Tring to link TV to DVD & Sky
I am trying to link my dvd recorder and TV together. I have tried plugging from the tv to dvd to sky and back to dvd. Unfortunately this does not work. The model no is. Daewoo DTY-28W5GB. Are you able to help? Many thanks Donna
harry0000010
  • 40 Answers
SOURCE: unable to get a sky
swap out the sky box and see if that helps...or take your box to your friends house and see if it works there..........
Posted on Feb 03, 2008
SOURCE: Connecting TV-DVD recorder-Sky plus
scart from the sky to the dvd recorder. then a scart from each to the tv. Job done.
Posted on Jun 14, 2008
SOURCE: setting up 42lg3000 with sky
i have same tv, this i was i did on mine. on the sky+ remote push tv and then press select + red button at the same time, the red light blinks twice, then push 1174 then power button.
Posted on Jan 07, 2009
8880u81
  • 3103 Answers
SOURCE: Toshiba Dvd won't work properly with my new TV
if your old tv was an analog one you need a digital converter box to change to the new signal.. new tvs wont recognize the analog signal..temporarily you may be able to use your laptops' dics player as a player for your discs..
Posted on Jan 11, 2014
wmdwhitt
  • 18 Answers
SOURCE: what are the sky remote codes for a Technika 39E21B-FHD tv?
Remote Central doesn't show any of these devices. I did find your manual. It is the second link below.
Posted on May 27, 2014
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Unable to set TV channels on dvd recorder since connected to Sky box
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
Feb 18, 2008 | Televison & Video
I cant get dvd recorder to record ext 2
Firstly, is the scart lead plugged in fully? Does it get the sound or nothing?
Is the recorder sitched to the correct input? It may be trying to pull a signal from the TV which may not be passing through the picture from the sky box.
Also, is the scart lead fully wired? Some only work one way so try spinning it round between the recorder and sky box.
Nov 24, 2011 | Philips DVDR70 DVD Recorder
Connecting DVD recorder to TV and SKY box
A simple solution - aerial input socket error - wrong socket!!
There are too many choices on the DVD record/play machine. When the plug came out - it was pushed back into the wrong socket.
Nov 30, 2009 | Sony RDR-GX300 DVD Recorder
Cannot tune -in my panasonic vcr. it plays tapes but will not record. I have wired together the tv, sky box and vcr in what seems the obvious way (and every alternative) but no joy so far. can you help?
The main aerial goes into the vcr,a fly lead then comes out of the vcr into the tv,a scart lead from av1 on the vcr into the tv.If you want to record from sky and the vcr has two scart sockets then connect a scart lead from the sky into av2 on the vcr,when you record from sky you select av2 on the vcr as your record channel
Sep 24, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
I have a philips dvdr70
From the Sky box, plug one SCART lead to your recorder and plug another to your TV. Then plug a SCART from the TV to the recorder.
You can then select the SCART connector for the sky box to record programs.
This will work after the digital switchover. The switchover is only for 'normal' tv signals from your tv aerial
Jan 12, 2009 | Philips DVDR70 DVD Recorder
Jan 18, 2008 | Televison & Video
Setting up
on the back of your sky box there are two scart ports. one says tv and the other video.
from the sky box connect a scart from the tv port to the back of your tv.
from the DVD connect a scart from that to the video scart port on the back of your sky box.
now when you turn your DVD player on it will override the sky and come through on your telly without having to change the scarts around.
what i would like you to do now. is get an RF lead. ( aerial lead) plug this into the RF out socket on the back of your sky box either one will do ie RF out 1 or 2 makes no difference.
Then plug the other end into the back of your Tv if you have an aerial cable coming into your home then simply plug this straight into the aerial port on the back of your sky box.
The last thing your going to have to do now is tune your telly in. if you click on channel 6 on your telly then go to menu, setup, and manual tune.. A good tip for you put your sky on the TV GUIDE screen this will make life easier for yourself as you will know its the sky channel.
once you find it STORE.
now when you turn your dvd player on if you select channel 6 you will now have the sky channel so you can record whatever you like
Hope this sorts you out.
cheers
Little Dish Fitter
Dec 28, 2007 | Samsung DVDHR738 (250GB) DVD Recorder /...
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Wife moaning at sound delay.......why.....
The sound delay would not be caused by hooking amp up but must be a software problem in sky box. Try to get an off air station with a antenna and see if the problem persists.The dvd recorder should see your sky box output first then out from recoder to tv.Then use tv audio out to amp,or tv audio out to amp. RANDY
Mar 16, 2007 | Cambridge Audio Azur 540A Amplifier
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
