Question about Socket Communications Standard Keyboard PS2 - 105 Keys (Black) (CD105PS2)
No mice work on my computer!I installed a wireless mouse, and now no mice work, the wireless, and normal keyboard does. How do I fix the mouse socket?
  • shannonhint May 10, 2009
    You dont understand, I have tried re installing and such, restarting, its a problem with the computer, how do I fix the mouse socket?
    I was trying to avoid that... I'l just get a USB mouse, the keyboard works fine.
  • 432 Answers
If it is PS2 then you need to reboot your computer in order for the computer to detect the PS2 device ( the PS2 device needs to be plugged in before rebooting )
If USB then try a different USB port and also check bios settings to ensure all usb keyboard and usb mice settings are all enabled.
You could go into device manager and delete usb hub etc and let windows re detect and re install otherwise go to
http://www.usbman.com/WinME%20USB%20Guide.htm
His site has lots of other useful info
Posted on May 10, 2009
  • Shane Russell
    Shane Russell May 10, 2009
    mouse socket on the socket of the cable thats attached to the mouse or actually on the computer socket ?
    If on the mouse socket you can use a paper clip or needle nose pliers if its the socket on the computer then your going to be hard pressed to fix that.
    Better off getting a usb mouse
  • Shane Russell
    unless you can use a paper clip or something small to get the pins or fix it yourself then fair enough but otherwise it will be easier just to get a usb mouse or keyboard and resolve it that way
    you can get reasonably cheap ones so its not really worth the hassle and time etc to try and fix it.
    Any chance you can alter the rating as I am trying to be helpful and honest
I cant get the mouse to connect to my laptop
Desktop or Laptop ?What type of mouse ??...
Enable a Mouse for a Laptop
Without the ability to drag and drop and point and click, a laptop computer is merely a desk ornament.
Most laptops are manufactured with a built-in mouse in the form of a touchpad.
If the touchpad fails or if you just prefer working with a mouse, it is easy to enable a mouse for use with your laptop.
Purchase a mouse that is compatible with your laptop.
You can find compatibility information on the manufacturer's website.
If the mouse is wireless, make sure that the USB receiver is included, or purchase it separately. The mouse will not function without the receiver.
Insert the batteries in the mouse if you are installing a wireless mouse.
The battery compartment is generally located on the bottom of the mouse.
Connect the USB mouse to the USB port on the computer.
If you are using a wireless mouse, connect the USB wireless receiver to the USB port.
Turn the computer off and then on again if you are enabling a standard mouse with a wire.
This will instruct the computer to run the "new hardware" wizard, which will walk you through the installation of the mouse, and your mouse will be enabled.
Turn the wireless mouse over, and locate a small indentation with a button.
You may need to use the tip of a pencil or pen to depress this button.
Simultaneously press the button on the mouse and the small button on the USB receiver.
This will initiate communication between the mouse and the receiver.
Hold the buttons down for about 5 to 10 seconds until the light on the mouse comes on.
Test the connection by moving the mouse.
If the cursor moves, you have successfully enabled the mouse.
If not, check that you have the batteries installed.
Try pressing the buttons independently of one another.
Press the button on the receiver until the light blinks and release it.
Press the button on the bottom of the mouse until the light on the mouse is lit.
This should enable your wireless mouse.
sign up
http://ftp.pisd.edu/guide/wireless-keyboard/wireless-keyboard.pdf
Wireless Mouse to Your Computer & Laptop
Connecting a wireless mouse to your computer is a great way to reduce clutter around your workplace. Also, it is an alternative to using your laptop's directional pad.
Wireless mice work just as well as wired mice for most computing needs.
The only detail that wireless mice lack compared to wired mice is the DPI (dots per inch) and the frequency rate, which is essential to the "fast twitch" movements in gaming.
However, most people do not need highly responsive mice; therefore, wireless mice are perfect for any other computing activity other than gaming.
Insert batteries into your mouse. If your mouse is rechargeable, charge it in the docking station provided with the mouse.
Buy a wireless adapter that works with your mouse.
If your laptop is enabled with wireless technology or Bluetooth, skip to the next step.
Install the drivers for your mouse.
Reboot the computer to apply the changes.
Power on the mouse and let the computer recognize the new hardware.
If you are using a mouse that requires software to run, enable the mouse in the software that is provided to you.
http://www.sunvalleyus.com/Article/LaptopKeyboardInfo/46.html
also
Laptop computers generally have built-in pointing devices such as touch pads that you can use to navigate the operating system on the go.
However, touch pads and pointing sticks are small and generally far from ergonomic.
At home, you might like to connect a full-sized mouse for greater comfort.
Computer mice connect in a variety of ways, and you should be able to find a mouse what works with whatever peripheral ports your laptop has.
As a general rule, any mouse that works with a desktop computer also works with a laptop.Laptops use the convenient touchpad and integrated scroll mouse that allow you to use just your finger to navigate Web pages, documents and open files and programs.
Just like all other hardware, the laptop's integrated touchpad and mouse can experience errors and problems that cause you to lose functionality for a length of time.
Whether the laptop's mouse is not working because of internal errors or conflicts with another device, several "tricks" can work to restore it.
Locate the function "Fn" button on your laptop in the lower left corner of the keyboard.
Look in the keyboard's upper row (the F1 through F12 buttons) for an icon of a touchpad or computer mouse.
This keyboard button acts as the toggle switch to enable and disable the built-in mouse and touchpad function.
Press and hold the "Fn" button together with the mouse icon button.
Look for the disable/enable symbol that briefly displays on your screen.
Slide your finger over the laptop's mouse and attempt to use it as normal.
