Question about Mantis 4-Cycle Tiller
My Mantis Tiller 4cycle engine starts well but when I press the throttle completedly, the tines turn very slowly. This is a brand new tiller, used only twice. The engine is sitting all the way down on the worn gear housing.
I had same issue with my 2 year old 4cycle. Check if the carb is moving full stroke with throttle movement. I had almost no movement at carb at full throttle, found the trigger in throttle handle was cracked and bent rather than pull cable. I called mantis and they promptly sent a new handle bar ***'y with new cable, throttle ***'y Etc and that solved my problem.
BTW: If you cannot wait, I did figure out that if I pushed the carb to open with the throttle trigger fully pulled it would run at high, but when you let go.....LOL
Rich in Wethersfield, Ct
Posted on May 28, 2009
Engine runs tines dont
The following was extracted from the Mantis owners manual..
At some point, you may find that the tines won't turn when you press the throttle. This may mean the engine isn't sitting all the way down on the worm gear housing. Perhaps you've been using your Tiller
for several years. Or perhaps you've removed the engine for use with the Mantis hedge trimmer attachment, then replaced it. In either case, the flange bolt may have come loose and lifted the engine up.
If this happened you'll notice a gap between the bottom of the engine clutch case and the top of the worm gear housing.
To fix this, loosen the flange bolt. Take the engine off the worm gear housing. Notice the hex head on top of the drive shaft . Inside the clutch case, you'll find the clutch drum. Make sure the hex head
lines up with the clutch drum inside the clutch case. Then put the engine back on the worm gear housing. Make sure the plastic carrying handle is not under the fuel tank. If you've followed these steps properly, there will be no gap between the clutch case and the worm gear housing. Make sure you tighten the flange bolt.
Jun 12, 2015 | Mantis 2-Cycle Tiller
When I Start Mantis Tilleer it starts in gear ( tines are turning)
The Mantis has a speed controlled automatic clutch.
Lower the idle speed by turning the idle screw counter clockwise. The idle screw is attached where the throttle cable meet the carb. The screw has a pointed end that resembles a pencil point.
The engine speed should be adjusted just above stalling.
If the tines turn even when the engine pull rope is pulled, the the clutch is defective and needs repairing.
j
Aug 03, 2013 | Mantis Tiller
Just bought an older Mantis 2 cycle tiller. The tines engage when the tiller is started. Of course that makes it hard to start with the tines on the ground! I don't believe it was doing this when I...
if the idle is too high the tines wont stop due to the tiller tines are run by a "centrifuigual clutch" which means when you increase the throttle speed the tines will start to turn : there are 2 adjustments you can try,1) adjust the idle screw under the carburetor where the throttle adjustment and a triangle piece of metal touch(your throttle cable wire will be attached to this triangle) ,if the triangle and idle adjustment don't touch and there's a gap between these 2 pieces close the gap by adjusting the 10mm adjusting nut,this will correctly set the idle #2) adjust the idle adjustment screw talked about above till the tines dont turn with throttle set at idle or lowest speed setting
Mar 26, 2011 | Mantis 2-Cycle Tiller
Tines turning, mantis 2 cycle tiller
sounds like a piston seizure. are you using correct oil and ratio. carb could be going lean and causing the cylinder to over heat, adjust high speed mixing screw and hope no damage has resulted.
Jun 30, 2010 | Mantis 2-Cycle Tiller
I have a mantis tiller, the tines won't turn, the engine IS seated to the flange. any ideas on a fix?
If the motor rpms up without drag it might be a bad gear in the transfer case or a broken cable if it's a cable drive, could also be a bad or stuck clutch. Hope this helps
Apr 27, 2010 | Mantis Tiller Tines #1622 00 02
Engine looses power, then speeds up, then looses power again
This sounds like the little fellow is getting hot. Are you using a good oil in the fuel don't skimp on that oil use the best you can find and get a new plug to sounds like the oil is killing your tiller.
Aug 02, 2009 | Mantis Tiller
Mantis 2 cycle - tines lose power.
I had this problem today. Loosen the flange bolt. Pull the engine off and check that the hex end of the shaft is lining up with the clutch pad in the engine-that it seats properly. Then make sure the shaft is seated all the way into the worm gear and put the engine back on. You will probably have to wiggle the shaft until it seats into the clutch. Tighten the flange bolt when the engine is seated flush with the worm housing (with no gap). That's all I did and the power is back up. Hopefully you still have your manual with the parts blow-up. (page 29?) BTW, have you checked that the wormgear is greased?
Jul 05, 2009 | Mantis 2-Cycle Tiller
Squeeze throttle engine doesn't increase/tines don't turn
Most likely the throttle shaft on your carb is stuck from residual fuel. Follow your throttle cable down to your carburetor and see if the shaft is moving when you press the trigger on the handle. If not, try moving it by hand and see if it loosens up. If not you may have to take off the air filter cover and spray some carb cleaner in the throat of the carb while moving the shaft back and forth until it loosens up. That should work for you.
May 05, 2009 | Mantis 2-Cycle Tiller
Honda FG100 Tiller - Tines wont move
I took the transmission apart and the gears were fine. The friction pads on the centrifugal clutch don't seem to make full contact with the drum. Does anyone know what the thickness of the friction pads are suppose to be? I used some belt dressing on the pads and got some movement on the tines. With no wear on the gears, I guess I'll be replacing the clutch.
May 02, 2009 | Honda Hmantis Mantis Garden Tiller with...
Crt or srt tiller?
* CRT or SRT -- These are two terms you will see on rear-tine tillers only. o Counter Rotating Tines are best for heavier duty jobs and for breaking new ground. o Standard Rotating Tines are good for aerating the soil and help propel the tiller forward.
Aug 27, 2008 | Mantis Electric Mini Tiller/Cultivator
Mantis 4-Cycle Tiller Logo
794 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
