it they cost too much around 350-450
Oct 06, 2008 | JVC AV-48WP74 48" Rear Projection...
Colors not aligned and picture arched.
I have had the same problem with my tv.I have replaced the 2 stk packs and have had the same result.So I called a tv repair man to the house and gave me a $400 estimate.I have come to far to give up fixing the TV myself!! So I started to check voltages on the power board and found on the 9 pin connector (right when you pull the back of TV panel off its right there)there all printed on the board.Check all those voltages,especially -22 and +22.Put your meter ground on the wire in between those 2 wires and check both.If either are not there,remove board and you will find about 1" in from that connector 2 orange resistor looking components,they are solid state fuses.Use an ohm meter to see if either are blown.there desigination on the board is5001 and 5002.I replaced one with an automotive 5 amp mini fuse soldered to two 1" pieces of wire.plug back in check for powers and if all good do following,press in order on remote display button then 5 button then volume + then power button all within 5 sec,you will see bunches of #s and letters.Then press 8 then enter,the tv should shut off.this is master reset for TV and starts whole tv like you just took it out of box.TV should be fixed
May 24, 2008 | Sony KP-57WS500 57" Rear Projection...
STK chips didn't fix my problem
You probably have a bad cap in the horizontal sync circuit. I'll check with mhy Pioneer contact for more details. Stay tuned...
Dan
May 23, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Panasonic PT-47WX42F 3red flashes and a pause
# flashes in a panasonic means the convergence amps have failed. You will need to replace both convergence ICs numbers STK392-110 you can get replacement ICs at the following link and they include free instalation instructions with pics so you can do the repair yourself and save about 400.00 Heres the link you will need two ICs.
http://servicemanuals.vstore.ca/
May 08, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic pt-53tw53 convergence
It looks more like an open solder because you were able to align it properly after replacing the STK ICs, if there was an open resistor(s) you would not be able to get it align.
I would suggest to go back and double check the solder joints on the STK ICs as well add some fresh solder to the resistors nearby the stk392-180.
Good Luck.
Apr 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
SD533HD5 Blowing Fuses
No lo creo ,ya que el problema puede ser el circuito horizontal checalo o manda la tv a un taller.
Mar 17, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Convergence/power off
no sundog this model has the potenthal to be a nice tv when you saw the burn't resisters that was your clue to change the stk's now that you have fixed the res problem the bad stk is telling the set to shut down replace stk,s i ALWAYS change both (buy the way in the future those are hi watt res THEY SMOKED FOR A REASON maybe you thought they were installed in the 70"s ha ha. but they smoked because the stk's one or more are bad. good luck doc
Aug 11, 2006 | Panasonic PT-51HX41 51" Rear Projection...
Hitachi 43FWX20B 43" Rear Projection Television Logo
141 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
