Question about Microsoft Internet Explorer 8
Why do i keep getting DEP error message each time i close IE8 or a tab?
Try disabling all of your internet explorer addons, then reenabling them one at a time until you get the error again. That should be the addon that is causing the problem.
Posted on May 22, 2009
  • 432 Answers
Windows xp has DEP ( data execution prevention ) some viruses etc use that sort of technique and from SP2 onwards I believe it was they included it.
http://www.zensoftware.co.uk/kb/article.aspx?id=10002
Several OSs have no-execute or execute protection. Microsoft has added this as well in SP2 with data execution prevention (DEP). This precents code execution in memory regions already marked as storage. This is a powerful tool against buffer overrun exploits. If a program is failing and you want to disable DEP to see if that is the cause. Here are the steps. (Just disable DEP for the program in question… don’t disable it for your whole system.)
    1. Click Start
    2. Select Control Panel
    3. Select System
    4. Click the Advanced tab
    5. In the Performance region select Settings
    6. Click the Data Execute tab in the dialog box that opens
    7. Select Turn on DEP for all programs and services except for those I select
    8. Click Add.
    9. The open dialog box will open. Browse and select your application.
    10. Click Open
    11. Click Apply
    12. Click Ok
    13. Reboot
Posted on May 10, 2009
2 Suggested Answers
sabharish
  • 297 Answers
SOURCE: why do i keep getting DEP error message each time
You can disable DEP by following these steps:
Disable Data Execution Prevention (DEP) completely
  1. Click Start, and then click Control Panel.
  2. Under Pick a category, click Performance and Maintenance.
  3. Under or Pick a Control Panel icon, click System.
  4. Click the Advanced tab, and in the Startup and Recovery area, click Settings.
  5. In the SystemStartup area, click Edit.
  6. In Notepad, click Edit and then click Find.
  7. In the Find what field, type /noexecute and then click Find Next.
  8. In the Find dialog box click Cancel.
  9. Replace the policy_level (for example, "OptIn" default) with "AlwaysOff" (without the quotes).
    WARNING: Be sure to enter the text carefully. Your boot.ini file switch should now read:
    /noexecute=AlwaysOff
  10. In Notepad, click File and then click Save.
  11. Click OK to close Startup and Recovery.
  12. Click OK to close System Properties and then restart your computer.
This setting does not provide any DEP coverage for any part of the system, regardless of hardware DEP support.
Verifying DEP is Disabled
  4. Click the Advanced tab.
  5. In the Performance area, click Settings and then click Data Execution Prevention.
  6. Verify that the DEP settings are unavailable and then click OK to close Performance Settings.
  7. Click OK to close System Properties then close Performance and Maintenance.
Thank you!
Sabharish
Posted on Jun 04, 2009
Data execution prevention as I am getting this messaGE WHENEVER i GO TO OTHER WEBLINK AND iNTERNET eXPLORER SHUTS OF SO i NEED YOUR HELP
There is two area's that DEP is held One in the perfomance section and the other in IE Firstly we'll fix IE DEP 1. Open up IE and quickly select Tools 2. Select the advanced tab 3. Uncheck the Enable memory protection 4. Restart IE to apply. 1. Start\Control Panel\System and Maintenance\Performance Information and Tools\Adjust visual effect 2. Select the Data execution prevention tab 3. Check the Enable DEP for Essential windows programs and services 4. Restart the computer to apply.Disable DEP using CMD A) In the command prompt, type bcdedit.exe set {current} nx AlwaysOff and press Enter.B You should get a success message back C Close the command prompt. D Restart the computer to apply. Enable DEP using CMD A In the command prompt, type bcdedit.exe /set {current} nx OptIn and press Enter. B You should get a success message back C Close the command prompt. D Restart the computer to apply.
If a program is being closed by DEP, then make sure that it is a DEP compatible version and check for an updated version. If it is not DEP compatible, then you can uninstall the program or turn off DEP for that particular program.Follow the steps below to to close Data execution prevention a. Click on start. b.Right click on Computer and click Properties.c. Click on Advanced system settings.in upper left green area d.Click on the Continue button in the UAC prompt.e Click on the Settings button under Performance section.f Click on the Data Execution Prevention tab. g. Turn DEP On for Essential Windows Vista Programs and Services Only.NOTE: This turns on DEP for only the 32 bit system programs and services. This is the default setting. h.Click on Turn on DEP for essential Windows programs and services only.click on OK to apply. j.Turn DEP On for All Programs and Services Except for the Ones you Select.NOTE: This turns on DEP for every 32 bit program except for the ones that you add to the list. The listed program will have DEP turned off for it.Turn on DEP for all programs and services except those I select. Click Add to add the programs that you do not want to use the DEP feature. m. Navigate to the program's .exe file that you want to add to the DEP exclusion list and select it, then click on Open. n.Click on OK to apply. b. Restart the computer to apply changes.
Oct 24, 2011 | HP Pavilion DV6000T 15.4­ NOTEBOOK LAPTOP...
DEP as IE shuts of
1. Start Control Panel System and Maintenance Performance Information and Tools Adjust visual effect 2. Select the Data execution prevention tab 3. Check the Enable DEP for Essential windows programs and services 4. Restart the computer to apply.
Alternatively
A) In the command prompt, type bcdedit.exe /set {current} nx AlwaysOff and press Enter.
B) You should get a success message back
C) Close the command prompt.
