Question about Cameras
Date stamp option in menu will not highlight to change it just skips past it change daye and time
  • Cameras Master
  • 4,738 Answers
For some cameras this option only works when the camera is set to a specific resolution. Some calle this resolution "Postcard" resolution, and is usually 1200 pixels width. Try setting your camera to its other resolutions to see if this ocrrects the problem. Suggest that you start with 1200 x 900 resolution. Keep in mind that this 1200 x 900 gives only 1 megapixel resolution. Most newer cameras are capable of taking much higher resolution pictures, so this may be a trade-off if you want to use the date stamp option.
Posted on May 10, 2009
I would like to turn the date stamp off... I do not like it in the pictures
Using the Capture Menu
The Capture Menu allows you to adjust camera settings that affect the characteristics
of the images and video clips you capture.
1. While in Live View or Playback, press , then use to highlight .
2. Use to highlight a menu option, then press to display the menu option's
sub-menu.
3. Use to highlight a setting, then press .
4. Press to exit the Capture Menu.
For on-camera information about an option, use to highlight Help... in the option's
sub-menu, then press .
In the capture menu goto
Date & Time Imprint Imprints date in lower left corner of image.
Off Default No date or time imprinted on the image. (this setting)
Date Only Date permanently imprinted.
Date & Time Date and time permanently imprinted.
this should fix your problem
Mar 18, 2014 | HP Photosmart M525 Digital Camera
Can I turn the date stamp on for a nikon coolpix 2000 camera. It tells me I have an internal date but the date is not showing up on my pictures.
Firts set the time and date
Go to "Setup" menu
Highlight "Date"
Display DATE menu
change yera. miont, day , hour
left menu
Time and date of recording is included with all pictures
taken with your Nikon digital camera.
try again , take a picture and look if show date time
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Nikon Coolpix 2000 Digital Camera
How do you date stamp pictures
1. Press the Menu button.
2. If your camera displays a menu with tabs at the top:
a) Press the Right/Left buttons to highlight the Setup tab.
b) Press the Down button to highlight Date Stamp.
c) Press the OK button to add the date stamp to new pictures.
3. If your camera does not display a tabbed menu:
a) Press the Down button to highlight Date Stamp. NOTE: Depending on your model, Date Stamp might be within the Setup choice.
b) Press the OK button to add the Date Stamp to new pictures.
Apr 11, 2011 | Kodak Easyshare M580 Digital Camera
How do I get the date stamp off the image?
  • 1
    Press the "Func./Set" button and select "Recording Pixels" and "Postcard". The camera is now set to "Postcard" mode.
  • 2
    Open the "Rec." menu by pressing the "Menu" button on the back of the camera.
  • 3
    Highlight "Date Stamp" by pressing the down navigation button.
  • 4
    Change the "Date Stamp" setting by pressing the right or left navigation button. Your choices are "Off", "Date" or "Date/Time". Choose "Off" to turn the date stamp off.
  • Jan 12, 2011 | Canon PowerShot SD960 IS Digital Camera
    How to remove date stamp from screen?
    In the lower left corner of the back of the camera just to the right of the LCD screen is a button marked "disp" by pressing the button it will change the different screen modes on should show only the picture without the numbers or writing on it.
    Dec 26, 2010 | Canon PowerShot SX20 IS Digital Camera
    How do I select to have the time and date on the photos I take. The option for this is not highlighted when I open the menu. Don't know why...
    The date stamp will only work when the camera's resolution is set to postcard mode. Press Func/set, scroll down to the bottom, then across to the icon with the clock and mountain. It will say "postcard". Press Func/set again. Then press Menu, scroll down to "Date stamp" and across to select date or date and time, then press menu again
    Dec 13, 2010 | Canon PowerShot A720 IS Digital Camera
    When I print photos, it doesn't show the date on the photo. Also , when I scroll down to Date/Stamp on the menu, it is always "off". And I can't change the setting. Help
    You haven't said what make/model your camera is, so it is hard to advise.
    Without knowing the camera, I am guessing that you may be in the wrong mode when trying to change this setting. You won't be able to change it while reviewing pictures already taken. You can only change it for pictures to be taken subsequently. Once pictures are taken, you won't be able to add the date stamp, nor remove it if it has been stamped.
    It may be that it won't allow you to set this if you haven't already set the date and time in your camera. I can't see why this setting would be shown at all if it was not possible to turn it on (i.e. if your camera did not have this feature).
    Nov 03, 2010 | Cameras
    Date stamp will not show on my camera
    I found the solution o-line. All I had to do was switch the camera to the 'postcard' mode and instant presto, I was able to access the date stamp mode. I want to express my thanks to the (I don't remember who) person who posted the solution.
    Jun 29, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
    Date/time stamp control in Menu won't allow access
    In many cameras these settings depend on the shooting mode. Did you change the shooting mode? If so, return to your normal shooting mode and the function should be available again.
    If this doesn't fix your problem I need to know if you have your camera's user manual. If I can find the solution in your user manual I need to know if you can read the steps in your own manual or if I need to provide you a link to read the manual online.
    Jan 11, 2009 | Canon PowerShot A530 Digital Camera
    Date stamp
    In order to use the date stamp option, the image size (L, M1, M2, M3, S, Postcard) has to be set to Postcard. Press the Func/Set button, scroll down to the image size icon (lower left corner), then scroll over to Postcard, and press the Func/Set button again.
    Jun 10, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
    Cameras Logo
    453 people viewed this question
    Top Cameras Experts
    Are you a Camera Expert? Answer questions, earn points and help others
