Question about Jabra BT250 Consumer Headset
Connection was ok , then device stopped being found by phone when both were fully charged.
  • Anonymous Nov 18, 2007
    tried all that and it don,t work anymore suggestions
    cheers............
    President:
  • 2,961 Answers
You will need to go into the phones bluetooth devices and delete the Jabra headset and then pair it up again.
Posted on Oct 12, 2007
Motorola phone will not connect with Motorola roadster
Sorry you are having an issue connecting your Roadster to your phone. It is best if you fully charge your roadster. Then turn off or delete the pairing the roadster shares with any other device. If no other device is connected when you turn on the roadster it should report that it is ready to pair. On your phone turn on Bluetooth and search for the roadster. When it is found select it on your phone to initiate the pairing process. If it asks for a code enter the code 0000 on your phone to confirm the pairing.
Mark
Motorola Support
Oct 11, 2014 | Motorola Cell Phones
Samsung reality won't stay connected to jabra bt2046
I've had this issue with lots of Jabra products, including both my BT3030 devices. The problem seems to stem from the quality of the charge. When the device is fully charged, it seems out a nice loud clear signal which can be detected by your phone. As the charge begins to wake the signal gets noisier. So (my experience shows), When you pair your device with a clean signal, that's what your phone is looking for. If you pair with a weak signal; it looks for that. The ideal seems to be too pair the items up when your bluetooth device is either fully charged, or mostly charged.
Think of it this way. You meet and are introduced to a strange man in the early morning who is clean shaven. You meet the same man a few days later with lots of stubble and fall to recognise him. It's a bit like that!
Feb 18, 2014 | Samsung Reality U820
It shows a green light at the on and of button but does not go on
Hello
In rare cases, your TomTom ONE/XL/XXL navigation device may not start correctly
or may stop responding to your taps.
First, check that the battery is properly charged. To charge the battery, connect
your device to the car charger. It can take up to 2 hours to fully charge the
battery
If this does not solve the problem, you can reset the device. To do this, press
and hold the On/Off button for 15 seconds and release the button when your
device begins to restart.
OK.
Oct 17, 2011 | Tomtom One XL GPS Receiver
I am using xperia X10...and i want to connect to my HBH-GV435 bluetooth to this phone..but the HBH-GV435 blue tooth is already paired with some other phone.so i want to reset the bluetooth and connect it...
Headset-
1. Make sure the headset is fully charged, turned off and within 1 m (3 ft) of the phone.
2. Press and hold the On/Off button for at least five seconds, until you hear a long high-pitched beep and the light flashes red and green. The headset is now in pairing mode.
3. If your phone supports auto pairing, press "Yes" when the question Add device? appears in your phone. If it doesn't, continue with the next step.
4. Prepare your phone in accordance with the phone instructions for adding a Bluetooth device. Please note that for some phones you may need to enter a passcode. The headset passcode is 0000.
X10-
1. From the Home screen, tap the applications bar.
2. Tap Settings > Wireless controls > Bluetooth settings.
3. Mark the Bluetooth check box.
4. The phone starts to search for the device. Make sure that the device is in pairing mode. If needed, tap Scan for devices.
5. When the device becomes visible in the Bluetooth devices found list, tap to select it.
6. If needed, tap the text bar to enter the passcode (0000 by default) and tap OK.
7. You can now start using the paired Bluetooth device. The status of the pairing and connection is shown below the name of the Bluetooth device in the Bluetooth devices list.
Good Luck!
Mar 23, 2011 | Sony Ericsson HBH-GV435 Bluetooth Headset...
Simply....The phone refuses to turn on
first thing i would try is some kind of electrical contact cleaner. spray a little on a tooth brush, and clean the charging port. do this with the phone off and battery out.
Apr 17, 2010 | Verizon Communications LG VX8350 Cell...
My phone only works when it's plugged into the charger
New batteries are shipped partially charged. Before you start using your device, it is recommended that you charge the battery. Some batteries perform best after several full charge/discharge cycles. You can charge the battery in two ways: • Charging the device’s battery by connecting the power adapter. • Connecting your device to a PC via the provided Mini USB cable. Note: Only the AC adapter and USB cable provided with your device should be used to charge the device. Charging is indicated by a solid amber light on the left LED indicator. As the battery is being charged while the device’s power is on, a charging icon will be shown on the title bar of the Today screen. After the battery has been fully charged, the left LED becomes green and a full battery icon appears on the Today screen’s title bar. Warning! Do not remove the battery from the device while you are charging it using the AC or car adapter. As a safety precaution, the battery stops charging when it overheats. When the low-battery warning appears, do the following: • Immediately save your current data. • Synchronize with your PC or connect the power adapter to charge the battery. • Turn off your device.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jul 14, 2009 | UTStarcom Blitz Cell Phone
Dead phones
change the lcd panels or give heat bye using hear driyer ok it will be work
Mar 13, 2008 | Cell Phones
Philips mp3 player sa6045
This player shows the "Do not disconnect" message when it is doing something critical such as transferring tracks or updating firmware, which could corrupt the player if disconnected part way through.
The player shows the "OK to disconnect" when it is idle. As the message says, it's ok to disconnect, as the player will not corrupt if disconnected when it is idle.
These messages mean that the player does not need the "Safe to remove" procedure.
It is ok to disconnect part way through charging. Also the player will condition the battery once it is fully charged, so it's ok to leave it charging.
Occassionally batteries can "memorise" when constantly disconnect and reconnected without fully charging and discharging. To help prevent this, fully discharge the player (leave on until dead) and fully charge and condition (leave charging for about 12 hours) every couple of weeks or so.
Feb 11, 2008 | Philips GOGEAR SA6045 MP3 Player
W810i doesnt turn on or connect via usb
Charge the phone until it has finished charging, The first thing to do is to make sure that the phone is charged. Attach the charger and charge the phone for about 2.5 hours. Please note that the battery icon may not appear until after the phone has charged for 30 minutes. When the battery icon has stopped “flashing” the phone is fully charged.
Jan 17, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Blue tooth
Most phones that support bluetooth have a "headset" or "hands-free" profile that the device must be in for the bluetooth headset to work. Can you confirm that your device is in this profile?
Jun 06, 2007 | Motorola Mobility PC850 Wireless Bluetooth...
Jabra BT250 Consumer Headset Logo
37 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