D) Restart the computer to apply.
A) In the command prompt, type bcdedit.exe /set {current} nx OptIn and press Enter.
Regards
Oct 24, 2011 | Microsoft Windows? Vista Home Premium...
How do I find the undo tab in Internet Explorer 8 How can I receive a instrustion manual for Internet Explorer 8
Please follow the below steps to undo Tab in IE8
To Reopen Closed Tabs in IE8 with Keyboard Shortcut
Press Ctrl + Shift + T keyboard shortcut will reopen the last closed tab. Press the same keyboard shortcut sequence again will open another tab that was closed prior before the previously opened tab. Ctrl + Shift + T supports restoration of up to last 10 tabs that are closed during the browsing session.
To Restore Closed Tabs in IE8 in New Tab Page
If may be easier to be able to browse and select which already closed tabs that user wants to reopen. IE8 provides such as option to reopen one or more closed tabs too, in "New Tab" page, which also displays complete web page titles of the closed tabs.
To open a new tab page, just press Ctrl + T keyboard shortcut, or click on New Tab button on the Tab bar.
Open New Tab in IE8
In the new tab page, there will be a Reopen closed tabs section. The last ten recently closed tabs that have been closed since starting Internet Explorer will be listed. Just click on the one that user wants to reopen. To reopen all closed tabs, just click on Open All link.
you may also download the user manual for IE8 from the below link,
http://download.microsoft.com/download/9/7...August%2008.pdf
Oct 09, 2010 | Microsoft Internet Explorer 8
When I try to play a big fish game I get the drm activator stopped working message...the game is midnight mysteries..curse of the raven or something like that..the solution involving checking windows to...
To fix this, go to: Control Panel > System > Advanced System Settings > Settings (under performance) > DEP (tab) and then add your program as an exception.
Aug 16, 2010 | Computers & Internet
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; InfoPath.1) Timestamp: Mon, 25 Jan 2010 20:30:47 UTC Message: HTML Parsing Error: Unable to modify the...
Within IE8, delete all Temporary Internet Files.
Close IE8.
Open IE8, and access Facebook's "home" page.
Does the error happen "all" the time, or only when accessing one specific friend's web-page?
If the latter, then there's a problem on that person's web-page -- avoid that page to avoid the error-message.
Jan 25, 2010 | Microsoft Internet Explorer 8
Hi I,m trying to log into the landregistry web site and this is the error I get can anyone help please the username and password is accepted and this has been checked I can get in using firefox however...
Open IE8, Click Tools, Internet Options, Advanced, Restore Advanced Settings, Click Apply, Click Security Tab, and click Reset all zones to default level, Clcik Privacy Tab, and click Default (if greyed out, you are already using default). Click General Tab, and Click Delete, then select all but your Passwords, and click delete Button, then click OK. Close all IE Browser Windows. Reopen IE8, go to https://www.landregistrybusiness.gov.uk/hmlr-login/userintro and trty logging with your credentials.
If you still receive error message, Open IE8, Click Tools, Internet Options, Advanced, and click Reset under Reset Internet Explorer Settings, Check delete Personal Seetings and click Reset. Close all IE Browser Windows. Reopen IE8, go to https://www.landregistrybusiness.gov.uk/hmlr-login/userintro and trty logging with your credentials.
Jan 13, 2010 | Microsoft Internet Explorer 8
Internet Explorere keeps closing down
Data Execution Prevention (DEP) is a security feature that helps prevent damage from viruses and other security threats by monitoring your programs to make sure they use system memory safely.
Here is a link to an excellent article on DEP.
Whie it will show you how to turn DEP on, it will also take you to the control panel that will aloow you to adjust your settings.
http://windowshelp.microsoft.com/Windows/en-US/help/1d9bb9b4-f6ba-466d-ac2b-7b8c4f8361611033.mspx
Oct 03, 2009 | Computers & Internet
ALert Messages are not shown in IE8
If you mean alerts of page errors, then click on Tools menu, Internet options, Advanced tab, scroll to Browsing and check "Display a notification about every script error"
Aug 25, 2009 | Computers & Internet
Why do i keep getting DEP error message each time i close IE8 or a tab? when i close a tab ie8 reloads it because of dep problems can i go back t ie7 and will this stop the reloads i now have to go to...
Thank you!
Sabharish
Jun 03, 2009 | Microsoft Internet Explorer 8
"Internet Explorer has has stopped working..."
After installing IE8 on vista I kept getting msg Internet Explorer has stopped working - continually looping thru this message.
Solution for me was.
End IE with task manager - needed to do a couple of times.
Then from control panel -> programs -> manage addons I disabled all add ons and then IE started OK. Then by process of elimination stated enabling add on until failed again.
In my case it was the skype addon that was causing IE to fail. Leaving it disabled has allowed IE8 to function.
Apr 25, 2009 | Microsoft Internet Explorer 8
Open Questions:
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET4.0C; nsapshr 10.0.3) Timestamp: Mon, 7 Jul 2014 20:45:22 UTC Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js Message: Script error Line: 0 Char: 0 Code: 0 URI: https://maps.gstatic.com/cat_js/intl/en_us/mapfiles/api-3/16/13/%7Bmain,drawing%7D.js
Jul 07, 2014 | Microsoft Internet Explorer 8
See all Microsoft Internet Explorer 8 Questions
Microsoft Internet Explorer 8 Logo
1,784 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
