Question about Hitachi P50H401 50 in. Plasma HDTV
No picture or sound, electrical storm
There was an electrical storm last week and I think it fried my TV.
I also got my hd dish receiver.
I can turn it on and the light comes on. I see no picture or sound. I can't change to different inputs or anything.
Is there a way to reset it or any suggestions. It will go in if need be, but would like to try some things first.
It is a 50" plasma 07 model
p50h401a model #
  • 4 Answers
Did you ever get it fixed? Are you looking at selling it or need parts. Mine fell and i broke the display panel, but everything else works
Posted on Jun 14, 2009
Sky hd box no satellite signal
Have you checked that the dish is still properly aligned? Could the recent storms in the UK have thrown it off? Likewise, have you checked that all the cables and plugs between dish and receiver are in good order? Lastly, if you have a Sky contract, have you called their customer support line?
Nov 05, 2013 | Televison & Video
Samsung hdtv how to know if lightning fried it
If the tv will not turn on it is safe to assume that the electrical storm did damage something in your television.
Jul 11, 2012 | Samsung 46 UN46D6000 LCD TV
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
Had HD tv but now no longer get picture just sound.Got 63% signal strengtht
i_forbes
If you are getting sound, try unplugging the receiver from your electrical outlet for 10 seconds and plug back in. This will cause the receiver to reboot and reacquire satellite signal. After it completes this process, see if you get a picture with sound back. I hope this helps.
Ray Calo
DISH Network
Feb 26, 2011 | Sagem Televison & Video
I have a 63 inch projection tv, 8 years old, that stopped turning on last week. Not sure what's wrong with it. You can hear the power turn on inside the television though the screen does not turn on. No...
LOOKING AT THE AGE OF THE TV IT MIGHT HAVE DRY JOINTS ON PCB,S SO IF U KNOW ABOUT ELECTRONICS AND GOT SOLDERING IRON RESOLDER SUSPECTED SOLDER JOINTS AND THEN TRY.
Aug 12, 2010 | Mitsubishi Televison & Video
My dish DVR HD control doesn't work
lumaes200,
You have indicated that you have a 622 DVR receiver, since this is where your posting was found. When you trying any of the DVR functions on the remote, do you get an error message (024 or 311) indicating that the function is not available at this time? If not, try unplugging the receiver for 10 seconds from the electrical outlet. This will reboot the receiver and re-acquire the satellite signal. Once the picture returns, try the DVR function. If the problem continues, please call 1-800-333-3474; we may need to replace the receiver. I hope this helps.
Ray Calo
DISH Network
Apr 02, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Toshiba CN36X81 television.. NO Sound... Great Picture. Using the TV2 output of a DISH Network HD receiver... TV2 output is std def, coax output. Using a different TV I get picture and sound... but not...
IF coming in via, the "Dish" networked receiver, please check that this volume is turned way up, on the TV. and then control the the Volume, with the Dish Remote, often this is a problem, as one is turned down, and the other cannot turn that up, simply try syncing the Volume controls, UP on TV, control the Audio with dish remote. thats all i can think of. Check by feeding a signal IN from an AV, source, ie: Yellow, Video, & Red& White, Audio. Turn TV UP and check, IF it responds to this all is well. If NOT then you do indeed have a fault, with the TV.
Mar 27, 2010 | Toshiba CN36X81 TV
Magnavox 52 inch HD Tv connected to a Dish Network HD Satellite Box. If you watch a channel with HD programming and then tune to a analog channel there is no sound. The tv has to be turned off and back...
have you tryed to go to setting and letting it yout tv know that you want sound onto the hd channels.? if you have any more problems joust contact you coustmer service for dish network. problalby your tv is not compatible and you need an hd receiver. i have dish network myself and just upgraded my receive to hd.
best of luck- JD
Nov 18, 2009 | Philips Televison & Video
Dish Network HD Monitor HD 40-300
I have a Dish Network HD40-310 Monitor. When you turn power on the green power light comes on, then tv makes funny noise, then goes off again without producing any picture. Any ideas how to fix?
Aug 02, 2008 | RCA Televison & Video
Pink and blue images occasionally on power up of DISH DVR
Tell me a little more about how the receiver is connected to the tv and if this is present on both tvs at the same time and lastly what brand and model of tv you have. I recently had an issue somewhat similar to this but need more information to make an educated hypothesis.
Apr 18, 2008 | DISH Network ViP622 DVR DTV Receiver /...
Hitachi P50H401 50 in. Plasma HDTV Logo
474 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
