Question about HP Compaq Presario SR1820NX (ER919AA) PC Desktop
Services default values for Vista
Can anyone tell me how to find out what the default settings should be. I have changed some to manual instead of auto in order to fix a 100% CPU usage problem - it solved the problem but caused others. Silly me, didn't make a list of the ones I changed.
  • mbox000-sas May 10, 2009
    Gosh thanks, I'm going to try that now.
  • 433 Answers
We have all done that, go into you bios and there you will see install default settings, they will tell you the key like F5 or F9 then save and exit. that will install your default settings.
If you only have a problem or two tell us what the are the type and model of your computer and the operating system you employ. Most of the time it is only reinstall a driver or two...
good luck, please leave rating. thank you
Posted on May 10, 2009
Overclock problem
Hi there, the freezing is probably caused by the north-bridge or CPU not getting enough voltage or becuase you are pushing your memory past the supported frequency, changing the FSB also changes the frequency of memory, overclocking a machine could also boost the temps past the point of conventional air cooling e.g might have to use water-cooling instead. You should be careful when you overclock your computer though, electronics are sensitive and you are going to cause permanent damage to either the board or CPU. I would rather advise you to return all values to default and continue to use the system normally, if you really need it to go faster rather go and buy a faster machine. b.t.w changing the PCI-e value will have no effect on your FSB and memory values, it could instead have an adverse effect on your graphics card if you have one installed
Jun 27, 2012 | Computers & Internet
Tip
Applying the settings to the logon desktop
Next, you need to apply the Screensaver settings to the Logon Desktop / Welcome Screen (Technically, HKEY_USERS\.Default registry key), so that the Screensaver is invoked when no user is logged on. Copying all the Screensaver settings to the Logon Desktop (or Welcome Screen) manually is a tough task. Use Tweak UI instead.
Download and install TweakUI.
Launch TweakUI and click Logon, click Settings.
Select Screensaver from the list box and choose Copy Now
The Screensaver settings are applied to the Logon Desktop
Restart Windows for the changes to take effect
Allow few minutes at the Logon screen, to test if the Screensaver is working properly. The Screensaver should launch after the timeout. It will look as if the Company Logo moves around.
Additional Tip
The User interface / slider allows the minimum value for picture change interval to 6 seconds only. To reduce the change interval to less than 6 seconds, alter the registry value named ChangeInterval (Set decimal value 1000 for 1 Second, and so forth) in this key:
HKEY_USERS \ .DEFAULT \ Control Panel \ Screen Saver.Slideshow
For Current user profile, make the change here:
HKEY_CURRENT_USER \ Control Panel \ Screen Saver.Slideshow
With no logon wallpaper set, Windows displays a pre-defined color for the logon desktop. ( If you have enabled Welcome Screen, press CTRL+ALT+DEL twice to see the logon screen background color. ) To change the logon background color to that of your choice, you need to alter the registry:
Click Start, Run and type REGEDIT and press Enter
Navigate to the following key:
HKEY_USERS\.DEFAULT\Control Panel\Colors
Backup the registry key by exporting to a REG file
In the right pane, double-click Background
In the Edit String dialog box, type the Color code in R G B format and then click OK.
Example: Type 0 0 0 if you want to see a Black background. You can choose any combination from 0-255
Points to ponder
If the logon Wallpaper is set, the background Color may not be visible. So, you must reset the Wallpaper value to a blank string in this key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
If the Background value is set under the following Winlogon registry key, the above setting is ignored. In other words, the Winlogon\Background value takes precedence over the .DEFAULT..\Background value.
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
on Mar 24, 2008 | Microsoft Windows Vista Ultimate Edition
Failure to recognize CD ROM or USB ports
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UsbStor
  3. In the right pane, double click on the Start value name.
  4. Change the value data to 4 to disable the removable USB mass storage device drive access
  5. 5.
  6. To revert and re-enable the drive access for removable USB mass storage device driver, change back the value data for Start to its original default of 3.
The change will take effect immediately to block any USB mass storage device such as USB flash drive, USB key and portable harddisk from been used in the system, while still allowing hardware components to work properly via USB connection. The hack works in most Windows operating system such as Windows Vista, XP, Windows Server 2008, 2003 and 2000.
For user who dare not to modify the registry manually, simply download the following registration entries file to enable or disable the USB drive. Extract the downloaded content in .ZIP format, and then double click on the .REG file to open and apply or merge the registry values to system.
you can get technical help from a technician online
you can get in touch with them through the website
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Oct 02, 2011 | Dell Dimension 3000 PC Desktop
My laptop model-M645-S4070,not showing battery icon in the taskbar,and there is nothing about battery that how much is left
Hello, Follow the bello step
For VISTA
Right click on the Start button, click "Properties". Where it says
> "Notification icon", click that tab. On the right click "customize"
> and there should be a list of icons with a button at the bottom that
> says "restore defaults". Click that that and save the changes. Now
> the power checkbox should work!
Hope that helps. ~
OR Change the registry,
run>type regedit>enter
Windows Registry Editor Version 5.00
Change the value
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\upnphost]
"Start"=dword:00000004 (original value was 3)
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\SSDPSRV]
>And restart
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 23, 2011 | Toshiba Computers & Internet
Vista cannot get online
Go into componant services and turn them all on, it's comman with vista to have this happen when using certain optimizing and anti virus programs, like spybot. Your network may have been turned off. Also just try using the wizard to establish a new connection instead of trying to fix the one you are troubleshooting, I had a similar problem ith an HP laptop and vista, and it had some services stopped or set to manual, the reset of the services fixed it.
Jul 24, 2009 | Microsoft Windows Vista Home Premium...
Arcsoft notifier has stopped work
Run administer tools - services , find the program , change the default state to disabled or manual instead of automatic.
don001996
Jul 19, 2009 | Dell Inspiron 1525 Notebook
Vista Aero Glass Effect
According to http://www.tweakvista.com/article39008.aspx, you actually need to do this:
  1. Click on the start button and key in regedit and hit Enter.
  2. Navigate through, HKEY_CURRENT_USER, Software, Microsoft, Windows and DWM.
  3. Set Composition to 1 and CompositionPolicy to 2.
  4. Restart the DWM by restarting the Desktop Windows Manager Session Manager service. This can be done in services.msc or by typing net stop uxsms and net start uxsms at command prompt.
Hope this helps! As always, be careful in the registry!!
May 06, 2009 | Computers & Internet
Problem with Widows Vista and Internet Connection
In this case you have to get your router reset to default settings and then set it up once again and also setting upa new wireless network with a different channel because the issue you're facing is because of channel selection.
Apr 22, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Default service menu codes
They are all different, in every set. Why do peeps not remember to leave these settings alone! sorry but now you will need to have the set serviced.
Jul 11, 2007 | Toshiba 27AF41 27" TV
HP Compaq Presario SR1820NX (ER919AA) PC Desktop Logo
82 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
