Question about Sharp R-930AK Convection/Microwave Oven
Sharp Microwave model R-1850A door won't open
My microwave has been working great... until suddenly I couldn't get the door open.
I finally managed to open the door by pushing the "open button" and pulling on the edge of the door.
The latch bar on the door seems to be working fine. The spring is still there and the latch goes up and down and has plenty of tension.
The door will shut and the oven still operates... however it is very hard and almost impossible to open. It normally just pops open when the tab button is pushed.
While the door was open I looked at the inside where the latches fit... when you push the button tab you can see something moving. I'm assumming this is the piece that releases the latch and opens the door. These slots on the top and bottom where the latches fit do not look the same. Could there be a piece that has broken off?
Thanks for your help!
Cathy I have the same problem with my Sharp R-930CS. The door won't open on it's own when I push the button, I have to actually pull on the door to get it to release & open. I don't see anything broken or out of place. This unit is just over a year old and has been given TLC. Any ideas on what the problem may be?
  • 4 Answers
Buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
Posted on May 10, 2009
SOURCE:
Replace dor latch spring in Sharp Microwave R-1850A
Usually this can be done easily by removing the door unit and removing the panel to the door wherein you will be able to get access to the door lock. If there is no damage to the pivot or the post to hold the lock and spring , you can push the spring and reset.
Sep 03, 2014 | Sharp R-1850A Convection/Microwave Oven
Sharp r-1850a turntable problems
turntable motor p/n 46-841666-3, available from searspartsdirect.com, use correct model #!!
Feb 09, 2013 | Sharp R-1850A Convection/Microwave Oven
It suddenly stopped working correctly. It makes a strange noise when operating and doesn't heat food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 16, 2010 | Sharp R-1850A Convection/Microwave Oven
Replacing a damper motor - Sharp R967 MICROWAVE AND CONVENTION
The damper should closed when in convection mode and open when in the microwave mode, to keep the heated air inside the cavity.
Aug 22, 2009 | Sharp R-1850A Convection/Microwave Oven
Microwave not heating up
Check the door switch, when it is faulty the oven will turn on but turntable, fan and magnetron wont operate.
Regarding parts, contact the seller here to purchase parts.
You can also order from MicrowaveSvc , they also provide parts.
Jan 13, 2009 | Sharp R-1850A Convection/Microwave Oven
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Jan 14, 2008 | Sharp R-1850A Convection/Microwave Oven
Sharp R-930AK Convection/Microwave Oven Logo
693 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
