Question about GE Microwave Ovens
Where can I get a replacement fusible link for a GE Microwave
I have a GE Microwave Modle #WES1384SM2SS which will not power up. I have traced the problem to a blown fusible link. The marking on the link are NT101 KIE and N100 0 7713. GE does not sell this as a replacement part. I have search various parts services, but no one carries it. Where can one get a replacment part?
Just had the same problem with my GE microwave. The electric print shows that the reset temperature for this switch NT101 is 32 degrees F. I put mine in the freezer (sitting on a ice cube) over night and the next morning it was good to go. I have not run the microwave extensively since I put it back together, but so far so good.
If you want to buy this part, I believe this link is the item you want. Not too expensive: http://store.appliancezone.com/servlet/-strse-61213/GE-General-Electric-RCA/Detail
Good luck,
Dennis
Posted on Jun 23, 2009
I have a GE WES1384SM2SS microwave oven that shoots fire out of the right hand side.
Sounds like it is arcing there. Is there a plastic or Mica cover there?? If so that is the wave guide cover and it will need to be replaced and any and all carbon burn marks totally cleaned out to be able to save the machine. You can remove the burnt cover and run the unit with a container of water in it to see if it still arcs. If it does more cleaning will be needed if not, replace the covers with new ones and you should be good.
Aug 12, 2017 | GE Microwave Ovens
WHERE CAN I FIND A DOOR SWITCH FOR MY GE MICROWAVE WES1384SM2SS
Most microwave ovens use generic "microswitches" for door switching. You will need to open your oven, and find what they look like, and then match them.
I bought replacements here:
Allied Electronics Electronic Components Distributor
but any electronics distributor will have them. Inexpensive, only a few dollars eacy. My ovens actually use 4 switches on the doors, and more than one were bad.
Jun 04, 2015 | GE Microwave Ovens
WHAT WILL MAKE MY GE MICROWAVE WES1384SM2SS FUSE KEEP BLOWING I REPLACED IT ONCE AND AS SOON AS I OPEN THE DOOR IT BLEW AGAIN
The fuse is there to protect your home in case something has gone wrong inside your microwave. Since the fuse has blown twice, you can safely assume that there is something wrong inside. It may be fixable, it may not be economic to fix it. Impossible to troubleshoot electronics without the unit and test equipment.
Wes1384sm2ss
It didn't come with one?
Oct 21, 2013 | Microwave Ovens
I HAVE A GE MICROWAVE/BROWNER NODEL WES1384SM2SS. IT HAS STOPPED RUNNING. I CAN SET IT UP TO COOK BUT WHEN I HIT THE START BUTTON NOTHING HAPPENS.
Re: GE JES1384SF Mine quit working so I unplugged it and put a pot of boiling water in it and let the steam dissolve whatever was gumming things up. I used an electric hot plate to keep the water boiling. I let it boil for a couple of hours. I left the door 2/3 open. The microwave is working again. It is four years old and has been used every day, many times a day before it stopped working.
Jan 08, 2011 | GE JES1384SF Microwave Oven
Model WES1384SM2SS runs bur no heat?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 09, 2010 | General Electric Microwave Oven
GE Microwave wes1384sm2ss quit cooking. it
Owners of a GE WES model might want to look at this blog post.
Nov 28, 2009 | GE JE1640 Microwave Oven
Brother put a foil wraped burger in micro now everything is dead
Hi, You may want to try to check/troubleshoot the PCB underneath the display/control panel. The mains do supply two circuitries: the heavy load and the electronics. In some units, they have a standard transformer while in others an SMPS that supplies the +5 (and sometimes +12 or higher) voltage. This powers the electronics which includes a microcontroller, timer, relay drivers and display panel. Trace the transformer/SMPS and look for any fusible link, secondary fuse or surface mounted fuse. More often than not, there are also standard components along the way like bride diode, diode, filter capacitor and regulator IC. Check for VDC input and output of power components. Hope this gives you an idea, Pls post again how things turn up or if you need further information. Good luck and kind regards.
Aug 11, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
2,657 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