Press the Windows keyboard key if using Windows 7, type "main.cpl" in the search box and press "Enter."
Press the left arrow key to navigate over to the "Device Settings" tab.
Press the tab key to reach the "Enable" button in this section.
Press "Enter" on your keyboard. Press the tab key to reach the "Disable internal pointing device" check box.
Press the space bar to remove the check mark.
Put your finger on the touchpad, and move the pointer down to the "Apply" button.
Click "Apply" to save the settings. Close the mouse "Properties" box.
Press the keyboard "Windows" logo key to open the "Start Menu."
Press the arrow keys on your keyboard to navigate to the "Shut Down" or "Turn Off Computer" menu. Press the up or down arrow key to highlight "Restart."
Press "Enter" to restart your computer and attempt to use the laptop mouse as it should normally function.
Open the "Control Panel."
Go to the "Add and Remove" or "Uninstall" programs section.
Highlight any secondary mouse devices in the list that you have installed for your laptop, such as an external USB mouse.
Select the "Uninstall" option to remove any software and settings associated with this secondary mouse.
Restart your computer and attempt to use the built-in laptop mouse as normal.
Check to see if the mouse is working properly.
Press the keyboard's "Windows" button to open the "Start Menu."
Press the keyboard's arrow keys, "Enter" button and "Tab" to navigate to and open the "Control Panel."
Go to the "Hardware and Sound" section, and press "Enter." Navigate to "Device Manager," and press "Enter" to open it.
Find "Mice and other pointing devices from the list" and open its "Properties" dialog box.
Select the "Driver" tab and choose "Update Driver."
Allow Windows to search the Internet for drivers and to update them automatically.
Restart your computer after the drivers are updated, and use your mouse as normal.
http://www.webdevelopersnotes.com/articles/laptop_touchpad_not_working.php
Aug 11, 2013 | Computers & Internet
I have installed the software and still can't use the wireless keyboard and mouse (GE wk1204)
Most mice should work without any software, there is a button on the underside of the mouse that needs to be pressed in the right order with pressing the receiver button connected to the computers USB port. Typically Press the base connect button first, then the mouse connect button, then the keyboard button. If it doesnt work reverse the mouse keyboard order. Make sure your using new batteries This is most often the case -dead batteries. (installed in the correct fashion) cheers.
Aug 25, 2010 | GE Wireless Optical Mouse
Windows update = dead mouse
Try using a usb mouse and keyboard.Your computer should already have drivers for these devices loaded.
Apr 08, 2010 | Dell Wireless Keyboard Optical Mouse w0147
My logitech wireless mouse works but the wireless keyboard does not. When I try connecting the keyboard the mouse stops working. I can get the mouse working but can't get the keyboard working. The only key...
The keyboard is not recognized by your PC. By the way, do you have the software installer for your keyboard.? Run the installer in your PC, and try again
if it now recognize the keyboard.
Sep 24, 2009 | Logitech Wireless Access Duo Optical...
Wireless keyboard and mouse not working
Hello
Some wireless keyboards and mices have a button that enables the locating signal of the device, this button when pressed locates the receiver and initiate a pairing with the host. Look below you keyboard and mouse, and if your keyboard is a Bluetooth device, then check in your computer if the bluetooth is enabled and drivers are installed.
good luck
May 23, 2009 | Dell 0Y3740 Keyboard
Keyboard not responding
Have you tried a USB keyboard and mouse wired.try also to hook up the normal keyboard and Mouse with out any usb devices hooked on the computer
May 05, 2009 | Logitech 967461-0403-PK Keyboard/Mouse
We have a 1027 wireless microsoft keyboard and a mouse
Go into your Control Panel, and select the icons (seperatly ofcourse) for your mouse and keyboard and make sure they are in the list for each and are activated. Also, uninstall the drivers for them, and re-install them with the disc provided that came with them. I hope this works for you. Also, after uninstalling the drivers and software, restart the computer, then insert the disc and run setup.
Apr 01, 2009 | Microsoft Wireless Optical Mouse
Wireless keyboard and optical mouse
Thanks! I fixed the problem by installing a USB mouse and using fn+f9. That unlocked the mouse so I could use the pointer leaving just the keyboard problem. I then tried reconnecting the wireless keyboard (by using the button on the receiver and under the keyboard) Hey Presto!!
Feb 02, 2009 | Logitech Wireless Access Duo Optical...
Wireless mouse doesn't work
This problem was happening on my system but i managed to fix it easily! What has happened is your itouch software has become corrupt so it will only recognise your keyboard thus the usb connection. You will need to download/install off disc onto your computer again but do NOT go to uninstall program manager on windows as it will not appear there because even though you can access the itouch configuration panel, the database is corrupt and the administrative system will not recognise this. Just download/install via disc and it will just install with no alerts unlike most programs which will recognise the program is already installed onto the system. Once the setup is 92% it will freeze for a second then the found new hardware window will appear on screen go through that process and your mouse is back to normal and your keyboard will work via itouch software.
(Please note that this will only work on windows)
Nov 26, 2008 | Logitech Cordless iTouch Keyboard/Cordless...
Mini wireless mouse not working
Well typically with wireless mice you must press both bottons on both the mouse and the connecter...then after pressing both buttons restart you computer...you computer might not recognize a new piece of hardware right after being turned on. Also make sure there isn't software that needs to be installed there normally is with usb wireless mice. If this does not work please post a comment and I will help you futher. If this does help please be kind and return the favor of giving me a fixya! rating have a good day!
Apr 30, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Computers & Internet Logo
120 people viewed this question
Top Socket Communications Computers & Internet Experts
David Payne
David Payne
Are you a Socket Communications Computer and Internet Expert? Answer questions, earn points and help others
