I have a red spot on my clothes... why? - Washing Machines
  • 2 more comments
  • steve_j72 May 10, 2009
    GE WPSL3120
    I bought in 1999. In the owner's manual, it's mentioned 10 years on the transmission and the tub.
    Thank for your help!! Finally, I bought in 2000 june.I'll check with my vendor for the warranty.
    President:
  • 1,136 Answers
Hi, It sounds like you are getting either rust spots or oil spots. Probably oil from the transmission which means it will be replaced. If you could get me the Model#, I could get you a part# and idea on a cost.
I hope this helps.
Vic
Posted on May 10, 2009
  • 1 more comment
  • Victor
    Victor May 10, 2009
    P#WH38X10002
    The cost for the transmission is about $155.00.
    To be honest, I have not changed this style transmission yet. How old is it? Some machines have a 5 year warrenty on transmissions
    Vic
  • Victor
    Victor May 10, 2009
    Hopefully it is still under warrenty. I would call GE asap. If the spots are more red then brown, it is most likely oil.
    Good luck and let me know if I can help you on anything else.
    Vic
  • Victor
    Victor May 10, 2009
    You are very welcome. Please feel free to rate me so the others and myself know how I am doing. New at this site but have been repairing appliances for 25 years.
    Thanks
What is the best way to clean a fresh blood stain from a wool carpet?
Cold water on a clean cloth, blot with damp cloth, then with dry cloth, repeat, repeat, repeat until you do not see any red coming out. If you have a carpet cleaner flush it with lots of cold water sucking it up with your carper cleaner or extractor. A good professional carpet cleaner can prevent your spot from becoming a stain. Often you can use enzyme cleaners to remove blood but NOT on wool carpets.
Apr 07, 2016 | Vacuums
Broken lint screen, what are the 2 wires attached to lint screen housing?
the red wires go to the sensor,this is used for the auto dry where it might say more or less,when the clothes spin they rub up against the sensor when the clothes start to dry it senses this and advances the timer until the clothes are dry and then the dryer will shut off automatically.go here to see the part
https://www.repairclinic.com/PartDetail/Moisture-Sensor/131845801/823088
Nov 20, 2017 | Frigidaire GLGQ332A Gas Dryer
Tried to wipe off a small spot w some furniture polish on a t-shirt and now it is a large spot maybe from some residue. How can I best clean it without messing anything up?
Um, sorry to say. you may have damaged the unit. Panasonic plasma televisions have a coating on the glass front to reduce infra red emissions and reduce reflections.The only thing you should clean them with is a damp cloth (water only).
go to the local electronic shop and get a special cloth for cleaning flat panel displays and try that. if it doesn't come off with that, then it will need the front safety glass replaced.
Sep 27, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Red spots on clothes
Perhaps there was lipstick or crayon inside - as there's nothing mechanical that would leave red spots.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 02, 2009 | Kenmore Washing Machines
Same thing
Liquid fabric softners usually cause spots and/or marks on light colored clothing . If you rewash the clothing and the marks dissapear , then try using dryer sheets instead . However , if you have an older dryer , then clothing could be getting rubbed between the rear drum seal and panel , but that would cause streaks but no spotting .
Jul 26, 2009 | Washing Machines
Spots on clothes
By spots I'm guessing that this is a permanent mark on the cloth. If that's the case, you are possibly putting concentrated liquid bleach into the machine...it is being added and causing the spots. Solution is to dilute the bleach or other concentrated cleaner. If you're adding it manually through a hopper...add it later in the cycle.
If the spots are black...you may have a bearing leak into the machine. Repair is a big job.
Dec 02, 2008 | Kenmore Elite 45986 Front Load Washer
Red spots all over my LG LCD tv
I would check the LG website for a software update. I have a Sony and had white sparkles. After downloading their driver update, it fixed the problem along with a few other issues. Good luck.
Nov 13, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Red spot, Yellow Spot, Blue scratch on the printing document
Hi hope you fine.
is it just a spot or a continous line kind of?
is just a spot check the service kit on the front door (ETB ) alighnment might be touching the prnt drum units.
Sep 21, 2008 | HP Color LaserJet 2600n Printer
Random red stains appearing on clothes. Aeg Lavamat 50430
possible you have some red clothing in the gap between the tub and drum - there is nothing in the machine to cause red stains
to check, remove rear half of cabinet, remove heater (held by 1 10mm nut which just loosen and prize out heater) you can then see into the gap between tub and drum. shine in a torch and rotate drum by hand to see if you can spot anything. disconnect from mains first
Jul 23, 2008 | Washing Machines
Washing Machines Logo
73 people viewed this question
Top Washing Machines Experts
