Question about Gigabyte GA-P35-DQ6 Motherboard
HOW TO OVERCOME ERROR : Markfun_load_nt_driver
Evertime i reboot my system , i get an error : Markfun_load_nt_driver. is there any threat for my system. how could i overcome it.
  • 3 Answers
I recently built a system with Gigabyte MB and encounter the same problem after installed Easy Tune from the accompanied CD.  But it only happens when one login as Limited Rigth user.  Account with Admin right shouldn't have this problem.
Here is my simple solution - login as user with Admin right then Run Msconfig (click Start -> Run -> type in "msconfig" then click Ok.  Uncheck ETcall which is the culprit that function as Startup agent for Gigabyte's EasyTune app.
Restart your system and go see it no more even if you login as limited right user.  This way you don't have to uninstall the whole EasyTune app in case later on you would like to overclock your system and such.
Hope this may help.
Posted on Jun 27, 2009
  • 447 Answers
According to this post on another site the error seems to be related to a driver/app that came with your motherboard. It doesn't appear to be a threat but you can get rid of the error by uninstalling EasyTune in add/remove software. As suggested you may want to check the manufacturer's site for any software upgrade that may help you also...
Posted on May 10, 2009
I tryed to download my printer software and now my computer keeps shutting down evertime i try to open up a program
Boot into safe mode (Keep hitting F8 until the boot option comes up)
In safe mode go to Start, Programs, Accessories System tools
Select System Restore
Pick a date before you loaded the printer driver software
The computer should be fine now but without the printer driver
Find a printer driver from the manufacturer that matches your model and operating system
Install the printer driver
Hope this helps
Oct 13, 2010 | Computers & Internet
STOP C0000221 erro de hardware desconhecido systemroot system32 ntdll.dll
You may receive one of the following stop error messages while working on your Windows XP computer.
STOP: C0000221 unknown hard error
Path\File_nameSTOP: 0xC0000221 unknown hard error
C:\Winnt\System32\Ntdll.dll (or another specific file or driver)
STOP: 0xC0000221 STATUS_IMAGE_CHECKSUM_MISMATCH
Path\File_name
Note: The error message may be discussed in many different formats-blue screen or message box. It depends on when the corrupt file was detected.
Similarly, you may receive the following STOP messages when a critical system file fails to load on your Windows NT and Windows 2000 computer.
<path>\<file_name>STOP: 0xC0000221 unknown hard error
c:\winnt\system32\ntdll.dll
Note: Some other drive may also be given in the message.
On Windows 2000 the following error message may display:
<path>\<file_name>
You usually face this problem when an incorrect driver for one or more hardware is installed on your system. For instance, the error messages described above are displayed when you install a millions of instructions per second (MIPS) driver on a x86 system.
Cause of the Error
This error occurs if the file given in the error message is damaged.
Your Windows XP operating system checks the following files for integrity during system startup:
  • All driver files, excluding the files that loaded using the system loader to start your system .
  • All DLL (Dynamic Link Libraries) on the system. These include, Graphics Driver Interface (GDI), User, Ntdll, Crtdll, Shell, Kernel and several other DLL files on the system.
  • On Windows NT and 2000 computers, all DLLs loaded in the Window server address space are also checked.
The problem may also occur if an Iomega Zip drive is connected to the same cable as your hard disk drive.
Resolution Method
You can resolve this issue by removing the corrupt driver from your computer and then reinstalling a fresh and healthy copy of the driver. You may need to use the Device Manager utility to remove the driver. It is recommended that you clean your registry with the help of a reliable tool, such as RegGenie to ensure that all entries related to the uninstalled driver are removed from the system. After you have completely removed the corrupt driver, restart your system and install a fresh copy of the driver on the system.
If this step does not resolve the problem, you may have to reinstall Windows XP.
It is recommended that you regularly clean your registry with the help of a registry cleaner tool and perform antivirus and antispyware scan using tools, such as Antivirus Plus and StopZilla to prevent such errors from occurring on your system.
GOOD LUCK :-)
Feb 03, 2010 | Intel Computers & Internet
Zalman RSSC driver problem
you may have to use the "safely remove hardware" icon in the system tray to turn off the USB module before unplugging it as it could be causing a power spike, also this could result in more permernant damage.
Dec 13, 2009 | Zalman Tech ZM-RSSC External Sound System
Memory file dump error, pc freezes
This is the issue with your RAM chip or Operating System .Pls replace the RAM chip with goods one and on the system .If still problem not resolved pls re-install the Operating System again.
Nov 17, 2009 | E-Machines eMachines Desktop PC
Dump file error, pc freezes
I would do a complete reinstall. It looks like you have really upset your pc. The kernal files are part of the main operating system and when they mess up its not good. As I said I would redo the pc..Sorry to say you will lose all personal files on pc..
Nov 17, 2009 | Lenovo 3000 N200 Notebook - Intel Celeron...
Furuno Navnet 2. Course up incorrect
you simply need an electronic compass hooked to it. without motion, the GPS does not know which way is up
Dec 19, 2008 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Error reading motherboard cd rom
i would go to the asus website and get the drivers you need from there.
Jul 29, 2008 | ASUS Intel 440BX Chipset P2B-F Motherboard
Flyvideo 2000 video/audio synch problem
Since you upgraded your OS... you should also upgrade your memory and also the video card.... 2000 has so many features because it is designed to be used for servers. These features eats memory and processing power.
I hope you got the point... happy fixya
Feb 02, 2008 | LifeView FlyVideo 2000 / FM (701013821030)...
Xp error message
Try the following:
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Navigate to and delete the following entries:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc2k5" = "C:\WINDOWS\SVIQ.EXE"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"Fun" = "C:\WINDOWS\system\Fun.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc" = "C:\WINDOWS\dc.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"run" = "C:\WINDOWS\system32\config\Win.exe"
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\"Shell" = "Explorer.exe C:\WINDOWS\system32\WinSit.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load" = "C:\WINDOWS\inf\Other.exe"
  5. Exit the Registry Editor.
Nov 10, 2007 | Microsoft Windows XP Home Edition
Gigabyte GA-P35-DQ6 Motherboard Logo
4,230 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
