Question about Frigidaire GLTF1670A Front Load Washer
Drum keeps filling with water when not in use
My frididaire front loading washing machine model #gltfq670aso, is filling with water slowly when not in use. dosen't mater if the door is open or closed, set on off position or even unpluged.
    President:
  • 1,136 Answers
Hi, You will need a new water inlet valve. the valve has stuck open just enough to let water trickle in. Until you can repair it, just turn the valve off at the wall. If you have not yet found your answer, let me know and I will assist you in getting part#.
I hope this helps. If so, please rate my answer so I know how I am doing.
Posted on May 10, 2009
Electrolux EWF 1495 won't spin.
The belt could be stretched or the tension idler could be malfunctioning.
Feb 12, 2015 | Electrolux Washing Machines
Machine will fill and turn slowly but will not
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
Mar 30, 2010 | Tricity Bendix AW1400W Front Load Washer
Miele W916 front-loading washing machine filling very slowly
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
Mar 05, 2010 | Miele Novotronic W1918A Front Load Washer
After water drains, it slowly comes back and fills in the drum over time.
Use the attached video to show you how to access the inside of the machine.Ignore the other parts other than access and re-assemly.
Apr 30, 2009 | Whirlpool GHW9150 Duet Washer
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Tumbler Washer drum fills with water when unit is not operating.
yes the water vale is defective it has goten a little piece of sand of something in it and it dont take much replace the valve and the problem will be gone good luck
Nov 14, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Kitchenaid front loading washing machine
check your drain hose see if its too low lower than the tub or too far down in the drain as this will cause a siphon action
Mar 02, 2008 | Washing Machines
Drum filling up with water when not in use.....
only source is leaking inlet valves and only way to cure is to replace
May 14, 2007 | Tricity Bendix AW1000W Front Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
64 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
