Question about Belkin (F5D6130) 802.11b Wireless Access Point
Unable to get connected to Belkin f5d6130 AP
I am unable (or I do not know how???) to configure the Belkin f5d6130 AP. I tried to this step by step using user guide, but Wireles Access Point Manager does not find it.
I tried to reset the AP to default settings but it also does not help. I cannot see it, ping, etc.....
Have you any suggesstion?
Thanks
M.
  • 2 more comments
  • M S Oct 12, 2007
    Thanks you for a very quick answer.... I'll check it in few moments.... :) and inform Yoy soon.
    Thanks
    MS
  • M S Oct 12, 2007
    :( still does not work.
    I did:
    1. On AP accordig to user guide I did reset AP,
    default ip should be 192.168.0.254.
    2. On PC:
    ip: 192.168.0.10
    mask: 255.255.255.0
    dg: 192.168.0.1
    dns: 192.168.0.1
    Reset the PC.
    After that I am still not able to see the AP.
    Have You maybe idea what to do else.
    Thanks and regards.
    MS
  • M S Oct 12, 2007
    I connected PC with AP.... with crossover cable.
  • M S Oct 12, 2007
    Thanks, I will check that on weekend.
    Have a nice weekend
    MS
    Brigadier General:
  • 6,966 Answers
You need to be connected using  wired Ethernet (PC's LAN card to Router's Ethernet Port (at the back)).  This is the preferable INITIAL way to configure the router before going wireless. Also it would be to your advantage to initially set your PC (that will be used for configuring the router)  to "Specify an IP address" (static settings) and not "Obtain an IP address automatically."
For a PC connected via UTP networking cable attached to a Belkin F5D6130 AP, the networking settings could be:
IP Address 192.168.2.2
Subnet Mask 255.255.255.0
Default Gateway 19*2.168.2.1
DNS Server 192.168.2.1
Reboot
Post back results. Good luck and kind regards.
Posted on Oct 12, 2007
  • Louie  Role
    Louie Role Oct 12, 2007
    Oooopppps, it should read>
    You need to be connected using  wired Ethernet (PC's LAN card to AP's Ethernet Port (at the side)).This is the preferable INITIAL way to configure the APbefore going
    (that will be used for configuring the AP)  to "Specify an IP
  • Louie  Role
    Hi again,
    If your AP's default IP add is 192.168.0.254 (?), then your PC's Default Gateway and DNS should also be 192.168.0.254.
    On PC:
    ip: 192.168.0.10              change to           same
    mask: 255.255.255.0                                same
    dg: 192.168.0.1                                        192.168.0.254.
    dns: 192.168.0.1                                      192.168.0.254.
    Also use a straight through network cable, not all devices are autosensing and capable of accepting a crossover.
    Cheers.
SOURCE:
Using the Belkin model f7d4302 for my PC (Processor: AMD Athlon II x215, 2.7 Ghz; 6 gigs of Ram on 64 bit system utilizing the Windows 7 operating system). Unable to connect directly to my modem (Comcast...
Please follow the below steps,
(1) What type of cable you are using between your Belkin Wireless Router. If you are using a cross cable which I suspect then replace it with a straight cable. You can easily get it from Computer hardware stores and sometimes in super markets. If you do not know how to check weather a cable is straight or cross please look at the connectors of both sides of the cable from downside up. If the position of small tiny colorful wires are identical in both connectors than it is straight which we need. If the position is not identical than it is cross cable and we do not need it. It will not work properly for you.
(2) You should set the IP address to automatic in My Network/Network properties.The same for DNS.
(3) You should know the IP of the Belkin Wireless router and you should be able to ping it with the cable on.
This much configuration is required from the PC side.
(1) If you look carefully around the Belkin Wireless router you will find a pin whole. This pin whole is used to reset the settings to default by poking a pointed object like a pin. Make sure the wireless router remains powered on during this.
(2)After this if you still face connectivity problems. Try replacing with another Wireless Router just to check if the connectivity or QoS improves. If it does, you can be sure that the problem is with your Belkin wireless router.
Good Luck!
Sep 25, 2010 | Computers & Internet
Unable to configure my wireless belkin N150
As i understand you have a router provided by your ISP: MTNL, you need to configure the Belkin router in Dynamic mode and not in PPPoE. Then restart the devices by unplugging the power from MTNL router and Belkin. Wait for 20 secs, then power up MTNL router 1st, wait for all lights to get steady and finally power up the Belkin wireless router. Then you will find the modem and internet light lit up properly.
For any further clarifications, revert!
Thanks and regards,
Arvind
Jul 09, 2010 | Belkin N150 (F6D4050) 802.11g/b Wireless...
How to configure symbol 5131 through hypertrm
Hi
You can set up the AP 5131 through Hyperterminal by accessing it through COM1 to start,
19200 bits per second
8 data bits
Parity: None
Stop bits: 1
Flow Control: None.
Good Luck. :)
Apr 22, 2010 | Symbol AP-5131
Unable to configure belkin n150 router manually
while connected to router, open internet browser and enter 192.168.2.1 into the address bar. this opens most belkin router setup utilities.
Mar 04, 2010 | Belkin Computers & Internet
Setting up a wireless network access point for a Belkin F5D6130
Go to default IP.set the new IP relevant to your network ip's.
Set the ip and DNS in wireless router then only you can access the internet
Sep 23, 2009 | Belkin (F5D6130) 802.11b Wireless Access...
IPs of F5D6130
The default IP address is
192.168.0.254
The default Subnet Mask is
255.255.255.0
Thanks for contacting Fixya.
Plz give rating by click on YES or NO.
Mar 16, 2009 | Belkin (F5D7050) 802.11a/g/b Wireless...
I lost my belkin install cd
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 02, 2008 | Belkin (F5D7633UK4A) Wireless Router
Wireless Router
Greetings...
Here are the steps to hopefully get you reconnected...
SymptomNot able to connect to the router/AP wirelessly, or intermittent wireless connection.
ResolutionTo address this issue, follow the steps below:
Note : The steps below are applicable only for Belkin routers.
  1. Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page. If you are not able to open the page click here.
  2. You will get a login page. Leave the password blank. Click Submit .
  3. On the left side of the page, click Channel and SSID below Wireless .
  4. The wireless channel on the Belkin router is set to Auto by defualt. Change the wireless to a static channel. Click Apply Changes .
  5. Click Logout in the top right hand corner.
Note: The wireless card in the computer will automatically detect the change in channel number on the router and will update the channel on the card.
Have a great day...
Ed
May 28, 2008 | Belkin (F5D7230-4) Router (587009)
Netgear WG602 wireless router,
Hi, Assuming that the WG602 is fully operational, when you did a hard reset, the router reverted to its original factory setting as you posted. The default pre-configuration: act as a DHCP client; if the WG602 does not find a DHCP server on the Ethernet LAN, it defaults to this IP configuration: DHCP Client - Enable IP Address ? 192.168.0.227 IP Subnet Mask ? 255.255.255.0 Gateway ? 0.0.0.0 Your PC need to be connected via a LAN cable to one of the Ethernet ports of the AP/Router to be able to configure it again to your desired network settings. Further it is necessary likewise to manually configure the connected PC's networking configuration to match the router. Manually configure your PC's IP Address to 192.168.0.228, Subnet Mask ? 255.255.255.0, Gateway - 192.168.0.227. You can now try configuring the router through its web interface (192.168.0.227). This is better explained in the user's manual available at the Netgear site ( Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Oct 03, 2007 | NetGear WG602 802.11g/b Wireless Access...
Belkin (F5D6130) 802.11b Wireless Access Point Logo
1,105 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
