Question about Canon SmartBase MP390 All-In-One InkJet Printer
My ink cartridge on my canon MP 390 will not move to the middle so I can remove the ink tank.
  • 32 Answers
Russel, try the following, open the casing so that you can view the round bar on wich the cartridge mounting is attached, then use kleenex or towel paper to remove any grime on the roundbar on that unit. then apply vaseline or 3 in 1 oil onto the whole length of the roundbar. Lastly with your finger try and move the cartridge unit gently without any force. If it still doesn't move then you should see that either the belt or belt drive tension is correct and moving freely, if it does, then place your finger under the cartridge unit and lift it gently upwards, while lifted try move it to the other side of the printer. If not get back to me.
Posted on May 12, 2009
How to reinstall new ink cartridges
Open usually in the front in the middle there is an opening pop it open have it on ink cartridge should move to the middle pop the clips and slide old one out gently slide new one in
Apr 10, 2012 | Canon Office Equipment & Supplies
I need to change the black ink cartridge in my Canon Pixma iP90 printer, can you help me
turn the printer on.
Raise the printhead cover.
The printhead carrier will move to the center.
Remove the cartridge
(1) Push the tab.
(2) Remove the ink tank.
Then lift it from its slot.
Do not touch the Lock Lever; remove only the ink tank.
Unpack a new ink tank and remove the orange Protective Cap
(1) Insert a new ink tank with it slightly slanted.
(2) Push down on the "PUSH" on the ink tank until it clicks into place.
Close the print head cover and the carrier will move to the right.
Reset the print counter.
Instructions can be downloaded from:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_series/pixma_ip90#BrochuresAndManuals
Please rate this solution. Thanks
Nov 05, 2010 | Canon Office Equipment & Supplies
Canon MP 610 printer. Cartridges half full when forced to replace
well printers calculate ink, with printing jobs. If you exchange cartriges in the middle of these ( ex:you exchange cartriges about after 100 print jobs and the cartriges is 500 top) the printer dont know excatly the ink level, so gives these error on calculation, not exact ink level. so you need to take out and place again to reset cartridge counter.
Jan 16, 2010 | Office Equipment & Supplies
Canon mp 390 waste ink near full
Some user tried the procedure to reset waste ink tanf full on Canon MP 360 and ... Reset Ink Level for Canon MX300 · Reset Counter Canon iP1500 and iP1000 ...
tricks-collections.com/waste-ink-tank-full-reset-canon-mp360/
Dec 06, 2009 | Canon SmartBase MP390 All-In-One InkJet...
Ink cartridge
  1. Check that the printer is powered on and open the front cover.
  2. Wait until the print head moves to the center.
  3. Check if the ink tanks are installed properly.
    Ink tanks installed correctly
    Ink tanks installed incorrectly
  4. When installing the ink tanks, push the top of the ink tank until a click sound is made.
    Note: If the ink tanks are not installed properly, paper may not be fed properly, or ink may not be ejected.
  5. Close the front cover.
Sep 16, 2009 | Canon BubbleJet i320 Printer
The ink tank doesn't go to the middle
After you opened the front panel, did you lift the scanner section? The scanner section has a switch on it that activates the ink tank holders to come out to the middle so they can be changed. It is not the greatest design and it doesn't stay up by itself. I normally use an old cartridge to prop up the scanner section while I change cartridges. Hope this helps!
Apr 01, 2009 | Canon MultiPASS MP370 All-In-One InkJet...
I have Canon MP 390 and no printing
Fill up the cartridge as printer software does not always monitor right ink level even its happens to me many times but fact is cartridge is empty fill it up thats it
Feb 11, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
Repair manual for a canon mp 390 printer
Change the cartridge message. I changed both black & color but still the same message would appear. I can NOT make any maintenance ( cleaning the nozzle,....)
Mar 04, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Canon SmartBase MP390 All-In-One InkJet Printer Logo
90 people viewed this question
old marine
old marine
