Question about Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor
How do i remove the blade?
I have a weedless Minn-Kota 44 endura/ transom mount and I need too remove the blade..I don't see a nut too remove but there is a plastic wingnut looking thing, looks like its on a shaft???..It spins but how do I get it off??
  • 157 Answers
SOURCE: Minn Kota 30 transom mount motor magnets fell out during service
Hello Bob, Contact www.minnkotamotors.com/index.asp choose ext#406 ask for Dave. He is a good guy. Merry Christmas.
Posted on Dec 05, 2008
SOURCE: I have a Minn Kota Endura 30, transom mount.
There is kind of a collar on the lower side of the head where the head connects to the shaft. There is a single bolt that runs right thru the shaft at this location, remove it. Rotate the head 180 degrees and re-install the bolt. 5 minute job.
Posted on Apr 17, 2009
SOURCE: the prop will turn on my minn kota endura 44 but
Odds are you have sheared the pin (slides through the prop shaft) holding the prop, or you have damaged the slot on the prop that the pin sits in.
Prop is secured to the shaft with a metal nut, or flat plastic wing nut. Remove the nut to remove the prop. You may have to pry, slightly, the prop from the motor housing. Removed, you will see a whole in the shaft where a pin should be located. If the pin broke, it probably hit the floor when the prop was loosened. If the pin is intact, examine the rear side of the prop and look for damage to the plastic slot where the pin would sit making contact.
If you've snapped the pin, you can make a replacement with a nail using a hacksaw. Replacement pins can also be ordered from Minn Kota. If the back side of the prop is damaged (recess for the pin to sit), the prop is toast. Replacement props are often carried by Walmart, and include a new pin.
If neither part is broken, perhaps the prop was just not seated on the pin correctly allowing the prop to freewheel.
Posted on May 13, 2009
SOURCE: how do I remove the composite shaft from the motor housing
I just replaced the shaft (composite) on my Endura 34 today. First, remove the crossbolt that attaches the control head to the top of the shaft. Second, remove the top cover of the control head. Third, make note of the wire connections within the control head (take a picture) and then unplug the red, yellow, white and black wires...no need to unplug the main 6 guage red and black power wires. Fourth, with the wires unplugged, pull the shaft with motor housing attached through the transom mount assembly. Fifth, immobilize the motor housing (gently vice?) and heat the socket in which the shaft screws into motor housing. Do not overheat, only use enough heat to soften factory sealant making unscrewing shaft possible. Sixth, reassemble in reverse order.
Notes: Do not use a pipe wrench as this will crush the composite shaft, either old or new. Apply thread sealant prior to installing new shaft (I used Permatex Thread Sealant/Formagasket). Ensure crossbolt hole on top of shaft aligns with motor housing below.
Posted on Jun 17, 2009
  • 91 Answers
SOURCE: Endura 30 Freshwater Transom Mount Trolling Motor: I JUST PURCHASED A Pellican pontoon boat 10e and i...
probably an endura 50 would be a better fit for a potoon boat. assuming the boat is normal size. if its a smaller one then this motor might work just fine. give it a try and see if it moves you about fast enough for your taste.
Posted on May 17, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    What kind or type of battery do I need for a Minn Kota Endura 40 trolling motor?
    The Endura 40 is a 12V motor. To get off a bit cheaper go to a place that sells car batteries and get a sealed maintenance free battery.
    Sep 27, 2010 | Minn Kota Endura 30 Freshwater Transom...
    What is the amp draw of the motor, so i can buy the right battery for a minn kota endura 30 trolling motor?
    You will need a 100 to130 amp hour deep cycle marine battery. Check prices of many brands in your area. (WalMart, Autozone, boat dealers,ect.)
    Sep 16, 2010 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Endura 30 Trolling Motor specs
    call 800 number on head minn kota they are very helpful and will fax, email or mail you anything you need.
    Jun 02, 2010 | Minn Kota Endura 30 Freshwater Transom...
    May 15, 2010 | Minn Kota Endura 30 Freshwater Transom...
    I need a truster speed for a Minn Kota Endura 46
    Hi!
    Here is a scchematic with part numbers and service center listing as well:
    Endura 46
    Best of luck!
    Mike
    Jun 21, 2009 | Minn Kota Endura 30 Freshwater Transom...
    The prop will turn on my minn kota endura 44 but it has no power is there a shear pin on this motor
    May 04, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Minn kota endura 30 repair
    The top section will pop off when the six screws are removed. It might just be dirty and sticking.
    Apr 12, 2009 | Minn Kota Endura 30 Freshwater Transom...
    I have a Minn Kota Endura 30, transom mount. Just wondering, is there a way to rotate the controls so that I could use the motor on or near the bow of my 15' Aluminum fishing boat?
    Mar 10, 2009 | Minn Kota Endura 30 Freshwater Transom...
    Minn Kota Endura 30 Freshwater Transom Mount Trolling Motor Logo
    113 people viewed this question
    Top Minn Kota Boating Experts
    Mike Marcotte
    Mike Marcotte
    Andrew Taylor
    Andrew Taylor
    Colin Stickland
    Colin Stickland
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
