Question about Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Slow drying times
When the vent pipe is attached the dryer does not dry well. If the pipe is disconnected it dries better. The vent pipe has been cleaned and is not blocked.
  • 744 Answers
Check these things:
* The length of the dryer pipe and especially the wall flapper to be sure it moves ok and that it is not blocked by something
* Check the dryer vent line to be sure it isn't kinked somehere
* Check the dryer vent fan itself to be sure it is clean and not clogged or obstructed (I'm assuming it works)
* If all ok, you may have a bad thermostat or sensor that is causing the unit to turn off the heat prematurely
* Make sure the dryer isn't overloaded
Posted on May 10, 2009
Dryer takes a long time to dry?
disconnect the vent pipe behind dryer,dry a load and if it after an hour clothes are dry then you may have a house venting blockage. also check all seals(door,drum,blower hosing).
Feb 14, 2011 | Estate TEDX640JQ Electric Dryer
The dryer produces less heat and therefore takes too long to dry clothes
Hello egines. Generally the first thing to check is the vent pipe. If the pipe has lint in it, you will get a very long drying time. Pull the machine out from the wall, disconnect the vent pipe and inspect the inside of the pipe, the inside of the rear of the dryer where the pipe entered and the outdoor component. Remove all lint. Also make sure that the vent pipe is not kinked.
Joe
Thanks for choosing Fixya!
Jan 05, 2011 | Speed Queen Dryers
Heat coils turn on and heat for a very short time then turn off briefly turn on again it takes 2 hours for a load to dry
Make sure your vent pipe is clear from the back of dryer all the way outside....A clogged or restricted vent is the most common cause of slow drying...
Nov 03, 2010 | Kenmore 62602 Electric Dryer
Dryer gets hot close wont dry cleaned vent as well
how long is the vent run,anything over 15 feet will slow drying process
Mar 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer is not drying fast enough
The most common cause of slow drying is poor venting. Make sure the lint screen is cleaned after each load and that the vent pipe from the back is clear. (If you're using the white plastic vent tubing, get rid of it and replace it with rigid duct or corrugated flexible duct. It's less likely to clog with lint, and the the plastic stuff is a fire hazard.)
Check the airflow out of the dryer with the vent pipe disconnected - there should be a good, strong flow. If it's weak, the fan blade inside may be slipping on the motor shaft. If you've noticed any odd rumbling noise while drying clothes, that might be the cause. This will increase drying time, and may cause the machine to shut down the heat as well.
If this is an electric dryer, there may be trouble with the heating element. The temperature selector switch may have problems so that the dryer doesn't reach the heat you think it's set for (both gas and electric dryers).
Check the venting first, though. Hope this gets you going again, and thanks for using Fixya!
Feb 23, 2010 | Washing Machines
Dryer will not dry on auto setting, drys slow , over an hour on high setting
This sounds like your venting is eather too long or has a kink in it or is full of lent. First check behind the dryer for a crushed hose. Then check where the vent exausts. (The vent cap can also freeze up in the winter) If you are using plastic pipe (not recomended) change it too a rigit metal pipe. You should only have two elbos in your run. The shouter the pipe the better your auto dry will work.
Dec 22, 2009 | Dryers
Slow drying time
very simple, do this test, take your vent hose off the back of your dryer, now dry a load of clothes, if it still takes a long time to dry, then you may need to replace your thermastats, if it works better, your vent hose was pushed in, or smashed or the vent from the wall to the outside is clogged.
thanks Whites appliance repair
Sep 07, 2009 | Kenmore 659 Electric Dryer
Dryer not performing as it should
A blocked air vent will definitely extend your drying time. You may even find yourself having to run a load twice to get it fully dried. One way to confirm this is to disconnect the vent hose from the back of your dryer and dry one load with the machine venting directly into your laundry room. If that load dries quickly then you know the problem is a blocked vent. Most vents get blocked by lint near their exit to the outside. There's usually a screen at this location to prevent small animals from crawling into your house. Often this screen gets clogged with lint. Most vents are designed to allow removal and cleaning of this screen from the outside.
May 28, 2009 | Oregon Scientific Electric PTO Clutch for...
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
If you have'nt done it yet, my first suggestion would be to have the vent on the dryer (inside the dryer all the way to the fan chamber) and the dryer vent pipe to the outside thoroughly cleaned.
That is leading cause for dryers not drying completely.
Also, has the dryer always been a bit slow to dry cloths? If so, try leaving a window open the next time and see if it makes a difference. Some houses are sealed so tight, the dryer can't get enough air. A typical dryer will use up to 200 cu/ft of air per minute when drying. If there is not sufficient air, the cloths take longer to dry.
Good luck, let me know.
Regards,
May 12, 2009 | Maytag PYG2300A Gas Dryer
On autodry clothes do not fully dry
Try it with the exhaust pipe disconnected for a load, if that makes a difference, you need to have your vent pipe cleaned. Check in your exhaust pipe in the machine, too.
May 05, 2009 | Electrolux Frigidaire Affinity AGQ8700F...
Whirlpool Duet 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
158 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
