Question about Toshiba Satellite A45-S151 Notebook
Cannot connect to internet due to certificate cannot be found...also says validating identity
Cannot connect to my wireless because the icon says windows was unable to find a certificate to log me onto the network.....or it says next to the network, under view wireless networks, that it validating identity. my girlfriend can connect fine to the network so it is =something in my computer. any ideas?
Tp-link validating identity
To fix, you go into the properties page of your wireless connection, go to "Wireless Networks" tab and then to Properties of the chosen wireless network you are trying to connect to. Then go to "authentification" tab and untick the box saying "Enable IEEE802.1x to the availiable network" and that should solve your problem
  • by avatar11.jpg guitarage74 Over a year ago
    • By avatar12.jpgMac Campbell Jan 31, 2012
    • Thank you!!!! Worked on Acer Laptop like a charm. Mac
  1. This is a wonderful solution and I working at tp-link have found this has helped my customers over the phone countless times. Granted there are those "unique" situations. However, this is a great solution to help resolve the issue.
Jun 16, 2012 | TP-LINK Computers & Internet
Tip
Wireless Network issues. Validating identity and Certificate Errors in Windows...
At times after you have entered the correct password for the wireless network on your computer you are unable to connect to the wireless network and see the below mentioned errors:<br /><br /> <ul> <li>"Windows was unable to find a certificate to log you on to the network." </li> <li>"Validating identity" replacing the name of the wireless network. </li> <li>A pop-up window requesting for login credentials off the wireless connection. </li></ul><br />To avoid these error messages, you need to manually create or add a wireless network profile. Follow these steps to manually add a wireless network on Windows XP and Vista computers. <br /><br /><span>Manually add a wireless network on a Windows Vista computer:</span><br /><br /> <ol> <li>Click Start, and then select Network. </li> <li>Select Network and Sharing Center.</li> <li>Click Manage wireless networks.</li> <li>Click Add and select Manually create a network profile.</li> <li>Type the SSID, select the type of security and type the wireless password in the Security Key/Passphrase field. </li> <li>Select the Start this connection Automatically and Connect even if the network is not broadcasting check boxes. </li> <li>Click Next and close the window.</li> <li>Go to the Network and Sharing Center and select Manage network connections.</li> <li>Right click on Wireless network connection and then select Status. </li> <li>Click details and check the IPv4 address. </li> <li>If there is a valid IPv4 address, check if the computer can access the Internet wireless.</li></ol><br /><span>Manually add a wireless network on a Windows XP computer </span><br /><br />Note: The following steps are for a wireless network that has WEP security.<br /><br /> <ol> <li>Click Start, then select Control Panel.</li> <li>In the left pane, select Switch to Classic view.</li> <li>Click Network Connections.</li> <li>Right click Wireless Network Connections and select Properties.</li> <li>Click on the Wireless Networks tab.</li> <li>Click the Add button.</li> <li>Enter the name of the wireless network (SSID). </li> <li>Set the encryption type to WEP.</li> <li>Clear the key is provided for me automatically check box.</li> <li>Enter the network key and confirm it. Note: Make sure that "This is a computer-to-computer (ad-hoc) network" is not selected. Click OK, and then click OK again.<br /></li> <li>Right-click Wireless Network Connections and select Status. </li> <li>Click on the Support tab and check if there is a valid IP address.</li> <li>Check if the computer can access the Internet wirelessly.</li></ol> <br /><br />If you still receive the same error message after manually adding a wireless network on a Windows XP computer, ensure that IEEE 802.1x authentication of the wireless adapter is disabled.<br /><br /><span>To disable IEEE 802.1x authentication: </span><br /><br /> <ol> <li>Click Start, then select Run.</li> <li>In the Run dialog box type ncpa.cpl and then click OK.</li> <li>Right-click the Wireless network connections icon, and then select Properties. </li> <li>Click the Wireless network tab.</li> <li>Click the Properties button beside Remove. </li> <li>Click the Authentication tab, and clear the Enable IEEE 802.1x authentication for this network check box.</li> <li>Click OK to update the settings.</li></ol>This TIP applies to: <br /><br /><span>All Windows XP and Vista computers that display the listed error messages when attempting to connect to wireless network of routers (specifically NETGEAR).</span>
on Apr 28, 2011 | Computers & Internet
Wireless router not validating my identity
Hi, Follow the steps below to configure settings :
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 30, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Cant find certificate for wireless
Jun 14, 2009 | Belkin (F5D5231-4) Router
Wireless network connection windows was unable to find a certificate to log you onto network
xp : go to start --> control panel ---> on the top leff click on "switch to classic view" then open network and internet connections right click on the wireless conn. then from the upper tabs go to "Authentication"  your setting should be as following :
Enable IEEE 802.1x ....... (cheked) EAP Type : Smart Card or certificate Authenticate as computer ...... (checked) Authenticate as gues ..............(unchecked)
then click on "properties"
choose "use a certificate on this computer" and check "use simple caertificate ......" and check "Validate server certtificate" click ok till u close all the boxes
:D hope that would work :D
Oct 17, 2008 | Computers & Internet
Wireless problem
its windows. nothing to do with the software. after you removed it. its long gone. Check the wireless and the OS settings
Jul 25, 2008 | Belkin (F5D7230-4) Router (587009)
D-Link Wireless: validating identity
I believe this has to do with your automatic router/setup for wireless networks....but this is what I did to clear the same problem:
1) Right click on the tray icon that is searching for validation and select status.
2) A "Wireless Network Connection Status" box will open, click "Properties".
3) Your "Wireless Connection Properties" box will open showing the Wireless Networks available. Find the wireless network you are connected to and highlight it by clicking once, then click "Properties" just below.
4) Another box will then open with the properties for your network. Click on the "Authentication" tab.
5) Un-check the "Enable IEEE 802.1x Authentication...." checkbox.
You're good to go.... :)
Jun 17, 2008 | Computers & Internet
Validating identity
it is just that the network key which is stored in the computer is not working so the 1st thing u need to do is verify the network key for that go to 192.168.0.1 from internet explorer enter the user id & password of ur dlink ( default id: admin password : admin) the go to wireless check the WEP or security key which is present their. reenter that key the computer & try to connect.
If it didn't work then go to control panel >> system >> hardware>> device manager
look for the network adepter & unintall the wireless network card
restart the computer
once restart it will automatically reintall the wireless card driver
then go to control panel>>Network Connection
right click on wireless network connection
select view wireless network connect
select ur network name & connect it will ask for the key provide the key & once u do that it will get connected & work fine
if in case u have the same problem replay back & i help u out with it & also provide all the details like which windows & network card etc
May 25, 2008 | D-Link AirPlus DI-524 Wireless Router
Toshiba Satellite A45-S151 Notebook Logo
717 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
