Question about Microsoft Crackdown for Xbox 360
My character can't stop shooting!
Whenever I squeeze the right trigger in the slightest on the controller, my character proceeds to keep shooting until he's emptied out 2 or 3 clips of ammunition.
The problem is limited to only my character and his weapon. I can drive cars fine, and I've put other games in the 360 to see if it's just the Right Trigger button, but it works fine in other games.
Any ideas?
  • bjgithens May 11, 2009
    I borrowed a friend's controller, and the game works fine now. I'm not sure why my controller doesn't like Crackdown, but I guess it's starting to break.
    Problem Solver:
  • 12 Answers
Reboot your 360 and just sit the controller down till it is done rebooting. If you even brush a button during the booting it can do crazy things.
Posted on May 11, 2009
No pressure once trigger is squeezed
We will have to just guess what this trigger is on :>)
AR Blue Clean - Spray Gun Trigger Squeezed, No Water Pressure
https://www.arblueclean.com/.../ar-blue-clean-spray-gun-trigger-squeezed-no-water-p...
When the spray gun trigger is squeezed, water comes out but there is no pressure. ... The RED color must stay in the window once the button is released.
pressure washer won't start unless trigger is depressed - Shop Your Way
https://www.shopyourway.com/questions/1151701 Jan 11, 2012 - pressure washer won't start unless trigger is depressed ... Thank you for your question on the pressure not starting unless you have the trigger pulled. ... After about 4 or 5 pulls the pump has built up enough pressure to make it ...
Pressure Washer Troubleshooting In-depth Beginner's Guide
pressurewashr.com/pressure-washer-troubleshooting/ Jul 5, 2017 - After holding the trigger to keep the water running through the machine ... (but not water supply) and release pressure by squeezing trigger gun.
Nov 21, 2017 | Garden
Acuraccy on my handi rifle
Can be three reasons for a group like that.
Barrel is loose on the stock and fore end.
You are jerking the trigger instead of squeezing it.
You are not controlling recoil as it has a very short barrel.
Aug 08, 2016 | Optics
Stanley tr-70 spring has no tension
It sounded good but made no sense. How do you remove the trigger/ squeeze handle assembly? This thing (Stanley TR70) is riveted together. The only piece that is removable is the staple feed tray.
Mar 01, 2012 | Tools & Hardware - Others
My right triger is not jammed but when i play my gun just keeps shooting and if i die then only my rigth thubstick and right trigger work
It sounds to me like this controller needs to be replaced. You can try cleaning the outside (and inside if you feel comfortable) with isopropyl/rubbing alcohol. If that doesn't work you'll probably have to buy a new one.
May 05, 2011 | Microsoft Xbox 360 Controller
My paslode wont shoot i cleaned the gun recently and oiled also the light is green and i compress the tip to shoot and it wont but the fan still comes on to vent the gas i also put a brand new gas in
strip it down again and put the battery in and whilst holding the nipple down pull the trigger (just mind your fingers as the fan will start) and as you squeeze the trigger see if sparks each time
Mar 05, 2010 | RTO PasLode 900420 Impulse Framing Nailer
How do I attach the drill bit to the chuck on a ss 120 drill
Well I couldn't find a pix of your drill so I will guess that it is a typical drill. You seem to be asking a very basic question so I will start will all the basic info I can think of.
First you have to know where the power trigger is to make it go.
2nd you have to know where the forward and reverse switch is.
Now with the switch in the forward position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the center Jaws should close up and come out of the chuck.
Now with the switch in the reverse position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the cetner Jaws should open up and go into the chuck to a maximum point
Open the jaws enough to put the drill in the jaws then put the switch in the forward position. Put the drill in the chuck, sqeeze the trigger to make it go, and hold the chuck so the jaws close on the drill. All while keeping the drill from falling out of the chuck.
When it closes on the drill and the drill is in straight then hold the chuck as tight as you can while squeezing the trigger to make the jaws close very tightly on the drill. If you have very tender hands you might want to use gloves.
To get the drill out put the switch in reverse, hold the chuck very tightly, and squeeze the trigger to open the jaws off of the drill.
Nov 28, 2009 | Black & Decker Drills
Stopped working in mid drill. squeeze the trigger, nothing happens
It could be a dirty switch connection in the trigger assembly , it happens to me on my electric sanders all the time , just open it up and try blowing it out with an air compressor
May 23, 2009 | Milwaukee 5318-21 1-1/2" Spline Rotary...
Xbox 360 Controller right trigger doesnt work
Your controller is most likely exhibiting a hardware failure. Taking apart the device voids your warranty. When a button does not work anymore, it is safe to say that you will need to buy a new controller.
The Logitech Chillstream Gamepad is only $20 and works in the same fashion as the XBOX 360 Controller (uses the same xb360 XInput controller driver too!)
Give that a look.
Aug 24, 2008 | Microsoft Xbox 360 Controller
Right trigger belives it is on constantly
it happens to quite alot of controlllers you just have to keep on pressing the trigger until it stops
May 31, 2008 | Microsoft Xbox 360 Controller
Microsoft Crackdown for Xbox 360 Logo
104 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
