Question about Kenmore Ovens
Message f 30 on my kenmore oven after I used the self cleaning feature.
  • 744 Answers
F30 is a warning code indicating that the oven either has overheated or that the sensor may have activated the error code.
There is a sensor inside the oven that should have a resistance of about 1,100 Ohms at room temperature. If the resistance is out of range then you will need to replace the sensor.
If the resistance is within tolerances then the problem is the clock control board. Also check for any loose or bad connections.
Posted on May 10, 2009
Did the self cleaning. Now it has a F 3 code & door will not unlock.
  • Check warranty to make sure it has expired.
  • Disconnect power for 30 seconds and see if oven will reset the electrical lock.
The following link describe for Kenmore several procedures to disengage the electrical lock securing the door.
It is unfortunate that during the self cleaning cycle the stress levels at the elevated temperature premature failure appears to occur.
How to Clear the Oven Lock Mechanism on Kenmore Stove
The F3 error is most likely the temperature sensor that protrudes into the oven near the top usually on the left. Don't be confused there can be two probes that enter the oven. One is the over temp like not to exceed type of switching device and the other is the actual sensor that maintains the temperature at the set point.
There is a procedure to replace this sensor from inside the oven. I have had only limited success doing this repair in ovens from the front. Newer ovens are equipped with a plug that is easier. In all cases ensure that the plug is pushed through away from the oven wall. In older ovens I have had to pull the built in ovens to accomplish the work from the back to ensure a good connection using wire nuts... The sensor in the second photo does not have a plug so small wire nuts that will fit through the back of the oven are used.
26060093-3hiy01xauopzuspf4owyz2yd-3-2.jpg This second link is a suggestion that the use of the self clean feature is a concern, On two occasions I have had oven problems right after using the self clean cycle.
http://www.thekitchn.com/why-you-should-almost-never-use-the-self-cleaning-function-of-your-oven-175110
Jan 19, 2016 | Ovens
I have a kenmore self cleaning oven.... How do I use that feature
DONT!
More problems will ensue.
It causes more problems than solving problems!!
Head over to the manufacture's website.
Typically - they have a SUPPORT section that you enter your full model number in, and you can download the manual for free.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 19, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
The inner oven glass of my self-clean oven has a small crack. Can I still use the self-clean feature?
No, that may be what cracked it in the first place...the self clean or self destruct feature will noly finish it off for you...
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 23, 2010 | Frigidaire 30 in. Electric Gallery Series...
I have Jenn Air 30 inch slide in dual fuel oven JDS8860BDP I used the self cleaning feature on my oven 2 days ago and it has had a very strange odor ever since. A chemical oily smell within a few feet...
The self destruct or self clean feature has burnt the wiring inside your range... do not use that feature it causes the range to get too hot...
heatman101
Apr 15, 2010 | Ovens
I have a Kenmore Gas Oven, model # 911.30465864 and have lost the manual. I want to clean the oven, (it has self cleaning feature), but I am not sure if I can use oven cleaners in Gas Oven or not. Can...
Just use some easy off and do not use the self clean feature. Clean it the old fashioned way. Self clean ruins expensive electronics.
Feb 20, 2010 | Ovens
Whirlpool oven ''feature not available''
That happened to my fairly new Whirlpool double oven. But I remembeedr the power in the neighborhood had flickered earlier in the day. So I went to the circuit breaker and shutoff power to the oven for about 30 seconds and turned back on. Everything normal now. I just assumed the slight flicker in the power affected to programming.
Jan 24, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Advise use of self clean feature on kenmore self clean oven 30''
If there is an up and down arrow on the control panel, you need to press the clean button first and then choose clean time with the up and down arrow. Be sure to remove the racks, if left in the oven they will be blackened by the extreme heat. Clean them separately with oven cleaner. Place them on newspaper and spray them.
Dec 07, 2009 | Ovens
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self-clean turns off after 5 minutes with F2 error message
Hi MaryB,
F2 error code means that the oven temperature is too hot. You will have to replace relay board if faulty. Check and replace oven temperature sensor (RTD). If failure repeats, replace ERC (electronic range control or clock).For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Apr 15, 2009 | Thermador C272 Electric Double Oven
Ovens Logo
306 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
