Question about Ariens Garden
Ariens lawn mower 1332 dies when put in gear - Ariens Garden
  • 246 Answers
Hello
From your Description it Sounds like a Bad Saet Safety Switch.
>>The Following is the Instruction File for Checking the Seat Safety Switch.
>>***PLEASE REMEMBER THAT THE INSTRUCTIONS FOR CHECKING THE SAFETY SWITCHES IS JUST THAT!!! FOR CHECKING ONLY.***
>>I NEVER Suggest a Mower be Operated with a Safety Device or Switch Disconnected or Bypassed. **Make Sure the Switch has a Good Connection. Now; On Some Model Mowers you can Simply Unplug the Safety Switch from the Harness. On Other Models you have to Place a Jumper Wire Between the Harness Terminals (on the 4 Post Switch Jumper from Same Color Wire to Same Color Wire). The Seat Safety is Showing No One is Seating in the Seat when the Clutch or Blades are Engaged.**
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
My ariens mower will crank but when i let the clutchout it dies what is wrong with it
Take the belt (s) off and try. If it still shuts off then probably a clutch problem. If not make sure that drive system can turn and isn't locked up.
Jul 30, 2016 | Ariens 42 in 17.5 HP 6-speed Riding Lawn...
It will not go forward it is only 1 year old and yes it starts my husband past away and I don't know what I am doing wrong
After the engine starts you must put the mower into gear so that it moves. Look for the gear shift lever or whatever.
Aug 02, 2015 | Ariens Zoom 42 In 165 HP Briggs Stratton...
My ariens lawn tractor is stuck in gear how do I manually put the tractor in gear and in neutral ?
Depending on the model of the tractor would determine what style transmission you have. However, there should be a by-pass valve located on the rear of the tractor. It looks something like a small piece of wire. Pull this by-pass valve out and you can then push the tractor.
May 04, 2015 | Ariens Garden
Does arien mower have a hydrostatic transmisson?
Some units do have hydrostatic transmissions, but most of the 42" units have 6 speed geared transmissions. To be absolute, you will need the product number.
Jun 16, 2014 | Ariens 42" Riding Lawn Mower Blade ...
Top gear broke on top of starter
some starters the gear is held on with a span ring and some with a roll pin
Sep 28, 2012 | Ariens Lawn Mower Universal Solenoid...
Myb ariens mower will go about 5 laps and then die
iF IT COOLS OFF AND WILL RUN OK BUT SHUTS OFF WHEN IT GETS WARM IT USUALL TO LITTLE VALVE STEM GAP.
Aug 02, 2011 | Ariens 21 In Classic Walk Behind Push Lawn...
Arien Riding Lawn Mower Model A20BH42
Did you check the Hydrostat freewheel control. I can't tell specifically from your question, but it sounds like the freewheel control is set in the freewheel position. See page 12 in the owners manual.
May 10, 2010 | Ariens Pair Of 02483859 Double Sided Skid...
Garden Logo
619 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Matt Olenzek
Matt Olenzek
Are you an Ariens Garden Expert? Answer questions, earn points and help others
